查看: 1552|回复: 2
[求助] 求助imx93-14x14-evk 串口7没有节点
发表于 2023-8-10 10:30:41 | 显示全部楼层 |阅读模式
我在  imx93-11x11-evk-lpuart.dts 中添加了 串口7,放到板子上后,/dev/ttyLP0  /dev/ttyLP4  /dev/ttyLP5
没有串口7的节点,是咋回事
  1. // SPDX-License-Identifier: (GPL-2.0+ OR MIT)
  2. /*
  3. * Copyright 2022 NXP
  4. */
  5. #include "imx93-11x11-evk.dts"
  6. /* Unbind lpuart5 from Bluetooth, use it for lpuart test. */
  7. &lpuart5 {
  8.         /delete-node/ bluetooth;
  9. };
  10. &lpuart6 {
  11.         pinctrl-names = "default";
  12.         pinctrl-0 = <&pinctrl_uart6>;
  13.         status = "okay";
  14. };
  15. &lpuart7 {
  16.         pinctrl-names = "default";
  17.         pinctrl-0 = <&pinctrl_uart7>;
  18.         status = "okay";
  19. };
  20. /*
  21. * uart test port1. Note: don't use Bluetooth at the sametime.
  22. * J1001: Pin27--TX Pin28--RX Pin3--CTS Pin5--RTS
  23. */
  24. &pinctrl_uart5 {
  25.         fsl,pins = <
  26.                 MX93_PAD_GPIO_IO00__LPUART5_TX      0x31e
  27.                 MX93_PAD_GPIO_IO01__LPUART5_RX      0x31e
  28.                 MX93_PAD_GPIO_IO02__LPUART5_CTS_B   0x31e
  29.                 MX93_PAD_GPIO_IO03__LPUART5_RTS_B   0x31e
  30.         >;
  31. };
  32. &iomuxc {
  33. /* uart test port2: J1001: Pin7--TX Pin29--RX Pin31--CTS Pin26--RTS */
  34.         pinctrl_uart6: uart6grp {
  35.                 fsl,pins = <
  36.                         MX93_PAD_GPIO_IO04__LPUART6_TX                0x31e
  37.                         MX93_PAD_GPIO_IO05__LPUART6_RX                0x31e
  38.                         MX93_PAD_GPIO_IO06__LPUART6_CTS_B        0x31e
  39.                         MX93_PAD_GPIO_IO07__LPUART6_RTS_B        0x31e
  40.                 >;
  41.         };
  42.                 pinctrl_uart7: uart7grp {
  43.                 fsl,pins = <
  44.                         MX93_PAD_GPIO_IO08__LPUART7_TX                0x31e
  45.                         MX93_PAD_GPIO_IO09__LPUART7_RX                0x31e
  46.                         MX93_PAD_GPIO_IO10__LPUART7_CTS_B        0x31e
  47.                         MX93_PAD_GPIO_IO11__LPUART7_RTS_B        0x31e
  48.                 >;
  49.         };
  50. };
我知道答案 目前已有2人回答
 楼主| 发表于 2023-8-10 10:31:31 | 显示全部楼层
板子是imx93-11x11-evk
 楼主| 发表于 2023-8-10 19:59:39 | 显示全部楼层
如下修改 fsl_uart.c后节点有了,但是串口没数据
#define UART_NR                8
GMT+8, 2025-12-1 13:12 , Processed in 0.080614 second(s), 23 queries , Redis On.
