请选择 进入手机版 | 继续访问电脑版
查看: 4037|回复: 3
[求助] keazn64 读写完EEPROM 串口发送数据 进入 HardFault
发表于 2021-9-10 09:55:09 | 显示全部楼层 |阅读模式
int main(void)
      uint8_t eBuf[EEPROM_SIZE];
      Bsp_Init();
      GetChipUniqueID();
      memset(eBuf,0x5A,sizeof(eBuf));
      mFLASH_Init(16000000);
      mEEPROM_EraseOneSector(EEPROM_SIZE);
      mEEPROM_Program(EEPROM_START_ADDRESS,&eBuf[0],EEPROM_SIZE);
      memset(eBuf,0x00,sizeof(eBuf));
      mEEPROM_Read(0,&eBuf[0],EEPROM_SIZE);
        printf("Usart0 Send Hello kea ! \r\n");               //程序执行到这里 死机  putchar 如下
        PUTCHAR_PROTOTYPE
            USART0_SendData((uint8_t) ch);            //串口发送函数如下
           void USART0_SendData(uint8_t dat)
                while (!(UART0->S1 & 0x80));
                UART0->D = (uint8_t) dat;
           return ch;
        while(1)
观察 串口调试助手  能接收到两个字节 “Us” 后程序就 进入 “HardFault” 中断。
EEPROM  参照官方 demo  及“https://www.nxpic.org.cn/module/ ... xtra=page%3D&page=1” 此帖。
楼主你好 请问如果不操作EEPROM,单独调用printf("Usart0 Send Hello kea ! \r\n"); 是否会触发HardFault?
 楼主| 发表于 2021-9-10 10:20:02 | 显示全部楼层
串口配置
void USART0_Init(void)
       uint32_t baudTemph,baudTempl;
        SIM->SCGC         |= 0x00100000;                //Enable bus clock in UART0
        SIM->PINSEL      |= 0x00000080;         //=1 UART0_RX and TX are mapped on PTA2 and PTA3.
        UART0->BDH         &= ~0x20;                //One stop
        //UART baud rate equals BUSCLK/(16×BR).
        baudTemph   = BUSCLOCK;
        baudTemph >>= 4;
        baudTemph  /= 9600;
        baudTempl   = baudTemph;
        baudTemph  &= 0x1FFF;
        baudTemph >>= 8;
        UART0->BDH &= 0xE0;                            //clear baud_h
        UART0->BDH |= (uint8_t)  baudTemph;
        UART0->BDL  = (uint8_t) (baudTempl & 0x00FF);
        UART0->C1   = 0;                                  /* No parity enable,8 bit format*/
        UART0->C2  |= 0x08;                             /* Enable Transmitter*/
        UART0->C2  |= 0x04;                             /* Enable Receiver   */
        UART0->C2  |= 0x20;                             /* Enable Receiver interrupts*/
        NVIC_ClearPendingIRQ(UART0_IRQn);              /* Clear any Pending IRQ for all UART0_IRQn  (#23) */
        NVIC_EnableIRQ(UART0_IRQn);                    /* Set Enable IRQ for UART0 */
        NVIC_SetPriority(UART0_IRQn,0);                /* Set Priority for UART0 */
发表于 2021-9-14 18:37:53 | 显示全部楼层
楼主你好
 楼主| 发表于 2021-9-15 07:55:49 | 显示全部楼层
小恩GG 发表于 2021-9-14 18:37
楼主你好
请问如果不操作EEPROM,单独调用printf("Usart0 Send Hello kea ! \r\n"); 是否会触发HardFault? ...
单独printf 没有问题,是堆栈溢出了,操作eeprom 开了一个 256Byte的数组,   修改启动文件堆栈的空间好了。  谢谢
GMT+8, 2025-11-18 03:45 , Processed in 0.101502 second(s), 24 queries , MemCache On.
