查看: 2442|回复: 0
[S32] S32K148 FlexCAN模块远程帧接收问题
发表于 2023-2-23 14:53:49 | 显示全部楼层 |阅读模式
在测试FlexCAN模块远程帧的收发功能时,发送远程帧是正常的,但是接收不到远程帧。是我配置有问题吗?
flexcan_data_info_t dataInfo =
//         .data_length = 1U,
         .msg_id_type = FLEXCAN_MSG_ID_EXT,
         .enable_brs  = false,
         .fd_enable   = false,
         .fd_padding  = 0U,
                 .is_remote   = true
    /* Configure RX message buffer with index RX_MSG_ID and RX_MAILBOX */
    FLEXCAN_DRV_ConfigRxMb(INST_FLEXCAN_CONFIG_1, RX_MAILBOX, &dataInfo, RX_MSG_ID);
    /* Start receiving data in RX_MAILBOX. */
    FLEXCAN_DRV_Receive(INST_FLEXCAN_CONFIG_1, RX_MAILBOX, &recvBuff);
我知道答案 目前已有0人回答
GMT+8, 2025-10-23 01:32 , Processed in 0.079488 second(s), 21 queries , MemCache On.
