查看: 3837|回复: 3
[求助] mkv31F256 pwm输出配置问题
发表于 2021-11-23 16:49:10 | 显示全部楼层 |阅读模式
系统时钟为120MHz,PWM中心对齐,计划配置PWM周期10us,结果显示20US。程序如下
uint8_t regtemp;
         SIM->SCGC6  |= SIM_SCGC6_FTM0_MASK ;       /* ´ò¿ªFTMʱÖÓ    */
//    SIM->SOPT2  |= SIM_SOPT2_PLLFLLSEL_MASK | SIM_SOPT2_TPMSRC(1);
//         SIM->SOPT2  |= SIM_SOPT2_PLLFLLSEL_MASK ;
        FTM0->MODE |=0x05;
//        FTM0->CONF=0XC0;
//        FTM0->FMS=0X00;
//        FTM0->MOD  = 600;
        FTM0_CONF=0xC0; //set up BDM in 11
FTM0_FMS=0x00; //clear the WPEN so that WPDIS is set in FTM0_MODE register
FTM0_MOD=600;
FTM0->CONTROLS[0].CnSC =0x28; //High_Low_High for center-alignment
FTM0_C1SC=0x28;
FTM0_C2SC=0x28;
FTM0_C3SC=0x28;
FTM0_COMBINE|=0x2020; //enable update the FTM_C0V/FTM0_C1V register
FTM0_COMBINE|=0x0202; //complementary mode for CH0&CH1 of FTM0
FTM0_COMBINE|=0x1010; // dead timer insertion enabled in complementary mode //for CH0&CH1 of
FTM0_DEADTIME=0x00; //dead time is 0 system clock cycles
FTM0_C1V=100;
FTM0_C0V=100;
FTM0_C2V=100;
FTM0_C3V=100;
FTM0_CNTIN=0x00;
FTM0_SC=0x68; //do not start FTM0
求大神指点
 楼主| 发表于 2021-11-23 16:53:14 | 显示全部楼层
另外请问该款芯片的PWM时钟,最高可以达到120MHz吗
发表于 2021-11-25 11:33:53 | 显示全部楼层
the period is determined by 2 × (MOD − CNTIN)
如果你的主频配置成core clock=120MHz, 那么FTM最高频率的时钟源选择Bus Clock=60MHz.
  • 签到天数: 4 天
    发表于 2021-11-26 19:08:14 | 显示全部楼层
    可以看範例的simple_pwm
    GMT+8, 2025-10-27 05:21 , Processed in 0.110493 second(s), 25 queries , MemCache On.
