查看: 3462|回复: 1
[求助] imx6 烧录异常
    发表于 2021-10-8 17:27:06 | 显示全部楼层 |阅读模式
    按照某开发板做的原理图,出现问题如下: 1 无法使用OTG下载,BOOT0/BOOT1已经按照正常的设置好了。USB VBUS有5V,ID脚为3.3V,layout,DMDP数据线为90欧差分走线。但是连接OTG时出现无法识别,最开始 有成功过一下,后来一直都是无法识别状态,不清楚是什么问题。该USB口作为设备时接U盘可以识别,读取正常。
    2 SD卡烧录异常。SD卡可以正常读写,但是SD卡烧录的时候。到后面一直提示如下错误。查询发现有/dev/ubi_ctrl文件,但是 没有/dev/ubi0,不清楚哪里出现问题。
    root@ATK-IMX6U:~# [   12.927526] random: nonblocking pool is initialized
    Erasing 128 Kibyte @ 0 -- 100 % complete
    Erasing 128 Kibyte @ e0000 -- 100 % complete
    正在擦除设备树分区...
    正在烧写设备树...
    正在擦除内核分区...
    Erasing 128 Kibyte @ 7e0000 -- 100 % complete
    正在烧写内核...
    正在擦除文件系统分区,请稍候...
    Erasing 128 Kibyte @ 7d80000 -[   19.575179] ICM20608 ID = 0X0
    Erasing 128 Kibyte @ 1f140000 -- 99 % complete flash_erase: Skipping bad block at 1f160000
    flash_erase: Skipping bad block at 1f180000
    flash_erase: Skipping bad block at 1f1a0000
    flash_erase: Skipping bad block at 1f1c0000
    Erasing 128 Kibyte @ 1f1c0000 -- 100 % complete
    ubiformat: mtd5 (nand), size 522059776 bytes (497.9 MiB), 3983 eraseblocks of 131072 bytes (128.0 KiB), min. I/O size 2048 bytes
    libscan: scanning eraseblock 3982 -- 100 % complete
    ubiformat: 3979 eraseblocks are supposedly empty
    ubiformat: 4 bad eraseblocks found, numbers: 3979, 3980, 3981, 3982
    ubiformat: formatting eraseblock 3982 -- 100 % complete
    libubi: error!: cannot open "/dev/ubi_ctrl"
            error 19 (No such device)
    ubiattach: error!: cannot attach mtd5
    libubi: error!: cannot get information about "/dev/ubi0"
            error 2 (No such file or directory)
    ubimkvol: error!: error while probing "/dev/ubi0"
              error 2 (No su[   69.804204] UBIFS error (pid: 761): cannot open "ubi0:rootfs", error -19ch file or directory)
    我知道答案 目前已有1人回答
    发表于 2021-11-1 14:21:04 | 显示全部楼层
    这种情况一般都是layout问题,不会是软件/芯片的问题。
    GMT+8, 2025-10-27 00:12 , Processed in 0.082258 second(s), 22 queries , MemCache On.
