查看: 3756|回复: 1
[求助] IMX8qxp 编译安卓报错,求解
    2021-12-8 10:41
    发表于 2021-11-22 16:02:42 | 显示全部楼层 |阅读模式
    环境:
        Ubuntu 18.04
        固件版本:imx-automotive-11.0.0_2.1.0
        NXP 官网下载的imx-automotive-11.0.0_2.1.0,参考官网的 Android_User's_Guide.pdf
        前期还算顺利吧,执行
       lunch mek_8q_car-userdebug
    ./imx-make.sh bootloader -j4
    ./imx-make.sh -j4 2>&1 | tee build-log.txt
    后开始编译,但中间报错
    FAILED: out/soong/build.ninja
    out/soong/.bootstrap/bin/soong_build -t -l out/.module_paths/Android.bp.list -b out/soong -n out -d out/soong/build.ninja.d -globFile out/soong/.bootstrap/build-globs.ninja -o out/soong/build.ninja Android.bp
    error: vendor/nxp/imx_android_mm/codec2/video_dec/common/Android.bp:45:1: "lib_imx_c2_videodec" depends on undefined module "libwvtrustyclient"
    15:40:39 soong bootstrap failed with: exit status 1
    这个问题该怎么解决?
    暂时将vendor/nxp/imx_android_mm/codec2/video_dec/common/Android.bp 中的
        static_libs: [
            "libwvtrustyclient",
            "libtrusty",
            "libtrustystorageinterface",
            "libtrustystorage",
    中的  "libwvtrustyclient",删除,试着编译试试,但不知道会不会有问题,也不确定会有什么影响
    基本上这种包的编译出错就是下载的时候某个文件出错了,试着删除重新下源码
    发表于 2021-11-23 16:30:17 | 显示全部楼层
    GMT+8, 2026-4-5 03:50 , Processed in 0.087945 second(s), 24 queries , Redis On.
