查看: 2745|回复: 2
[求助] S32DS V3.4 编译s32k144报错
发表于 2022-6-28 16:17:33 | 显示全部楼层 |阅读模式
选sram 编译报错,选择 flash编译OK;
但是这个工程很奇葩,只能选择sram编译才能仿真,flash编译无法仿真。
  1. make -j8 all
  2. Building target: s32k144_demo.elf
  3. Invoking: Standard S32DS C Linker
  4. arm-none-eabi-gcc -o "s32k144_demo.elf" "@s32k144_demo.args"
  5. c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/real-ld.exe: s32k144_demo.elf section `.text' will not fit in region `m_text'
  6. c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/real-ld.exe: section .data LMA [20000000,20000c97] overlaps section .text LMA [1fff8400,200038bf]
  7. c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/real-ld.exe: region `m_text' overflowed by 14548 bytes
  8. collect2.exe: error: ld returned 1 exit status
  9. make: *** [makefile:46: s32k144_demo.elf] Error 1
  10. "make -j8 all" terminated with exit code 2. Build might be incomplete.
看信息 是m_text 内容超出了 报错,但是这个是官方sdk的历程,也不知道怎么修改?
我知道答案 目前已有2人回答
 楼主| 发表于 2022-6-28 16:19:58 | 显示全部楼层
sw.zip (514.97 KB, 下载次数: 0)
 楼主| 发表于 2022-6-28 16:20:13 | 显示全部楼层
工程源码见附件
GMT+8, 2025-9-13 07:50 , Processed in 0.088038 second(s), 24 queries , MemCache On.
