查看: 905|回复: 0
[求助] i.MX8MQ evk 無法開機
发表于 2023-8-11 16:39:39 | 显示全部楼层 |阅读模式
各位您好,
原本使用SD卡或eMMC都能正常開機,現在不管燒錄幾次都無法開機,甚至使用官方demo image也開不了。
以下是我開機時用debug port看到的訊息,固定卡在imx6q pcie這邊。
U-Boot SPL 2023.04-lf_v2023.04+gaf7d004eaf (Jun 06 2023 - 14:59:40 +0000)
PMIC:  PFUZE100 ID=0x10
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3200MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
SEC0:  RNG instantiated
Normal Boot
Trying to boot from MMC2
U-Boot 2023.04-lf_v2023.04+gaf7d004eaf (Jun 06 2023 - 14:59:40 +0000)
CPU:   i.MX8MQ rev2.0 1500 MHz (running at 1000 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 45C
Reset cause: POR
Model: NXP i.MX8MQ EVK
DRAM:  3 GiB
TCPC:  Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C0 0x50]
Core:  169 devices, 31 uclasses, devicetree: separate
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
  • -Video Link 0 (1280 x 720)
            [0] display-controller@32e00000, video
            [1] hdmi@32c00000, display
    In:    serial
    Out:   serial
    Err:   serial
    switch to partitions #0, OK
    mmc1 is current device
    flash target is MMC:1
    Net:   eth0: ethernet@30be0000
    Fastboot: Normal
    Normal Boot
    Working FDT set to 43000000
    starting USB...
    Bus usb@38100000: Register 2000140 NbrPorts 2
    Starting the controller
    USB XHCI 1.10
    Bus usb@38200000: Register 2000140 NbrPorts 2
    USB XHCI 1.10
    scanning bus usb@38100000 for devices... 1 USB Device(s) found
    scanning bus usb@38200000 for devices... 1 USB Device(s) found
           scanning usb for storage devices... 0 Storage Device(s) found
    Device 0: unknown device
    Scanning mmc 1:1...
    48345 bytes read in 3 ms (15.4 MiB/s)
    Unable to open OP-TEE session (err=-5)
    mm_communicate failed!
    Error: Cannot initialize UEFI sub-system, r = 3
    mmc0(part 0) is current device
    Scanning mmc 0:1...
    Running BSP bootcmd ...
    Failed to load 'boot.scr'
    32121344 bytes read in 352 ms (87 MiB/s)
    Booting from mmc ...
    ## Flattened Device Tree blob at 43000000
       Booting using the fdt blob at 0x43000000
    clk usb1_phy_root_clk already disabled
    clk usb2_phy_root_clk already disabled
       Using Device Tree in place at 0000000043000000, end 000000004300ecd8
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.22+g66e442bc7fdc (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.40.20230119) #1 SMP PREEMPT Mon Jun 12 12:31:27 UTC 2023
    [    0.000000] Machine model: NXP i.MX8MQ EVK
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000080000000, size 896 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] NUMA: No NUMA configuration found
    [    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000fdffffff]
    [    0.000000] NUMA: NODE_DATA [mem 0xfd9ca700-0xfd9ccfff]
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000040000000-0x00000000fdffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fdffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000fdffffff]
    [    0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 20 pages/cpu s44520 r8192 d29208 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Fallback order for Node 0: 0
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 766080
    [    0.000000] Policy zone: DMA
    [    0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:all(zero), heap allocff, heap freeff
    [    0.000000] Memory: 2101372K/3112960K available (19584K kernel code, 1608K rwdata, 6708K rodata, 3328K init, 644K bss, 94084K reserved, 917504K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 128 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
    [    0.000000] ITS: No ITS available, not enabling LPIs
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 8.33MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1ec0311ec, max_idle_ns: 440795202152 ns
    [    0.000001] sched_clock: 56 bits at 8MHz, resolution 120ns, wraps every 2199023255541ns
    [    0.000481] Console: colour dummy device 80x25
    [    0.000555] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.66 BogoMIPS (lpj=33333)
    [    0.000568] pid_max: default: 32768 minimum: 301
    [    0.000632] LSM: Security Framework initializing
    [    0.000737] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.000761] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.002327] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.002337] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.002417] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.002596] rcu: Hierarchical SRCU implementation.
    [    0.002600] rcu:     Max phase no-delay instances is 1000.
    [    0.003761] EFI services will not be available.
    [    0.004032] smp: Bringing up secondary CPUs ...
    [    0.004527] Detected VIPT I-cache on CPU1
    [    0.004614] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
    [    0.004650] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.005178] Detected VIPT I-cache on CPU2
    [    0.005252] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
    [    0.005275] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.005752] Detected VIPT I-cache on CPU3
    [    0.005825] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
    [    0.005848] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.005909] smp: Brought up 1 node, 4 CPUs
    [    0.005916] SMP: Total of 4 processors activated.
    [    0.005921] CPU features: detected: 32-bit EL0 Support
    [    0.005923] CPU features: detected: 32-bit EL1 Support
    [    0.005928] CPU features: detected: CRC32 instructions
    [    0.005997] CPU: All CPU(s) started at EL2
    [    0.006018] alternatives: applying system-wide alternatives
    [    0.008192] devtmpfs: initialized
    [    0.016015] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.016037] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.045569] pinctrl core: initialized pinctrl subsystem
    [    0.047832] DMI not present or invalid.
    [    0.048533] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.049785] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.050069] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.050305] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.050346] audit: initializing netlink subsys (disabled)
    [    0.050483] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
    [    0.051015] thermal_sys: Registered thermal governor 'step_wise'
    [    0.051020] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.051056] cpuidle: using governor menu
    [    0.051230] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.051312] ASID allocator initialised with 65536 entries
    [    0.052309] Serial: AMBA PL011 UART driver
    [    0.052378] imx mu driver is registered.
    [    0.052401] imx rpmsg driver is registered.
    [    0.062656] imx8mq-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
    [    0.069156] platform 30a70000.mipi_csi1: Fixed dependency cycle(s) with /soc@0/bus@30800000/csi1_bridge@30a90000
    [    0.069180] platform 30a70000.mipi_csi1: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a30000/ov5640_mipi@3c
    [    0.070469] platform 30b60000.mipi_csi2: Fixed dependency cycle(s) with /soc@0/bus@30800000/csi2_bridge@30b80000
    [    0.070491] platform 30b60000.mipi_csi2: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a20000/ov5640_mipi2@3c
    [    0.072019] platform 32c00000.hdmi: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e00000
    [    0.072782] platform 38100000.usb: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a20000/tcpc@50
    [    0.075600] platform ptn36043: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a20000/tcpc@50/connector
    [    0.078252] KASLR disabled due to lack of seed
    [    0.099206] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.099214] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.099219] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.099223] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.099229] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.099233] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.099238] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.099243] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.101255] ACPI: Interpreter disabled.
    [    0.101952] iommu: Default domain type: Translated
    [    0.101958] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.102260] SCSI subsystem initialized
    [    0.102582] usbcore: registered new interface driver usbfs
    [    0.102625] usbcore: registered new interface driver hub
    [    0.102657] usbcore: registered new device driver usb
    [    0.103775] mc: Linux media interface: v0.10
    [    0.103813] videodev: Linux video capture interface: v2.00
    [    0.103900] pps_core: LinuxPPS API ver. 1 registered
    [    0.103904] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.103919] PTP clock support registered
    [    0.104072] EDAC MC: Ver: 3.0.0
    [    0.105273] FPGA manager framework
    [    0.105353] Advanced Linux Sound Architecture Driver Initialized.
    [    0.105970] Bluetooth: Core ver 2.22
    [    0.106000] NET: Registered PF_BLUETOOTH protocol family
    [    0.106004] Bluetooth: HCI device and connection manager initialized
    [    0.106012] Bluetooth: HCI socket layer initialized
    [    0.106019] Bluetooth: L2CAP socket layer initialized
    [    0.106031] Bluetooth: SCO socket layer initialized
    [    0.106404] vgaarb: loaded
    [    0.106907] clocksource: Switched to clocksource arch_sys_counter
    [    0.107100] VFS: Disk quotas dquot_6.6.0
    [    0.107141] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.107330] pnp: PnP ACPI: disabled
    [    0.114867] NET: Registered PF_INET protocol family
    [    0.115121] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.118405] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.118448] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.118464] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.118721] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.119768] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.119873] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.119985] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.120186] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.120535] RPC: Registered named UNIX socket transport module.
    [    0.120540] RPC: Registered udp transport module.
    [    0.120543] RPC: Registered tcp transport module.
    [    0.120546] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.121409] PCI: CLS 0 bytes, default 64
    [    0.122130] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.123012] kvm [1]: IPA Size Limit: 40 bits
    [    0.124610] kvm [1]: vgic-v2@31020000
    [    0.124625] kvm [1]: GIC system register CPU interface enabled
    [    0.124720] kvm [1]: vgic interrupt IRQ9
    [    0.124813] kvm [1]: Hyp mode initialized successfully
    [    0.126032] Initialise system trusted keyrings
    [    0.126225] workingset: timestamp_bits=42 max_order=20 bucket_order=0
    [    0.133363] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.133954] NFS: Registering the id_resolver key type
    [    0.133988] Key type id_resolver registered
    [    0.133992] Key type id_legacy registered
    [    0.134072] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.134078] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.134103] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    0.134424] 9p: Installing v9fs 9p2000 file system support
    [    0.177290] Key type asymmetric registered
    [    0.177295] Asymmetric key parser 'x509' registered
    [    0.177348] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.177355] io scheduler mq-deadline registered
    [    0.177360] io scheduler kyber registered
    [    0.184266] EINJ: ACPI disabled.
    [    0.192742] imx-sdma 302c0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
    [    0.192755] imx-sdma 302c0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
    [    0.196152] mxs-dma 33000000.dma-apbh: initialized
    [    0.200855] SoC: i.MX8MQ revision 2.0
    [    0.200953] Config NOC for VPU and CPU
    [    0.201691] Bus freq driver module loaded
    [    0.207630] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.209920] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 18, base_baud = 1562500) is a IMX
    [    1.343788] printk: console [ttymxc0] enabled
    [    1.348778] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 19, base_baud = 5000000) is a IMX
    [    1.357693] serial serial0: tty port ttymxc2 registered
    [    1.376940] loop: module loaded
    [    1.381367] of_reserved_mem_lookup() returned NULL
    [    1.386351] megasas: 07.719.03.00-rc1
    [    1.394812] spi-nor spi3.0: n25q256a (32768 Kbytes)
    [    1.404345] tun: Universal TUN/TAP device driver, 1.6
    [    1.410262] thunder_xcv, ver 1.0
    [    1.413542] thunder_bgx, ver 1.0
    [    1.416817] nicpf, ver 1.0
    [    1.421712] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
    [    1.428944] hns3: Copyright (c) 2017 Huawei Corporation.
    [    1.434316] hclge is initializing
    [    1.437651] e1000: Intel(R) PRO/1000 Network Driver
    [    1.442537] e1000: Copyright (c) 1999-2006 Intel Corporation.
    [    1.448330] e1000e: Intel(R) PRO/1000 Network Driver
    [    1.453301] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [    1.459272] igb: Intel(R) Gigabit Ethernet Network Driver
    [    1.464681] igb: Copyright (c) 2007-2014 Intel Corporation.
    [    1.470289] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    1.476564] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    1.482665] sky2: driver version 1.30
    [    1.486939] usbcore: registered new interface driver r8152
    [    1.492690] VFIO - User Level meta-driver version: 0.3
    [    1.501193] usbcore: registered new interface driver uas
    [    1.506560] usbcore: registered new interface driver usb-storage
    [    1.512642] usbcore: registered new interface driver usbserial_generic
    [    1.519195] usbserial: USB Serial support registered for generic
    [    1.525238] usbcore: registered new interface driver ftdi_sio
    [    1.531006] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    1.538350] usbcore: registered new interface driver usb_serial_simple
    [    1.544902] usbserial: USB Serial support registered for carelink
    [    1.551016] usbserial: USB Serial support registered for zio
    [    1.556700] usbserial: USB Serial support registered for funsoft
    [    1.562730] usbserial: USB Serial support registered for flashloader
    [    1.569103] usbserial: USB Serial support registered for google
    [    1.575045] usbserial: USB Serial support registered for libtransistor
    [    1.581592] usbserial: USB Serial support registered for vivopay
    [    1.587628] usbserial: USB Serial support registered for moto_modem
    [    1.593919] usbserial: USB Serial support registered for motorola_tetra
    [    1.600557] usbserial: USB Serial support registered for nokia
    [    1.606413] usbserial: USB Serial support registered for novatel_gps
    [    1.612798] usbserial: USB Serial support registered for hp4x
    [    1.618567] usbserial: USB Serial support registered for suunto
    [    1.624511] usbserial: USB Serial support registered for siemens_mpi
    [    1.630911] usbcore: registered new interface driver usb_ehset_test
    [    1.640138] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
    [    1.654645] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
    [    1.660856] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01T00:00:00 UTC (0)
    [    1.670024] i2c_dev: i2c /dev entries driver
    [    1.675551] mxc-mipi-csi2_yav 30a70000.mipi_csi1: mipi_csi2_probe
    [    1.681704] mxc-mipi-csi2_yav 30a70000.mipi_csi: Remote device at endpoint@0 XXX found
    [    1.6**4] mxc-mipi-csi2_yav 30a70000.mipi_csi1: lanes: 2, name: mxc-mipi-csi2.0
    [    1.697484] mxc-mipi-csi2_yav 30b60000.mipi_csi2: mipi_csi2_probe
    [    1.703638] mxc-mipi-csi2_yav 30b60000.mipi_csi: Remote device at endpoint@0 XXX found
    [    1.711588] mxc-mipi-csi2_yav 30b60000.mipi_csi2: lanes: 2, name: mxc-mipi-csi2.1
    [    1.719423] mx6s-csi 30a90000.csi1_bridge: initialising
    [    1.724892] CSI: Registered sensor subdevice: mxc-mipi-csi2.0
    [    1.730816] mx6s-csi 30b80000.csi2_bridge: initialising
    [    1.736259] CSI: Registered sensor subdevice: mxc-mipi-csi2.1
    [    1.745941] Bluetooth: HCI UART driver ver 2.3
    [    1.750409] Bluetooth: HCI UART protocol H4 registered
    [    1.755558] Bluetooth: HCI UART protocol BCSP registered
    [    1.760905] Bluetooth: HCI UART protocol LL registered
    [    1.766052] Bluetooth: HCI UART protocol ATH3K registered
    [    1.771478] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    1.777856] Bluetooth: HCI UART protocol Broadcom registered
    [    1.783548] Bluetooth: HCI UART protocol QCA registered
    [    1.790368] sdhci: Secure Digital Host Controller Interface driver
    [    1.796562] sdhci: Copyright(c) Pierre Ossman
    [    1.801662] Synopsys Designware Multimedia Card Interface Driver
    [    1.808358] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.816037] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.822811] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.829818] usbcore: registered new interface driver usbhid
    [    1.835409] usbhid: USB HID core driver
    [    1.844213]  cs_system_cfg: CoreSight Configuration manager initialised
    [    1.852183] optee: probing for conduit method.
    [    1.856653] optee: revision 3.21 (1962aec9)
    [    1.857964] optee: dynamic shared memory is enabled
    [    1.867433] optee: initialized driver
    [    1.878343] NET: Registered PF_LLC protocol family
    [    1.885255] NET: Registered PF_INET6 protocol family
    [    1.893624] Segment Routing with IPv6
    [    1.897348] In-situ OAM (IOAM) with IPv6
    [    1.901335] NET: Registered PF_PACKET protocol family
    [    1.906429] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    1.921035] Bluetooth: RFCOMM TTY layer initialized
    [    1.925936] Bluetooth: RFCOMM socket layer initialized
    [    1.931100] Bluetooth: RFCOMM ver 1.11
    [    1.934857] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.940177] Bluetooth: BNEP filters: protocol multicast
    [    1.945415] Bluetooth: BNEP socket layer initialized
    [    1.950387] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.956319] Bluetooth: HIDP socket layer initialized
    [    1.962992] 8021q: 802.1Q VLAN Support v1.8
    [    1.967207] lib80211: common routines for IEEE802.11 drivers
    [    1.972986] 9pnet: Installing 9P2000 support
    [    1.977396] Key type dns_resolver registered
    [    1.983076] registered taskstats version 1
    [    1.987209] Loading compiled-in X.509 certificates
    [    2.031584] gpio-157 (wl-reg-on-hog): hogged as output/high
    [    2.039997] ov5640_mipi 0-003c: No sensor reset pin available
    [    2.046254] ov5640_mipi 0-003c: supply DOVDD not found, using dummy regulator
    [    2.053507] ov5640_mipi 0-003c: supply DVDD not found, using dummy regulator
    [    2.060624] ov5640_mipi 0-003c: supply AVDD not found, using dummy regulator
    [    2.079423] ov5640_mipi 0-003c: Read reg error: reg=300a
    [    2.084754] ov5640_mipi 0-003c: Camera is not found
    [    2.090211] imx-gpcv2 303a0000.gpc: Failed to create device link (0x180) with 0-0008
    [    2.097979] imx-gpcv2 303a0000.gpc: Failed to create device link (0x180) with 0-0008
    [    2.109199] pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
    [    2.120310] pfuze100-regulator 0-0008: FAB: 0, FIN: 0
    [    2.125385] pfuze100-regulator 0-0008: pfuze100 found.
    [    2.219582] imx-gpcv2 303a0000.gpc: Failed to create device link (0x180) with 0-0008
    [    2.227349] imx-gpcv2 303a0000.gpc: Failed to create device link (0x180) with 0-0008
    [    2.242307] i2c i2c-0: IMX I2C adapter registered
    [    2.249049] ov5640_mipi 1-003c: No sensor reset pin available
    [    2.254846] ov5640_mipi 1-003c: supply DOVDD not found, using dummy regulator
    [    2.262090] ov5640_mipi 1-003c: supply DVDD not found, using dummy regulator
    [    2.269205] ov5640_mipi 1-003c: supply AVDD not found, using dummy regulator
    [    2.291660] ov5640_mipi 1-003c: Read reg error: reg=300a
    [    2.296991] ov5640_mipi 1-003c: Camera is not found
    [    2.302120] i2c i2c-1: IMX I2C adapter registered
    [    2.308932] i2c i2c-2: IMX I2C adapter registered
    [    2.314353] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
    [    2.322959] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
    [    2.333543] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges:
    [    2.335805] imx6q-pcie 33c00000.pcie: host bridge /soc@0/pcie@33c00000 ranges:
    [    2.340850] imx6q-pcie 33800000.pcie:       IO 0x001ff80000..0x001ff8ffff -> 0x0000000000
    [    2.348050] imx6q-pcie 33c00000.pcie:   No bus range found for /soc@0/pcie@33c00000, using [bus 00-ff]
    [    2.356250] imx6q-pcie 33800000.pcie:      MEM 0x0018000000..0x001fefffff -> 0x0018000000
    [    2.365549] imx6q-pcie 33c00000.pcie:       IO 0x0027f80000..0x0027f8ffff -> 0x0000000000
    [    2.381921] imx6q-pcie 33c00000.pcie:      MEM 0x0020000000..0x0027efffff -> 0x0020000000
    [    2.400822] cdns-mhdp-imx 32c00000.hdmi: lane-mapping 0xe4
    [    2.406331] [drm] Both HDCP 1.4 and 2.2 are enabled
    [    2.417169] imx-dcss 32e00000.display-controller: bound 32c00000.hdmi (ops cdns_mhdp_imx_ops)
    [    2.427008] [drm] Initialized imx-dcss 1.0.0 20190917 for 32e00000.display-controller on minor 0
    [    2.436900] imx-dcss 32e00000.display-controller: [drm] Cannot find any crtc or sizes
    [    2.445844] imx-dcss 32e00000.display-controller: [drm] Cannot find any crtc or sizes
    [    2.448547] pps pps0: new PPS source ptp0
    [    2.454725] imx-dcss 32e00000.display-controller: [drm] Cannot find any crtc or sizes
    [    2.587576] imx6q-pcie 33800000.pcie: iATU: unroll T, 4 ob, 4 ib, align 64K, limit 4G
  • 不確定是不是硬體出現問題,有沒有大神可以幫幫我。
    謝謝!
    我知道答案 目前已有0人回答
    GMT+8, 2025-10-27 19:41 , Processed in 0.090769 second(s), 21 queries , MemCache On.
