查看: 5696|回复: 7
[原创] 【DIY-LPC553X】+ 测试板焊接和调试
  • 签到天数: 1615 天
    连续签到: 3 天
    发表于 2022-8-24 16:34:49 | 显示全部楼层 |阅读模式
        电路板打样回来了,开始焊接调试,烧写个点灯程序。
        一、电路板的焊接
      1.1、电路板正面
        板子上有几个元器件手上没有,还没有焊。
        1.2、电路板背面
        二、电路板调试
        2.1、使用MCUXpresso IDE软件导入官网开发板的GPIO例程
        2.2、根据我板子的硬件修改GPIO端口
         2.3、代码
    1. <font size="3">int main(void)
    2. {
    3.     uint32_t port_state = 0;
    4.     /* Define the init structure for the output LED pin*/
    5.     gpio_pin_config_t led_config = {
    6.         kGPIO_DigitalOutput,
    7.         0,
    8.     };
    9.     /* Board pin, clock, debug console init */
    10.     /* attach 12 MHz clock to FLEXCOMM0 (debug console) */
    11.     CLOCK_SetClkDiv(kCLOCK_DivFlexcom0Clk, 0u, false);
    12.     CLOCK_SetClkDiv(kCLOCK_DivFlexcom0Clk, 1u, true);
    13.     CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
    14.     /* enable clock for GPIO*/
    15.     CLOCK_EnableClock(kCLOCK_Gpio0);
    16.     CLOCK_EnableClock(kCLOCK_Gpio1);
    17.     BOARD_InitPins();
    18.     BOARD_BootClockPLL150M();
    19.     BOARD_InitDebugConsole();
    20.     /* Print a note to terminal. */
    21.     PRINTF("\r\n GPIO Driver example\r\n");
    22.     PRINTF("\r\n The LED is taking turns to shine.\r\n");
    23.     /* Init output LED GPIO. */
    24.     GPIO_PortInit(GPIO, APP_BOARD_TEST_LED_PORT);
    25.     GPIO_PortInit(GPIO, APP_SW_PORT);
    26.     GPIO_PinInit(GPIO, APP_BOARD_TEST_LED_PORT, APP_BOARD_TEST_LED_PIN, &led_config);
    27.     GPIO_PinWrite(GPIO, APP_BOARD_TEST_LED_PORT, APP_BOARD_TEST_LED_PIN, 1);
    28.     /* Port masking */
    29.     GPIO_PortMaskedSet(GPIO, APP_BOARD_TEST_LED_PORT, 0x0000FFFF);
    30.     GPIO_PortMaskedWrite(GPIO, APP_BOARD_TEST_LED_PORT, 0xFFFFFFFF);
    31.     port_state = GPIO_PortRead(GPIO, APP_BOARD_TEST_LED_PORT);
    32.     PRINTF("\r\n Standard port read: %x\r\n", port_state);
    33.     port_state = GPIO_PortMaskedRead(GPIO, APP_BOARD_TEST_LED_PORT);
    34.     PRINTF("\r\n Masked port read: %x\r\n", port_state);
    35.     /* Set systick reload value to generate 1ms interrupt */
    36.     if (SysTick_Config(SystemCoreClock / 1000U))
    37.     {
    38.         while (1)
    39.         {
    40.         }
    41.     }
    42.     while (1)
    43.     {
    44.         //port_state = GPIO_PortRead(GPIO, APP_SW_PORT);
    45.         //if (!(port_state & (1 << APP_SW_PIN)))
    46.         {
    47.             PRINTF("\r\n www.nxpic.org.cn lpc55s36 board test!\r\n");
    48.             GPIO_PortToggle(GPIO, APP_BOARD_TEST_LED_PORT, 1u << APP_BOARD_TEST_LED_PIN);
    49.         }
    50.         /* Delay 1000 ms */
    51.         SysTick_DelayTicks(500U);
    52.     }
    53. }</font>
        三、程序运行
        3.1、串口输出
        3.2、点灯
    发表于 2022-8-24 16:45:30 | 显示全部楼层
    这速度嘎嘎快啊
    5 天前
  • 签到天数: 1555 天
    发表于 2022-8-24 17:06:05 | 显示全部楼层
    您这是速度与质量并存。
    学习了
    前天 23:18
  • 签到天数: 2027 天
    连续签到: 8 天
    3万
    发表于 2022-8-24 17:56:39 | 显示全部楼层
    动作迅速啊~~
  • 签到天数: 345 天
    发表于 2022-8-25 09:25:51 来自手机 | 显示全部楼层
    速度真快哦
    昨天 11:49
  • 签到天数: 1915 天
    连续签到: 9 天
    发表于 2022-8-25 09:54:21 | 显示全部楼层
    厉害厉害!
  • 签到天数: 773 天
    发表于 2022-8-25 18:57:07 | 显示全部楼层
    厉害厉害!
  • 签到天数: 861 天
    发表于 2022-8-31 21:24:35 | 显示全部楼层
    速度啊
    GMT+8, 2026-4-2 01:20 , Processed in 0.107454 second(s), 27 queries , Redis On.
