查看: 3052|回复: 1
[求助] IMX6DP芯片烧录问题
发表于 2022-3-24 12:14:10 | 显示全部楼层 |阅读模式
芯片是imx6dplus
烧录工具用mfgtool
问题:烧录uboot、kernel都成功了,最后烧录文件系统卡住了,如图
mfg报错
mfg报错
另外串口log也是在解压处卡住,截取最后部分log如下
etc/init.d/rcS
etc/inittab
lib/
lib/libnss_dns.so.2
lib/libnss_files-2.19-2014.08-1-git.so
lib/libnss_nisplus.so.2
lib/libsupc++.a
lib/libstdc++.so.6.0.20
g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
重复烧录都是卡在这里,不知道怎么解决,求帮助,谢谢
我知道答案 目前已有1人回答
 楼主| 发表于 2022-3-24 13:11:04 | 显示全部楼层
在重复操作中还出现了一次这个log,好像是cpu1崩溃了
  1. Device         Boot   Start     End Sectors  Size Id Type
  2. /dev/mmcblk3p1        20480 1044479 1024000  500M  c W95 FAT32 (LBA)
  3. /dev/mmcblk3p2      1228800 7733247 6504448  3.1G 83 Linux
  4. The partition table has been altered.
  5. Calling ioctl() to re-read partition table.
  6. Syncing disks.
  7. UTP: sending Success to kernel for command $ sh mksdcard.sh /dev/mmcblk3.
  8. utp_poll: pass returned.
  9. UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk3 bs=1k seek=384 conv=fsync count=129'
  10. UTP: executing "dd if=/dev/zero of=/dev/mmcblk3 bs=1k seek=384 conv=fsync count=129"
  11. mmc3: Timeout waiting for hardware interrupt.
  12. mmcblk3: error -110 transferring data, sector 768, nr 264, cmd response 0x900, card status 0xc00
  13. blk_update_request: I/O error, dev mmcblk3, sector 768
  14. Buffer I/O error on dev mmcblk3, logical block 96, lost async page write
  15. blk_update_request: I/O error, dev mmcblk3, sector 776
  16. Buffer I/O error on dev mmcblk3, logical block 97, lost async page write
  17. blk_update_request: I/O error, dev mmcblk3, sector 784
  18. Buffer I/O error on dev mmcblk3, logical block 98, lost async page write
  19. blk_update_request: I/O error, dev mmcblk3, sector 792
  20. Buffer I/O error on dev mmcblk3, logical block 99, lost async page write
  21. blk_update_request: I/O error, dev mmcblk3, sector 800
  22. Buffer I/O error on dev mmcblk3, logical block 100, lost async page write
  23. blk_update_request: I/O error, dev mmcblk3, sector 808
  24. Buffer I/O error on dev mmcblk3, logical block 101, lost async page write
  25. blk_update_request: I/O error, dev mmcblk3, sector 816
  26. Buffer I/O error on dev mmcblk3, logical block 102, lost async page write
  27. blk_update_request: I/O error, dev mmcblk3, sector 824
  28. Buffer I/O error on dev mmcblk3, logical block 103, lost async page write
  29. blk_update_request: I/O error, dev mmcblk3, sector 832
  30. Buffer I/O error on dev mmcblk3, logical block 104, lost async page write
  31. blk_update_request: I/O error, dev mmcblk3, sector 840
  32. Buffer I/O error on dev mmcblk3, logical block 105, lost async page write
  33. dd: ------------[ cut here ]------------
  34. fsync failed for '/dev/mmcblk3': WARNING: CPU: 1 PID: 74 at /home/bamboo/build/4.1.X-2.0.0_ga/fsl-imx-x11/temp_build_dir/build_fsl-imx-x11/tmp/work-shared/imx6qdlsolo/kernel-mfgtool-source/fs/block_dev.c:56 __blkdev_put+0xc4/0x1e0()
  35. Input/output error
  36. Modules linked in:
  37. CPU: 1 PID: 74 Comm: dd Tainted: G        W       4.1.15+ #1
  38. Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
  39. [<80015ed8>] (unwind_backtrace) from [<80012768>] (show_stack+0x10/0x14)
  40. [<80012768>] (show_stack) from [<806913f0>] (dump_stack+0x80/0xc8)
  41. [<806913f0>] (dump_stack) from [<80036f7c>] (warn_slowpath_common+0x74/0xb0)
  42. [<80036f7c>] (warn_slowpath_common) from [<80037054>] (warn_slowpath_null+0x1c/0x24)
  43. [<80037054>] (warn_slowpath_null) from [<8011bb88>] (__blkdev_put+0xc4/0x1e0)
  44. [<8011bb88>] (__blkdev_put) from [<8011c154>] (blkdev_close+0x18/0x20)
  45. [<8011c154>] (blkdev_close) from [<800ecf18>] (__fput+0x80/0x1c8)
  46. [<800ecf18>] (__fput) from [<8004df2c>] (task_work_run+0xb4/0xe8)
  47. [<8004df2c>] (task_work_run) from [<80012388>] (do_work_pending+0x7c/0xa4)
  48. [<80012388>] (do_work_pending) from [<8000f50c>] (work_pending+0xc/0x20)
  49. ---[ end trace cb88537fdc8fa202 ]---
  50. 129+0 records in
  51. 129+0 records out
  52. 132096 bytes (132 kB, 129 KiB) copied, 10.268 s, 12.9 kB/s
  53. UTP: sending Non-success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk3 bs=1k seek=384 conv=fsync count=129.
  54. utp_poll: exit with status 256
GMT+8, 2026-4-12 00:32 , Processed in 0.092783 second(s), 25 queries , Redis On.
