查看: 2421|回复: 1
[求助] 【求救】关于KL03芯片 PA1无法开启上升沿中断的问题
发表于 2023-8-21 18:15:18 | 显示全部楼层 |阅读模式
1NXP金币
各位大佬,想问一下我目前将NXP的中断端口改到了SWD的RESET端口上,目前PA1端口一直为高电平,固件代码如下
想问一下,如何解决这个问题
 楼主| 发表于 2023-8-21 18:16:34 | 显示全部楼层
const port_pin_config_t NT_VOUT = {/* Internal pull-up/down resistor is disabled */
                                       kPORT_PullUp,
                                       /* Slow slew rate is configured */
                                       kPORT_FastSlewRate,
                                       /* Passive filter is disabled */
                                       kPORT_PassiveFilterDisable,
                                       /* Low drive strength is configured */
                                       kPORT_LowDriveStrength,
                                       /* Pin is configured as PTA1 */
                                       kPORT_PinDisabledOrAnalog};
    /* PORTA1 (pin B4) is configured as PTA1 */
    PORT_SetPinConfig(BOARD_INITPINS_NT_VOUT_PORT, BOARD_INITPINS_NT_VOUT_PIN, &NT_VOUT);
    /* Interrupt configuration on PORTA1 (pin D1): Interrupt on falling edge */
    PORT_SetPinInterruptConfig(BOARD_INITPINS_NT_VOUT_PORT, BOARD_INITPINS_NT_VOUT_PIN, kPORT_InterruptRisingEdge);
GMT+8, 2026-9-23 02:08 , Processed in 0.096463 second(s), 18 queries , Redis On.
