查看: 4216|回复: 1
[求助] MKV31F256HL12单片机串口2配置问题
发表于 2021-8-4 15:54:04 | 显示全部楼层 |阅读模式
MKV31F256HL12单片机串口2配置问题,pin_mux.c中对串口2引脚配置,SIM->SOPT5 = ((SIM->SOPT5 &                   /* Mask bits to zero which are setting */
                   (~(SIM_SOPT5_UART2RXSRC_MASK )))
                  /* UART 2 transmit data source select: UART2_TX pin. */
                  |SIM_SOPT5_UART2TXSRC(SOPT5_UART2TXSRC_UART_TX));
报错,MKV31F25612.中没有相关uart2的宏定义。
楼主你好 建议你看参考手册KV31P100M120SF8RM的“12.2.5 System Options Register 5 (SIM_SOPT5)”章节,这个寄存器没UART2部分(UART0 and UART1 receive/transmit source selection/configuration) [attach]50033 ...
发表于 2021-8-4 16:56:17 | 显示全部楼层
楼主你好
UART0 and UART1 receive transmit source selection configuration.jpg System Options Register 5 (SIM_SOPT5).jpg
GMT+8, 2026-4-9 03:21 , Processed in 0.097692 second(s), 26 queries , Redis On.
