查看: 1951|回复: 1
[求助] 串口功能切换回普通的GPIO
发表于 2022-11-22 10:12:08 | 显示全部楼层 |阅读模式
  使用的MCU为:S9KEAZN32AMLC,在初始化PTB0和PTB1为串口后,需要将PTB1切换回普通的GPIO功能,目前无法实现,PTB5使用没问题,请坛友帮忙看一下,感谢!
* main implementation: use this 'C' sample to create your own application
#include "derivative.h" /* include peripheral declarations SSKEAZN64M2 */
#include "gpio.h"
#include "ftm.h"
#include "UART.h"
FTM_Type* pFTM0 = (FTM_Type*)FTM0;
FTM_Type* pFTM1 = (FTM_Type*)FTM1;
FTM_Type* pFTM2 = (FTM_Type*)FTM2;
void FTM1_Task(void);
void Clk_Init();
void timer1_config();
void gpio_init();
void uart_com_init(void);
int main(void)
        /* Initialize Core Clock to 32MHz, Bus Clock to 16MHz  */
        Clk_Init();
        uart_com_init();
        gpio_init();
        timer1_config();
     while(1)
void Clk_Init()
ICS_C1|=ICS_C1_IRCLKEN_MASK  ;       /* Enable the internal reference clock*/
// ICS_C1 |= 0x06  ;
ICS_C3= 0x9B;                      /* Reference clock frequency = 31.25 kHz*/
while(!(ICS_S & ICS_S_LOCK_MASK)); /* Wait for PLL, running at 40 MHz (1280 * 31.25 kHz)      1024*31.25K = 32M  */
ICS_C2|=ICS_C2_BDIV(1);                /* BDIV=2, Bus clock = 20 MHz    16M */
ICS_S |= ICS_S_LOLS_MASK;                   /* Clear Loss of lock sticky bit */
void gpio_init()
        SIM_BASE_PTR->SCGC &= (~SIM_SCGC_UART0_MASK);
        CONFIG_PIN_AS_GPIO(PTB,PTB1,OUTPUT);
        OUTPUT_SET(PTB,PTB1);
        CONFIG_PIN_AS_GPIO(PTB,PTB5,OUTPUT);
        OUTPUT_SET(PTB,PTB5);
        FTM_ConfigType FTM1_Config={0};
        FTM1_Config.modulo=62499;
        FTM1_Config.clk_source=FTM_CLOCK_SYSTEMCLOCK;
        FTM1_Config.prescaler=FTM_CLOCK_PS_DIV128;
        FTM1_Config.mode=1;
        FTM1_Config.toie=1;
        FTM_SetCallback(pFTM1, FTM1_Task);
        FTM_Init(pFTM1,&FTM1_Config);
        UART_ConfigType UART_Config={{0}};
        UART_Config.sctrl1settings.bits.bM=0;          /* 8 bit mode*/
        UART_Config.sctrl1settings.bits.bPe=0;        /* No hardware parity generation or checking*/
        UART_Config.bSbns=0;                                        /* One stop bit*/
        UART_Config.sctrl2settings.bits.bRe=1;        /* Enable Receiver*/
        UART_Config.sctrl2settings.bits.bTe=1;        /* Enable Transmitter*/
        UART_Config.sctrl2settings.bits.bRie=1;        /* Enable Receiver  interrupt */
        UART_Config.u32SysClkHz = 16000000;           /* Bus clock in Hz*/
        UART_Config.u32Baudrate = 19200;             /* UART baud rate */
//        UART_SetCallback(UART0, UART0_ISR);
        UART_Init(UART0,&UART_Config);
        PORT_PUEL |= 1<<8 ;
//        UART0->BDH |= UART_BDH_LBKDIE_MASK ;
        UART0->S2 |= UART_S2_BRK13_MASK ;
//        UART0->S2 |= UART_S2_LBKDE_MASK ;
//        UART_SendWait(UART0, test_Buff, 1);
        NVIC_SetPriority(UART0_IRQn,0);
        FTM_ClrOverFlowFlag(pFTM1);
        static uint8_t Cnt_1s = 0 ;
        Cnt_1s ++ ;
        if(Cnt_1s == 2)
                Cnt_1s = 0;
                OUTPUT_TOGGLE(PTB,PTB1);
                OUTPUT_TOGGLE(PTB,PTB5);
我知道答案 目前已有1人回答
发表于 2022-12-1 14:41:57 | 显示全部楼层
解决了吗?我也碰到相似的问题
GMT+8, 2025-10-27 09:34 , Processed in 0.086223 second(s), 23 queries , MemCache On.
