在线时间7 小时
UID3509846
注册时间2018-9-27
NXP金币0
- 61
- 2021-9-17
楼主 |
发表于 2021-7-29 21:20:28
显示全部楼层
DebugLog求帮忙分析下是不是哪里没设置好,另外,片内Flash我使用SDK的fsl_romapi的例程下载到Ram中,可以正常擦除读取写入数据。
是不是J-LINK哪里下载的Flash算法需要改或者哪里没有设置好呢?
Thu Jul 29, 2021 21:13:58: IAR
Embedded Workbench 8.50.9 (C:\
Program *** (x86)\IAR Systems\
Embedded Workbench 8.4\arm\bin\
armproc.dll)
Thu Jul 29, 2021 21:13:58: Loaded
macro file: C:\Program *** (x86)\IAR
Systems\Embedded Workbench 8.4\
arm\config\debugger\NXP\
iMXRT.dmac
iMXRT_Trace.dmac
arm\config\flashloader\NXP\
FlashIMXRT1060_FlexSPI.mac
Thu Jul 29, 2021 21:13:58: JLINK
command: ProjectFile = C:\Users\yhf\
Desktop\
SDK_2_9_2_MIMXRT1064xxxxA\
boards\evkmimxrt1064\demo_apps\
led_blinky\iar\settings\
iled_blinky_flexspi_nor_debug.jlink,
return = 0
Thu Jul 29, 2021 21:13:58: Device
"MIMXRT1064XXX6A" selected.
Thu Jul 29, 2021 21:13:58: DLL version:
V7.50a, compiled Jul 8 2021 18:16:52
Thu Jul 29, 2021 21:13:58: Firmware:
J-Link V9 compiled May 7 2021 16:26:12
Thu Jul 29, 2021 21:13:58: Selecting
SWD as current target interface.
Thu Jul 29, 2021 21:13:58: JTAG speed
is initially set to: 32 kHz
Thu Jul 29, 2021 21:13:58: InitTarget()
start
Thu Jul 29, 2021 21:13:58: _TargetHalt:
CPU halted
end
Thu Jul 29, 2021 21:13:58: Found
SW-DP with ID 0x0BD11477
Thu Jul 29, 2021 21:13:58: DPIDR:
0x0BD11477
Thu Jul 29, 2021 21:13:58: Scanning AP
map to find all available APs
Thu Jul 29, 2021 21:13:58: AP[1]:
Stopped AP scan as end of AP map
has been reached
Thu Jul 29, 2021 21:13:58: AP[0]:
AHB-AP (IDR: 0x04770041)
Thu Jul 29, 2021 21:13:58: Iterating
through AP map to find AHB-AP to use
Thu Jul 29, 2021 21:13:58: AP[0]: Core
found
AHB-AP ROM base: 0xE00FD000
Thu Jul 29, 2021 21:13:58: CPUID
register: 0x411FC271. Implementer
code: 0x41 (ARM)
Cortex-M7 r1p1, Little endian.
Thu Jul 29, 2021 21:13:58: FPUnit: 8
code (BP) slots and 0 literal slots
Thu Jul 29, 2021 21:13:58: CoreSight
components:
Thu Jul 29, 2021 21:13:58: ROMTbl[0] @
E00FD000
ROMTbl[0][0]: E00FE000, CID:
B105100D, PID: 000BB4C8 ROM Table
Thu Jul 29, 2021 21:13:58: ROMTbl[1] @
E00FE000
Thu Jul 29, 2021 21:13:59:
ROMTbl[1][0]: E00FF000, CID:
B105100D, PID: 000BB4C7 ROM Table
Thu Jul 29, 2021 21:13:59: ROMTbl[2] @
E00FF000
ROMTbl[2][0]: E000E000, CID:
B105E00D, PID: 000BB00C SCS-M7
ROMTbl[2][1]: E0001000, CID:
B105E00D, PID: 000BB002 DWT
ROMTbl[2][2]: E0002000, CID:
B105E00D, PID: 000BB00E FPB-M7
ROMTbl[2][3]: E0000000, CID:
B105E00D, PID: 000BB001 ITM
ROMTbl[1][1]: E0041000, CID:
B105900D, PID: 001BB975 ETM-M7
ROMTbl[1][2]: E0042000, CID:
B105900D, PID: 004BB906 CTI
ROMTbl[0][1]: E0040000, CID:
B105900D, PID: 000BB9A9 TPIU-M7
ROMTbl[0][2]: E0043000, CID:
B105F00D, PID: 001BB101 TSG
Thu Jul 29, 2021 21:13:59: Cache:
Separate I- and D-cache.
Thu Jul 29, 2021 21:13:59: I-Cache L1: 32
KiB, 512 Sets, 32 Bytes/Line, 2-Way
Thu Jul 29, 2021 21:13:59: D-Cache L1:
32 KiB, 256 Sets, 32 Bytes/Line, 4-Way
ResetTarget() start
Thu Jul 29, 2021 21:13:59: Core did not
halt on reset vector. Assuming faulty
image.
Thu Jul 29, 2021 21:13:59: Resetting and
halting core on image verification value
read.
Thu Jul 29, 2021 21:14:00: Core did not
halt after reset step 1
ResetTarget() end
Thu Jul 29, 2021 21:14:00: Hardware
reset with strategy 1 was performed
Thu Jul 29, 2021 21:14:00: Initial reset
was performed
Thu Jul 29, 2021 21:14:01: FLASH
MAC:____Configure ITCM, DTCM and
OCRAM____
Thu Jul 29, 2021 21:14:01: 3340 bytes
downloaded and verified (17.35
Kbytes/sec)
Thu Jul 29, 2021 21:14:01: Loaded
debugee: C:\Program *** (x86)\IAR
FlashIMXRT1060_FlexSPI.out
Thu Jul 29, 2021 21:14:01: Target reset
Thu Jul 29, 2021 21:14:02: Unloaded
Thu Jul 29, 2021 21:14:02: Downloaded
C:\Users\yhf\Desktop\
led_blinky\iar\flexspi_nor_debug\
iled_blinky.out to flash memory.
Thu Jul 29, 2021 21:14:02: 9792 bytes
downloaded into FLASH (2.58
Kbytes/sec)
ResetTarget() start
Thu Jul 29, 2021 21:14:02: Core did not
image.
Thu Jul 29, 2021 21:14:02: Resetting and
read.
ResetTarget() end
Thu Jul 29, 2021 21:14:02: Hardware
Thu Jul 29, 2021 21:14:03: 9792 bytes
verified (101.73 Kbytes/sec)
Thu Jul 29, 2021 21:14:03: Warning:
Thu Jul 29, 2021 21:14:03: Verify error at
address 0x70000000, target byte: 0x00,
byte in file: 0x46
address 0x70000001, target byte: 0x00,
byte in file: 0x43
address 0x70000002, target byte: 0x00,
byte in file: 0x46
address 0x70000003, target byte: 0x00,
byte in file: 0x42
address 0x70000005, target byte: 0x00,
byte in file: 0x04
address 0x70000006, target byte: 0x00,
byte in file: 0x01
address 0x70000007, target byte: 0x00,
byte in file: 0x56
address 0x7000000C, target byte: 0x00,
byte in file: 0x01
address 0x7000000D, target byte: 0x00,
byte in file: 0x03
address 0x7000000E, target byte: 0x00,
byte in file: 0x03
address 0x70000045, target byte: 0x00,
byte in file: 0x04
address 0x70000046, target byte: 0x00,
byte in file: 0x06
address 0x70000052, target byte: 0x00,
byte in file: 0x40
address 0x70000080, target byte: 0x00,
byte in file: 0xEB
address 0x70000081, target byte: 0x00,
byte in file: 0x04
address 0x70000082, target byte: 0x00,
byte in file: 0x18
address 0x70000083, target byte: 0x00,
byte in file: 0x0A
address 0x70000084, target byte: 0x00,
byte in file: 0x06
address 0x70000085, target byte: 0x00,
byte in file: 0x32
address 0x70000086, target byte: 0x00,
byte in file: 0x04
address 0x70000087, target byte: 0x00,
byte in file: 0x26
address 0x700001C1, target byte: 0x00,
byte in file: 0x01
address 0x700001C5, target byte: 0x00,
byte in file: 0x10
address 0x700001D2, target byte: 0x00,
byte in file: 0x01
address 0x70001000, target byte: 0x00,
byte in file: 0xD1
address 0x70001002, target byte: 0x00,
byte in file: 0x20
address 0x70001003, target byte: 0x00,
byte in file: 0x41
address 0x70001005, target byte: 0x00,
byte in file: 0x20
address 0x70001007, target byte: 0x00,
byte in file: 0x70
address 0x70001010, target byte: 0x00,
byte in file: 0x20
address 0x70001011, target byte: 0x00,
byte in file: 0x10
address 0x70001013, target byte: 0x00,
byte in file: 0x70
address 0x70001015, target byte: 0x00,
byte in file: 0x10
address 0x70001017, target byte: 0x00,
byte in file: 0x70
address 0x70001023, target byte: 0x00,
byte in file: 0x70
address 0x70001026, target byte: 0x00,
byte in file: 0x40
address 0x7000102C, target byte: 0x00,
byte in file: 0xFF
address 0x7000102D, target byte: 0x00,
byte in file: 0xFF
address 0x7000102E, target byte: 0x00,
byte in file: 0xFF
address 0x7000102F, target byte: 0x00,
byte in file: 0xFF
address 0x70002002, target byte: 0x00,
byte in file: 0x02
address 0x70002003, target byte: 0x00,
byte in file: 0x20
address 0x70002004, target byte: 0x00,
byte in file: 0x89
address 0x70002005, target byte: 0x00,
byte in file: 0x40
address 0x70002007, target byte: 0x00,
byte in file: 0x70
address 0x70002008, target byte: 0x00,
byte in file: 0x0B
address 0x70002009, target byte: 0x00,
byte in file: 0x3A
address 0x7000200B, target byte: 0x00,
byte in file: 0x70
address 0x7000200C, target byte: 0x00,
byte in file: 0x45
address 0x7000200D, target byte: 0x00,
byte in file: 0x41
address 0x7000200F, target byte: 0x00,
byte in file: 0x70
address 0x70002010, target byte: 0x00,
byte in file: 0x6F
address 0x70002011, target byte: 0x00,
byte in file: 0x41
address 0x70002013, target byte: 0x00,
byte in file: 0x70
address 0x70002014, target byte: 0x00,
byte in file: 0x7B
address 0x70002015, target byte: 0x00,
byte in file: 0x41
address 0x70002017, target byte: 0x00,
byte in file: 0x70
address 0x70002018, target byte: 0x00,
byte in file: 0x09
address 0x70002019, target byte: 0x00,
byte in file: 0x44
address 0x7000201B, target byte: 0x00,
byte in file: 0x70
address 0x7000202C, target byte: 0x00,
byte in file: 0x0B
address 0x7000202D, target byte: 0x00,
byte in file: 0x44
address 0x7000202F, target byte: 0x00,
byte in file: 0x70
address 0x70002030, target byte: 0x00,
byte in file: 0x0D
address 0x70002031, target byte: 0x00,
byte in file: 0x44
address 0x70002033, target byte: 0x00,
byte in file: 0x70
address 0x70002038, target byte: 0x00,
byte in file: 0x0F
address 0x70002039, target byte: 0x00,
byte in file: 0x44
address 0x7000203B, target byte: 0x00,
byte in file: 0x70
address 0x7000203C, target byte: 0x00,
byte in file: 0x03
address 0x700020***, target byte: 0x00,
byte in file: 0x***
address 0x7000203F, target byte: 0x00,
byte in file: 0x70
address 0x70002040, target byte: 0x00,
byte in file: 0x5D
address 0x70002041, target byte: 0x00,
byte in file: 0x42
address 0x70002043, target byte: 0x00,
byte in file: 0x70
address 0x70002044, target byte: 0x00,
byte in file: 0x65
address 0x70002045, target byte: 0x00,
byte in file: 0x42
address 0x70002047, target byte: 0x00,
byte in file: 0x70
address 0x70002048, target byte: 0x00,
byte in file: 0x6D
address 0x70002049, target byte: 0x00,
byte in file: 0x42
address 0x7000204B, target byte: 0x00,
byte in file: 0x70
address 0x7000204C, target byte: 0x00,
byte in file: 0x75
address 0x7000204D, target byte: 0x00,
byte in file: 0x42
address 0x7000204F, target byte: 0x00,
byte in file: 0x70
address 0x70002050, target byte: 0x00,
byte in file: 0x7D
address 0x70002051, target byte: 0x00,
byte in file: 0x42
address 0x70002053, target byte: 0x00,
byte in file: 0x70
address 0x70002054, target byte: 0x00,
byte in file: 0x85
address 0x70002055, target byte: 0x00,
byte in file: 0x42
address 0x70002057, target byte: 0x00,
byte in file: 0x70
address 0x70002058, target byte: 0x00,
byte in file: 0x8D
address 0x70002059, target byte: 0x00,
byte in file: 0x42
address 0x7000205B, target byte: 0x00,
byte in file: 0x70
address 0x7000205C, target byte: 0x00,
byte in file: 0x95
address 0x7000205D, target byte: 0x00,
byte in file: 0x42
address 0x7000205F, target byte: 0x00,
byte in file: 0x70
address 0x70002060, target byte: 0x00,
byte in file: 0x9D
address 0x70002061, target byte: 0x00,
byte in file: 0x42
address 0x70002063, target byte: 0x00,
byte in file: 0x70
address 0x70002064, target byte: 0x00,
byte in file: 0xA5
address 0x70002065, target byte: 0x00,
byte in file: 0x42
address 0x70002067, target byte: 0x00,
byte in file: 0x70
address 0x70002068, target byte: 0x00,
byte in file: 0xAD
address 0x70002069, target byte: 0x00,
byte in file: 0x42
address 0x7000206B, target byte: 0x00,
byte in file: 0x70
address 0x7000206C, target byte: 0x00,
byte in file: 0xB5
address 0x7000206D, target byte: 0x00,
byte in file: 0x42
address 0x7000206F, target byte: 0x00,
byte in file: 0x70
address 0x70002070, target byte: 0x00,
byte in file: 0xBD
address 0x70002071, target byte: 0x00,
byte in file: 0x42
address 0x70002073, target byte: 0x00,
byte in file: 0x70
address 0x70002074, target byte: 0x00,
byte in file: 0xC5
address 0x70002075, target byte: 0x00,
byte in file: 0x42
address 0x70002077, target byte: 0x00,
byte in file: 0x70
address 0x70002078, target byte: 0x00,
byte in file: 0xCD
address 0x70002079, target byte: 0x00,
byte in file: 0x42
address 0x7000207B, target byte: 0x00,
byte in file: 0x70
address 0x7000207C, target byte: 0x00,
byte in file: 0xD5
address 0x7000207D, target byte: 0x00,
byte in file: 0x42
address 0x7000207F, target byte: 0x00,
byte in file: 0x70
address 0x70002080, target byte: 0x00,
byte in file: 0xDD
address 0x70002081, target byte: 0x00,
byte in file: 0x42
address 0x70002083, target byte: 0x00,
byte in file: 0x70
address 0x70002084, target byte: 0x00,
byte in file: 0x01
address 0x70002085, target byte: 0x00,
byte in file: 0x44
address 0x70002087, target byte: 0x00,
byte in file: 0x70
address 0x70002088, target byte: 0x00,
byte in file: 0x01
address 0x70002089, target byte: 0x00,
byte in file: 0x44
address 0x7000208B, target byte: 0x00,
byte in file: 0x70
address 0x7000208C, target byte: 0x00,
byte in file: 0x01
address 0x7000208D, target byte: 0x00,
byte in file: 0x44
address 0x7000208F, target byte: 0x00,
byte in file: 0x70
address 0x70002090, target byte: 0x00,
byte in file: 0xE5
address 0x70002091, target byte: 0x00,
byte in file: 0x42
address 0x70002093, target byte: 0x00,
byte in file: 0x70
address 0x70002094, target byte: 0x00,
byte in file: 0xED
address 0x70002095, target byte: 0x00,
byte in file: 0x42
address 0x70002097, target byte: 0x00,
byte in file: 0x70
address 0x70002098, target byte: 0x00,
byte in file: 0xF5
address 0x70002099, target byte: 0x00,
byte in file: 0x42
address 0x7000209B, target byte: 0x00,
byte in file: 0x70
address 0x7000209C, target byte: 0x00,
byte in file: 0xFD
address 0x7000209D, target byte: 0x00,
byte in file: 0x42
address 0x7000209F, target byte: 0x00,
byte in file: 0x70
address 0x700020A0, target byte: 0x00,
byte in file: 0x05
address 0x700020A1, target byte: 0x00,
byte in file: 0x43
address 0x700020A3, target byte: 0x00,
byte in file: 0x70
address 0x700020A4, target byte: 0x00,
byte in file: 0x0D
address 0x700020A5, target byte: 0x00,
byte in file: 0x43
address 0x700020A7, target byte: 0x00,
byte in file: 0x70
address 0x700020A8, target byte: 0x00,
byte in file: 0x15
address 0x700020A9, target byte: 0x00,
byte in file: 0x43
address 0x700020AB, target byte: 0x00,
byte in file: 0x70
address 0x700020AC, target byte: 0x00,
byte in file: 0x1D
address 0x700020AD, target byte: 0x00,
byte in file: 0x43
address 0x700020AF, target byte: 0x00,
byte in file: 0x70
address 0x700020B0, target byte: 0x00,
byte in file: 0x25
address 0x700020B1, target byte: 0x00,
byte in file: 0x43
address 0x700020B3, target byte: 0x00,
byte in file: 0x70
address 0x700020B4, target byte: 0x00,
byte in file: 0x2D
address 0x700020B5, target byte: 0x00,
byte in file: 0x43
address 0x700020B7, target byte: 0x00,
byte in file: 0x70
address 0x700020B8, target byte: 0x00,
byte in file: 0x35
address 0x700020B9, target byte: 0x00,
byte in file: 0x43
address 0x700020BB, target byte: 0x00,
byte in file: 0x70
address 0x700020BC, target byte: 0x00,
byte in file: 0x***
address 0x700020BD, target byte: 0x00,
byte in file: 0x43
address 0x700020BF, target byte: 0x00,
byte in file: 0x70
address 0x700020C0, target byte: 0x00,
byte in file: 0x45
address 0x700020C1, target byte: 0x00,
byte in file: 0x43
address 0x700020C3, target byte: 0x00,
byte in file: 0x70
address 0x700020C4, target byte: 0x00,
byte in file: 0x4D
address 0x700020C5, target byte: 0x00,
byte in file: 0x43
address 0x700020C7, target byte: 0x00,
byte in file: 0x70
address 0x700020C8, target byte: 0x00,
byte in file: 0x55
address 0x700020C9, target byte: 0x00,
byte in file: 0x43
address 0x700020CB, target byte: 0x00,
byte in file: 0x70
address 0x700020CC, target byte: 0x00,
byte in file: 0x5D
address 0x700020CD, target byte: 0x00,
byte in file: 0x43
address 0x700020CF, target byte: 0x00,
byte in file: 0x70
address 0x700020D0, target byte: 0x00,
byte in file: 0x65
address 0x700020D1, target byte: 0x00,
byte in file: 0x43
address 0x700020D3, target byte: 0x00,
byte in file: 0x70
address 0x700020D4, target byte: 0x00,
byte in file: 0x6D
address 0x700020D5, target byte: 0x00,
byte in file: 0x43
address 0x700020D7, target byte: 0x00,
byte in file: 0x70
address 0x700020D8, target byte: 0x00,
byte in file: 0x01
address 0x700020D9, target byte: 0x00,
byte in file: 0x44
address 0x700020DB, target byte: 0x00,
byte in file: 0x70
address 0x700020DC, target byte: 0x00,
byte in file: 0x01
address 0x700020DD, target byte: 0x00,
byte in file: 0x44
address 0x700020DF, target byte: 0x00,
byte in file: 0x70
address 0x700020E0, target byte: 0x00,
byte in file: 0x01
address 0x700020E1, target byte: 0x00,
byte in file: 0x44
address 0x700020E3, target byte: 0x00,
byte in file: 0x70
address 0x700020E4, target byte: 0x00,
byte in file: 0x01
address 0x700020E5, target byte: 0x00,
byte in file: 0x44
address 0x700020E7, target byte: 0x00,
byte in file: 0x70
address 0x700020E8, target byte: 0x00,
byte in file: 0x01
address 0x700020E9, target byte: 0x00,
byte in file: 0x44
address 0x700020EB, target byte: 0x00,
byte in file: 0x70
Thu Jul 29, 2021 21:14:03: Warning: Too
many verify errors, only the first 200 are
displayed
Thu Jul 29, 2021 21:14:06: Warning:
There were warnings during download,
see Log Window
Thu Jul 29, 2021 21:14:06: Loaded
debugee: C:\Users\yhf\Desktop\
iled_blinky.out
ResetTarget() start
Thu Jul 29, 2021 21:14:06: Core did not
image.
Thu Jul 29, 2021 21:14:06: Resetting and
read.
ResetTarget() end
Thu Jul 29, 2021 21:14:06: Software
reset was performed
Thu Jul 29, 2021 21:14:06: Target reset
Thu Jul 29, 2021 21:14:06: There was 1
warning during the initialization of the
debugging session.
Could not start CPU core. (ErrorCode:
-1)
Thu Jul 29, 2021 21:14:13: Failed to
clear breakpoint: Target busy.
Thu Jul 29, 2021 21:14:13: Code still
contains old breakpoints
Thu Jul 29, 2021 21:14:13: IAR
armproc.dll)
