查看: 3905|回复: 1
[CodeWarrior] ls1046A的中断驱动没反应
    发表于 2022-4-14 14:24:58 | 显示全部楼层 |阅读模式
    我现在想使用中断IRQ09,已经在RCW中复用了相关引脚为IRQ09(IRQ_EXT——>000;IRQ_BASE——>0);
    设备树配置如下: 微信图片_20220414142536.png
    驱动:
    外部给这个引脚高电平没什么反应,可能是什么原因?
    参照lx2160的步骤 做参考: The usage of external IRQ is same as other IP's irq, normally you need: 1) enable IRQ pin function in RCW, bit 402:410 2) Add interrupt related description in dts node 3) map ...
    啊啊啊
    发表于 2022-4-22 14:16:31 | 显示全部楼层
    参照lx2160的步骤 做参考:
    3) map hwirq to Linux irq
    4) request irq in device driver.
    For LX2ARDB, you can take 10G (DPMAC3) copper PHY interrupt as an example, the PHY of 10G Copper port (DPMAC3) connected with External IRQ3,
    1) RCW
    IRQ3 is enabled by default in RCW from LSDK
    2) dts.
    &emdio1 {
    aquantia_phy1: ethernet-phy@4 {
    interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
    reg = <0x4>;
    Please be aware that the irq in dts is calculated as : irq = hwirq - 32. For this example, the PHY of 10G Copper port (DPMAC3) connected with External IRQ3,
    According to chapter <interrupt assignment > of LX2RM, the hwirq num of IRQ3 is 34, so in dts file it should be 34 - 32 = 2.
    3) map hwirq to Linux IRQ
    You can reference the following code to map hwirq to a Linux IRQ num : xgmac_mdio_probe->of_mdiobus_register->of_mdiobus_register_phy->fwnode_mdiobus_phy_device_register->fwnode_irq_get->of_irq_get
    4) request irq in driver
    void phy_request_interrupt(struct phy_device *phydev)
    int err;
    err = request_threaded_irq(phydev->irq, NULL, phy_interrupt,
    IRQF_ONESHOT | IRQF_SHARED,
    phydev_name(phydev), phydev);
    5) testing log
    # cat /porc/interrupt
    122: 6 0 0 0 GICv3 34 Level 0x0000000008b96000:04
    123: 6 0 0 0 GICv3 35 Level 0x0000000008b96000:05
    GMT+8, 2026-4-9 01:13 , Processed in 0.104241 second(s), 26 queries , Redis On.
