查看: 3606|回复: 3
[求助] Android5.1 imx6怎么编译mfgtools镜像
    发表于 2021-12-10 15:21:20 | 显示全部楼层 |阅读模式
    各位大佬请教一下,我用的是imx6q这款板子,因为我版本目前更换了emmc而新的emmc是emmc5.1的,所以需要更改内核,在烧录的时候发现烧录失败,怀疑也需要更新\mfgtools\Profiles\Linux\OS Firmware\firmware这个目录下的镜像。在uboot和kernel目录下未发现有关mfg_config配置文件,这种情况下我该怎么编译呢。
    mfgtools已经不提供支持了,新的下载工具是uuu
    1112112@aaa
     楼主| 发表于 2021-12-10 16:23:10 | 显示全部楼层
    目前用自己编译出来的zimage替换firmware下的zimage,下载会一卡在no deviece,
    log会卡在这里:
    1. U-Boot 2015.04-14409-g6cf684a-dirty (Nov 01 2016 - 16:01:59)
    2. CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
    3. CPU:   Temperature 34 C
    4. Reset cause: POR
    5. Board: MX6-SabreSD
    6. I2C:   ready
    7. DRAM:  2 GiB
    8. MMC:   FSL_SDHC: 0, FSL_SDHC: 1
    9. *** Warning - bad CRC, using default environment
    10. No panel detected: default to Hannstar-XGA
    11. Display: Hannstar-XGA (1024x768)
    12. In:    serial
    13. Out:   serial
    14. Err:   serial
    15. switch to partitions #0, OK
    16. mmc1(part 0) is current device
    17. Net:   FEC [PRIME]
    18. Error: FEC address not set.
    19. Boot from USB for mfgtools
    20. Use default environment for                              mfgtools
    21. Run bootcmd_mfg: run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};
    22. Hit any key to stop autoboot:  0
    23. Kernel image @ 0x12000000 [ 0x000000 - 0x572ca8 ]
    24. ## Loading init Ramdisk from Legacy Image at 12c00000 ...
    25.    Image Name:   fsl-image-mfgtool-initramfs-imx6
    26.    Image Type:   ARM Linux RAMDisk Image (gzip compressed)
    27.    Data Size:    7487205 Bytes = 7.1 MiB
    28.    Load Address: 00000000
    29.    Entry Point:  00000000
    30.    Verifying Checksum ... OK
    31. ## Flattened Device Tree blob at 18000000
    32.    Booting using the fdt blob at 0x18000000
    33.    Using Device Tree in place at 18000000, end 1800db57
    34. Starting kernel ...
    这是怎么回事呢
    1112112@aaa
     楼主| 发表于 2021-12-10 20:30:44 | 显示全部楼层
    替换uboot时候  直接mfgtool打开失败 errno code -4  版主有没有imx6Quad适配高版本的emmc mfgtool镜像
    1112112@aaa
    发表于 2021-12-13 13:42:24 | 显示全部楼层
    GMT+8, 2026-4-4 01:55 , Processed in 0.082897 second(s), 26 queries , Redis On.
