查看: 1619|回复: 1
S32k串口通信接收发
发表于 2023-11-22 17:05:02 | 显示全部楼层 |阅读模式
哪位大神知道为什么,串口第一次发送信息能正常返回,第二次发送就产生异常了。搞了一整天没搞出来。
*   Project              : RTD AUTOSAR 4.4
*   Platform             : CORTEXM
*   Peripheral           :
*   Dependencies         : none
*   Autosar Version      : 4.4.0
*   Autosar Revision     : ASR_REL_4_4_REV_0000
*   Autosar Conf.Variant :
*   SW Version           : 1.0.0
*   Build Version        : S32K1_RTD_1_0_0_ASR_REL_4_4_REV_0000_20210810
#include "Mcl.h"
#include "Mcu.h"
#include "Uart.h"
#include "Port.h"
#include "Dio.h"
#include "Platform.h"
#include "Lpuart_Uart_Ip_Irq.h"
#include "Lpuart_Uart_Ip.h"
//#include "Flexio_Uart_Ip_Irq.h"
//#include "check_example.h"
#include <string.h>
#define UART_LPUART_INTERNAL_CHANNEL  0U
#define WELCOME_MSG_1 "LED已点亮,灯光明亮啦!\r\n"
#define WELCOME_MSG_2 "LED已熄灭,一片宁静!\r\n"
#define WELCOME_MSG_3 "hello\r\n"
#define BUFFER_SIZE  50U
int flag = 1;
uint8 rxIndex = 0;
uint8 Rx_Buffer[BUFFER_SIZE];
uint8 Rx_Data[BUFFER_SIZE];
uint8 Response[BUFFER_SIZE];
volatile Uart_StatusType Uart_ReceiveStatus = UART_STATUS_TIMEOUT;
volatile Uart_StatusType Uart_TransmitStatus = UART_STATUS_TIMEOUT;
uint32 T_bytesRemaining;
uint32 T_timeout = 0xFFFFFF;
void TestDelay(uint32 delay);
   static volatile uint32 DelayTimer = 0;
   while(DelayTimer<delay)
       DelayTimer++;
   DelayTimer=0;
boolean User_Str_Cmp(const uint8 * pBuffer1, const uint8 * pBuffer2, const uint32 length)
    uint32 idx = 0;
    for (idx = 0; idx < length; idx++)
        if(pBuffer1[idx] != pBuffer2[idx])
            return FALSE;
    return TRUE;
void Lpuart_CallBack(const uint8 HwInstance,const Lpuart_Uart_Ip_EventType Event,void *UserData)
        (void)UserData;
        if(HwInstance == UART_LPUART_INTERNAL_CHANNEL)
                switch(Event)
                        case  LPUART_UART_IP_EVENT_RX_FULL:
                                if((Rx_Buffer[rxIndex] != '\n')&&(rxIndex != (BUFFER_SIZE -2U)))
                                        rxIndex++;
                                        Lpuart_Uart_Ip_SetRxBuffer(1,&Rx_Buffer[rxIndex],1U);
//                                        Response[rxIndex] = rxIndex;
//                                        flag = 0;
        //                        RX_FULL_num++;
                                break;
                        case LPUART_UART_IP_EVENT_TX_EMPTY:
        //                        TX_EMPTY_num++;
                                break;
                        case LPUART_UART_IP_EVENT_END_TRANSFER:
                                flag = 0;
                                break;
                        case LPUART_UART_IP_EVENT_ERROR:
        //                        ERROR_num++;
                                break;
                        default :
                                break;
  \brief The main function for the project.
  \details The startup initialization sequence is the following:
* - startup asm routine
* - main()
int main(void)
    /* Write your code here */
         /* Initialize the Mcu driver */
            Mcu_Init(NULL_PTR);
            Mcu_InitClock(McuClockSettingConfig_0);
        #if (MCU_NO_PLL == STD_OFF)
            while ( MCU_PLL_LOCKED != Mcu_GetPllStatus() )
                /* Busy wait until the System PLL is locked */
            Mcu_DistributePllClock();
        #endif
            Mcu_SetMode(McuModeSettingConf_0);
            /* Initialize Mcl module */
            Mcl_Init(NULL_PTR);
            /* Initialize all pins using the Port driver */
            Port_Init(NULL_PTR);
            /* Initialize IRQs */
            Platform_Init(NULL_PTR);
            Platform_InstallIrqHandler(LPUART1_RxTx_IRQn, LPUART_UART_IP_1_IRQHandler, NULL_PTR);
            /* Initializes an UART driver*/
            Uart_Init(NULL_PTR);
            memset(Rx_Buffer, 0, sizeof(Rx_Buffer));
                while(true)
                         Uart_AsyncReceive(UART_LPUART_INTERNAL_CHANNEL, Rx_Buffer, 1);
                         while(flag);
                         /* Append string terminator to the received data */
                         rxIndex++;
                         Rx_Buffer[rxIndex] = 0U;
                         memcpy(Rx_Data,Rx_Buffer,rxIndex);
                         Uart_AsyncSend(UART_LPUART_INTERNAL_CHANNEL, Rx_Data, 10);
                         /* Reset the buffer index to start a new reception */
                         rxIndex = 0U;
       Uart_Deinit();
           Mcl_DeInit();
//           Exit_Example((T_Uart_Status1 == E_OK) && (T_Uart_Status2 == E_OK));
           return (0U);
GMT+8, 2025-10-27 01:19 , Processed in 0.084684 second(s), 18 queries , MemCache On.
