查看: 3935|回复: 2
[求助] 请教LPC54608 UART 功能, 配置完成 后只能输出一个字符 '\0' ?
发表于 2023-3-4 14:31:20 | 显示全部楼层 |阅读模式
使用 FC4_UART 功能, 配置完成 后只能输出一个字符 '\0' ?
单片机使用 LPC54608J512
相关程序如下:
#define IOCON_PIO_FUNC2    0x02u
void BOARD_InitPins(void)
    /* Enables the clock for the IOCON block. 0 = Disable; 1 = Enable.: 0x01u */
    CLOCK_EnableClock(kCLOCK_Iocon);
            const uint32_t port3_pin26_config = (/* Pin is configured as FC4_RXD_SDA_MOSI */
                                         IOCON_PIO_FUNC2 |
                                         /* No addition pin function */
                                         IOCON_PIO_MODE_INACT |
                                         /* Input function is not inverted */
                                         IOCON_PIO_INV_DI |
                                         /* Enables digital function */
                                         IOCON_PIO_DIGITAL_EN |
                                         /* Input filter disabled */
                                         IOCON_PIO_INPFILT_OFF |
                                         /* Standard mode, output slew rate control is enabled */
                                         IOCON_PIO_SLEW_STANDARD |
                                         /* Open drain is disabled */
                                         IOCON_PIO_OPENDRAIN_DI);
    /* PORT3 PIN26 (coords: K5) is configured as FC4_RXD_SDA_MOSI */
    IOCON_PinMuxSet(IOCON, 3U, 26U, port3_pin26_config);
    const uint32_t port3_pin27_config = (/* Pin is configured as FC4_TXD_SCL_MISO */
                                         IOCON_PIO_FUNC2 |
                                         IOCON_PIO_INV_DI |
    /* PORT3 PIN27 (coords: P14) is configured as FC4_TXD_SCL_MISO */
    IOCON_PinMuxSet(IOCON, 3U, 27U, port3_pin27_config);
status_t BOARD_InitDebugConsole(void)
#if ((SDK_DEBUGCONSOLE == DEBUGCONSOLE_REDIRECT_TO_SDK) || defined(SDK_DEBUGCONSOLE_UART))
    status_t result;
    /* attach 12 MHz clock to FLEXCOMM0 (debug console) */
    CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
    RESET_PeripheralReset(BOARD_DEBUG_UART_RST);
    result = DbgConsole_Init(BOARD_DEBUG_UART_INSTANCE, BOARD_DEBUG_UART_BAUDRATE, BOARD_DEBUG_UART_TYPE,
                             BOARD_DEBUG_UART_CLK_FREQ);
    assert(kStatus_Success == result);
    return result;
#else
    return kStatus_Success;
#endif
#define DEMO_USART          USART4
#define DEMO_USART_CLK_SRC  kCLOCK_Flexcomm0
#define DEMO_USART_CLK_FREQ CLOCK_GetFlexCommClkFreq(0)
uint8_t txbuff[]   = "Usart polling example\r\nBoard will send back received characters\r\n";
int main(void)
BOARD_InitPins();
//   BOARD_BootClockPLL220M();
BOARD_BootClockPLL180M();
BOARD_InitDebugConsole();
     * config.baudRate_Bps = 115200U;
     * config.parityMode = kUSART_ParityDisabled;
     * config.stopBitCount = kUSART_OneStopBit;
     * config.loopback = false;
     * config.enableTx = false;
     * config.enableRx = false;
    USART_GetDefaultConfig(&config);
    config.baudRate_Bps = BOARD_DEBUG_UART_BAUDRATE;
    config.enableTx     = true;
    config.enableRx     = true;
    USART_Init(DEMO_USART, &config, DEMO_USART_CLK_FREQ);
    USART_WriteBlocking(DEMO_USART, txbuff, sizeof(txbuff) - 1);
我知道答案 目前已有2人回答
    2016-12-2 08:40
  • 签到天数: 3 天
    发表于 2023-3-6 00:00:35 | 显示全部楼层
    管脚 设置 试试 切换成PULL- UP别用INACTIVE?
     楼主| 发表于 2023-3-7 14:38:04 | 显示全部楼层
    好的, 多谢多谢了啊
    GMT+8, 2025-11-4 12:25 , Processed in 0.085044 second(s), 23 queries , MemCache On.
