查看: 8520|回复: 0
[其他] 裕太微百兆、千兆PHY芯片,管脚兼容瑞昱管脚
发表于 2021-10-30 16:35:34 | 显示全部楼层 |阅读模式
裕太微百兆、千兆、单口、多口PHY,管脚兼容瑞昱管脚,有需求的老板可以联系。13510937178黄生,微信同号
裕太微型号等级速率接口IO 供给封裝工作温度范围管脚兼容(不用改版,软件微调)競爭(功能可以替代,需要改版)NOTE
YT8010A车规100 MbpsRGMII/MII/RMII3.3/2.5VQFN 36 6x6mm,-40 °C to +125 °CBCM89811RTL9000/88Q1010/(
TI)DP83TC811R/TJA1101
100BaseT1 AECQ-100 Grade 1,
YT8510C消费10/100 Mbps1RGMII/MII/RMII3.3/2.5VQFN 40 6x6mm, 0 °C to +70 °CBCM54811/RTL8201FG距离增强型
YT8510H工业10/100 Mbps1RGMII/MII/RMII3.3/2.5VQFN 40 6x6mm,-40 °C to +85 °CBCM54811距离增强型
YT8512C消费10/100 Mbps1MII/RMII3.3/2.5VQFN 32 5x5mm, 0 °C to +70 °CRTL8201F(九阳)IP101/(和芯润德)SR8201
YT8512H工业10/100 Mbps1MII/RMII3.3/2.5VQFN 32 5x5mm,-40 °C to +85 °CRTL8201FI(TI)DP83848/(微芯)LAN8720
/(微芯)KSZ8041/(英特尔)LXT971
SZ18201消费10/100 Mbps1MII/RMII3.3/2.5VQFN 32 5x5mm, 0 °C to +70 °CRTL8201FIP1001/SR8201
YT8511C消费10/100/1000 Mbps1RGMII3.3/2.5VQFN 40 5x5mm, 0 °C to +70 °CAR8035RTL8211F/IP1001
YT8511H工业10/100/1000 Mbps1RGMII3.3/2.5VQFN 40 5x5mm,-40 °C to +85 °CAR8035(ADI)ADIN1300/KSZ8061
YT8521SC消费10/100/1000 Mbps1RGMII/SGMII3.3/2.5/1.8VQFN 48 6x6mm, 0 °C to +70 °CRTL8211FS-CG(美满)88E1512
YT8521SH工业10/100/1000 Mbps1RGMII/SGMII3.3/2.5/1.8VQFN 48 6x6mm,-40 °C to +85 °CRTL8211FS(I)-CG88E1512
YT8618C消费10/100/1000 Mbps8QSGMIISerDesLQFP 128 14x20mm,-40 °C to +85 °CRTL8218B/D88E1680/VSC8658
YT8618H工业10/100/1000 Mbps8QSGMIISerDesLQFP 128 14x20mm,-40 °C to +85 °CRTL8218B/D88E1680/VSC8658
YT8614C消费10/100/1000 Mbps4QSGMII/SGMIISerDesLQFP 176 20x20mm,-40 °C to +85 °CRTL8214FC
YT8614H工业10/100/1000 Mbps4QSGMII/SGMIISerDesLQFP 176 20x20mm,-40 °C to +85 °CRTL8214FC
YT8614QC消费10/100/1000 Mbps 光4QSGMIISerDesQFN88 10x10mm, 0 °C to +70 °CRTL8214QF
YT8531SC消费10/100/1000 Mbps1RGMII/SGMII3.3/2.5/1.8VQFN 48 6x6mm, 0 °C to +70 °CRTL8211FS-CG88E151X系列
YT8531SH工业10/100/1000 Mbps1RGMII/SGMII3.3/2.5/1.8VQFN 48 6x6mm, -40 °C to +85 °CRTL8211FS(i)-CG88E151X系列
YT8531C消费10/100/1000 Mbps1RGMII3.3/2.5/1.8VQFN 40 5x5mm, 0 °C to +70 °CRTL8211F-CGVDDL SWR
YT8531H工业10/100/1000 Mbps1RGMII3.3/2.5/1.8VQFN 40 5x5mm,-40 °C to +85 °CRTL8211FI-CGVDDL SWR
YT8531DC消费10/100/1000 Mbps1RGMII3.3/2.5/1.8VQFN 40 5x5mm, 0 °C to +70 °CRTL8211FD-CGVDDL LDO
YT8531DH工业10/100/1000 Mbps1RGMII3.3/2.5/1.8VQFN 40 5x5mm,-40 °C to +85 °CRTL8211FDI-CGVDDL LDO
YT8531P消费10/100/1000 Mbps1RGMII3.3/2.5/1.8VQFN 40 5x5mm, 0 °C to +70 °CRTL8211FPVDDL external power
我知道答案 目前已有0人回答
GMT+8, 2025-10-5 08:55 , Processed in 0.089027 second(s), 21 queries , MemCache On.
