查看: 3752|回复: 1
[S32] S32K148 CAN周期发送,CAN卡却接收到远程帧
发表于 2021-8-26 16:53:30 | 显示全部楼层 |阅读模式
void CAN0_init(void)
{          CAN_Init(&can_pal1_instance, &can_pal1_Config0);                  //接收BUFFER配置
can_buff_config_t Rx_buffCfg =                  {
.enableFD = false,
.enableBRS = false,
.fdPadding = 0U,
.idType = CAN_MSG_ID_STD,
.isRemote = false                  };
//发送BUFFER配置
can_buff_config_t Tx_buffCfg =                  {                            .enableFD = false,                            .enableBRS = false,                            .fdPadding = 0U,                            .idType = CAN_MSG_ID_STD,                            .isRemote = false                  };                  CAN_ConfigRxBuff(&can_pal1_instance, CAN0_RevMailBox, &Rx_buffCfg, CAN0_RxFilter);
CAN_ConfigTxBuff(&can_pal1_instance, CAN0_TxMailBox, &Tx_buffCfg);                  //掩码设置为0 就接收全部Msg_ID的报文
CAN_SetRxFilter(&can_pal1_instance, CAN_MSG_ID_STD, CAN0_RevMailBox, 0);                  //配置接收中断
CAN_InstallEventCallback(&can_pal1_instance, &CAN0_Callback_Func, (void*)0);                  //CAN接收配置
CAN_Receive(&can_pal1_instance, CAN0_RevMailBox, &CAN0_RecMsg);
主循环中
while(1)
                OSIF_TimeDelay(1);
                //CAN0_PeriodSend(TxMsg, 500);
                 if( (CAN0_MissionPeriodCounter*100) - 500 == 0)
                                          //CAN_SendBlocking(&can_pal1_instance, CAN0_TxMailBox, &TxMsg, 1);
                                          CAN_Send(&can_pal1_instance, CAN0_TxMailBox, &TxMsg);
                                          CAN0_MissionPeriodCounter = 0;
什么原因导致啊
我知道答案 目前已有1人回答
    无聊
    2021-6-23 10:13
    发表于 2021-9-3 09:04:47 | 显示全部楼层
    应该是配置的问题吧。关注结构体的成员地址对应的寄存器。
    GMT+8, 2025-10-29 21:22 , Processed in 0.084298 second(s), 21 queries , MemCache On.
