查看: 4471|回复: 7
[求助] RT1064如何通过网络魔法包唤醒?
发表于 2021-5-25 13:33:39 | 显示全部楼层 |阅读模式
1.根据手册将ENETn_ECR[SLEEP]  和 ENETn_ECR[MAGICEN] 两个位置位2.使能ENET唤醒中断,打开ENET中断
3.使用UDP向板卡发送魔法包
4. 网卡没有睡眠之前板卡能够接收到以太网帧, 但是调用ENET_EnableSleepMode(ENET,1);使网卡休眠后.EIR[WAKEUP]位不能够置位???
如何定位问题
int macsleep111(void)
        //ENET_EnableSleepMode(ENET,1);
        ENET->ECR |= (1 <<2 );
        ENET->ECR |= (1 <<3 );
        DisableIRQ(ENET_IRQn);
        ENET_EnableInterrupts(ENET,ENET_ERR_INTERRUPT|kENET_WakeupInterrupt );
        NVIC_ClearPendingIRQ(ENET_IRQn);
        NVIC_EnableIRQ(ENET_IRQn);
        LPM_EnableWakeupSource(ENET_IRQn);
        return 0;
MSH_CMD_EXPORT(macsleep111, wakeup_demo );
magic packet
magic packet
magic detect
magic detect
接收到的魔法包
接收到的魔法包
  • 签到天数: 1506 天
    发表于 2021-5-25 17:57:29 | 显示全部楼层
    网口还能这么玩啊
    发表于 2021-5-27 11:23:53 | 显示全部楼层
    正在测试,请稍后
     楼主| 发表于 2021-5-27 14:03:15 | 显示全部楼层
    小恩GG 发表于 2021-5-27 11:23
    正在测试,请稍后
    官方驱动需要在这里
    #define ENET_ERR_INTERRUPT        \
      (kENET_BabrInterrupt | kENET_BabtInterrupt | kENET_EBusERInterrupt |
         kENET_LateCollisionInterrupt | \
         kENET_RetryLimitInterrupt | kENET_UnderrunInterrupt | kENET_PayloadRxInterrupt
        |kENET_WakeupInterrupt)
    加上唤醒中断kENET_WakeupInterrupt
    在初始化ENET配置唤醒中断后才会有错误中断处理,现在EIR[WAKEUP]能够正常置位,但是不能够唤醒,使用官方E:\01_auto_sample\SDK\boards\evkmimxrt1064\lwip_examples\lwip_httpsrv\freertos\mdk测试过了
    int enetwakeup(void)
        uint32_t freq;
        /* When wakeup from suspend, peripheral's doze & stop requests won't be cleared, need to clear them manually */
        IOMUXC_GPR->GPR4  = 0x00000000;
        IOMUXC_GPR->GPR7  = 0x00000000;
        IOMUXC_GPR->GPR8  = 0x00000000;
        IOMUXC_GPR->GPR12 = 0x00000000;
        CLOCK_SetMux(kCLOCK_UartMux, 1);
        CLOCK_SetDiv(kCLOCK_UartDiv, 0);
        DEBUG_MSG("\r\nCPU wakeup source 0x%x...\r\n", SRC->SRSR);
        APP_PrintRunFrequency(0);
        LPM_Init();
        while (1)
            freq = CLOCK_GetFreq(kCLOCK_CpuClk);
            DEBUG_MSG("\r\n########## Power Mode Switch Demo (build %s) ###########\n\r\n", __DATE__);
            DEBUG_MSG("    Core Clock = %dHz \r\n", freq);
            APP_ShowPowerMode(s_curRunMode);
            s_targetPowerMode = LPM_PowerModeSysIdle;
            if (s_targetPowerMode <= LPM_PowerModeEnd)
                /* If could not set the target power mode, loop continue. */
                if (!APP_CheckPowerMode(s_curRunMode, s_targetPowerMode))
                    continue;
                            ENET_EnableInterrupts(ENET,kENET_WakeupInterrupt );                                //ʹ�ܴ����ж� �����ж�
                            NVIC_ClearPendingIRQ(ENET_IRQn);                //����Դ������
                            LPM_EnableWakeupSource(ENET_IRQn);                //ʹ�ܻ���Դ
                APP_PowerPreSwitchHook(s_targetPowerMode);
                APP_PowerModeSwitch(s_targetPowerMode);
                APP_PowerPostSwitchHook(s_targetPowerMode);
                            ENET_EnableSleepMode(ENET,0);// MAC�˳�����
            DEBUG_MSG("\r\nNext loop\r\n");
    进入睡眠模式之前能够正常职位EIR[WAKEUP],  进入睡眠模式之后不能够唤醒
    发表于 2021-6-30 17:20:56 | 显示全部楼层
    这个睡眠唤醒测试了没啥问题,NXP已经把中断转化成事件了,你不要自己写,用他的就行了,当然还得改点东西,这就像STM32的HAL库已经封装SysTick了就别自己写了,直接用HAL_Delay就好。但是这个睡眠监测了一下功耗,没节能呀,所以没啥用呀,也不知道结合MCU的电源管理节能的效果。
    干不完的事
    发表于 2021-6-30 17:31:34 | 显示全部楼层
    fengyun2018 发表于 2021-6-30 17:20
    这个睡眠唤醒测试了没啥问题,NXP已经把中断转化成事件了,你不要自己写,用他的就行了,当然还得改点东西 ...
    修正一下不是1064是1021
    干不完的事
     楼主| 发表于 2021-7-7 14:00:58 | 显示全部楼层
    fengyun2018 发表于 2021-6-30 17:31
    修正一下不是1064是1021
    现在使用1064确实没有测试出来,可否贡献以下1021代码?
    发表于 2021-7-7 22:08:55 | 显示全部楼层
    也没几句,1、我看ENET_ERR_INTERRUPT一堆搞它也没啥用,就把它放到ENET_TS_INTERRUPT处理中了,先配置enet_config_t的中断事件类型,config.interrupt = ENET_RX_INTERRUPT;2、配置中断事件回调函数ethif.handle.callback=enet_event_callback_r;然后是函数的处理部分void enet_event_callback_r(ENET_Type *base, enet_handle_t *handle,  enet_event_t event,  enet_frame_info_t *frameInfo,  void *userData) {...};3、把ENET_ErrorIRQHandler中单独判断部分if (0U != ((uint32_t)kENET_WakeupInterrupt & base->EIR)){...}拷贝到ENET_ReceiveIRQHandler中,4、最后修改个BUG,它把你配置清除了(void)memset(handle, 0, sizeof(enet_handle_t));,需要在这句之前备份enet_callback_t callback_temp = handle->callback;然后在后面恢复handle->callback         = callback_temp;
    干不完的事
    GMT+8, 2025-10-27 07:59 , Processed in 0.087300 second(s), 27 queries , MemCache On.
