查看: 2757|回复: 2
[求助] 1768 485模式问题
发表于 2022-5-25 08:01:16 | 显示全部楼层 |阅读模式
为了跑modbus 在设计硬件时把uart2设计成了485,想使用官方的485例程,我的硬件是这样设计的txd,rxd ,再加一个enable-pin,觉得就是下面的485sel
下面是官方的设置那位能解释一下含义吗
485的应用一般会需要地址,存在cpu或flash里面,接受数据时比对,
/* RS485 mode definition. */
#define RS485_NMMEN                (0x1<<0)
#define RS485_RXDIS                (0x1<<1)
#define RS485_AADEN                (0x1<<2)
#define RS485_SEL                (0x1<<3)
#define RS485_DCTRL                (0x1<<4)
#define RS485_OINV                (0x1<<5)
TO test RS485, program one board with RS485_RX to 1(RX), one
board with RS485_RX to 0(TX). reset TX board to send out a string
with a RS485 slave address first, and then check the content of
UARTBuffer in the RX board. */
#define RS485_RX                        0                /* 1 is RX, 0 is TX. */
#define DIR_CTRL                        0
#define RS485_NMM                        1                /* 1 is NMM mode, 0 is AAD mode. */
/*if RS485_ENABLED is set, set RS485 slave address. */
#define        RS485_SLAVE_ADR                0xC0
串口模拟485也行啊,用个GPIO口控制收发好了
 楼主| 发表于 2022-5-27 10:47:43 | 显示全部楼层
仅uart1支持485模式,硬件设计时需要提前安排,其他串口自行处理没有配套的485寄存器
    2016-12-2 08:40
  • 签到天数: 3 天
    发表于 2022-5-27 15:54:48 | 显示全部楼层
    GMT+8, 2025-9-13 07:53 , Processed in 0.091925 second(s), 24 queries , MemCache On.
