在线时间31 小时
UID3736717
注册时间2021-5-12
NXP金币104
TA的每日心情 | 无聊 2022-12-14 09:08 |
签到天数: 41 天 连续签到: 1 天 [LV.5]常住居民I
- 1717
- 2025-8-14
发表于 2021-9-8 12:34:18
显示全部楼层
特征
AEC Q100 grade 2 compliant for automotive applications
Single-chip LCD controller and driver
Extended operating temperature range from -40 °C to +105 °C
2-line display of up to 20 characters plus 200 icons or 1-line display of up to 40 characters plus 200 icons
5 x 7 character format plus cursor and user-defined symbols
Icon blink function
On-chip:
Programmable 4, 3, or 2 times voltage multiplier generating LCD supply voltage (external supply also possible)
Integrated temperature sensor with temperature readout
Selectable linear temperature compensation of on-chip generated VLCD
Generation of intermediate LCD bias voltages
Oscillator requires no external components (external clock also possible)
Readout of RAM and all registers possible
Diagnostic features:
Checksum on I²C and SPI bus
Frame frequency: programmable from 45 Hz to 360 Hz
Display Data RAM (DDRAM): 80 characters
Character Generator ROM (CGROM): 240, 224, or 208 characters (5 x 8) depending on the selected RAM size
Character Generator RAM (CGRAM): 16, 32, or 48 characters (5 x 8); ICON-RAM: 400 bit
Two-line I²C-bus interface or four-line SPI bus selectable through input pin
Inversion modes
n-line (n = 1 to 7) inversion
Frame inversion
Large supply voltage range: VDD1: 2.5 V to 5.5 V (chip can be driven with battery cells)
Analog supply voltage VDD2: 2.5 V to 5.5 V
LCD supply voltage VLCD: 4 V to 16 V
Direct mode to save current consumption for icon mode and multiplex drive mode 1:9 (depending on VDD2 value and LCD properties)
Power-down mode pin
Very low current consumption (20 μA to 200 μA):
Power-down mode: < 2 μA
Icon mode: < 25 μA
Icon mode is used to save current. When only icons are displayed, a much lower LCD operating voltage can be used and the switching frequency of the LCD driver outputs is reduced. In this case, for many applications it is possible to use VDD as LCD supply voltage
Target Applications
Automotive
Instrument clusters
Climate control display
Car entertainment
Car radio
Industrial
Medical and health care
Measuring equipment
Machine control systems
Information boards
General-purpose display modules
Consumer
White goods
Home entertainment |
