查看: 2010|回复: 1
[求助] eiq在安装环境的pip install jupyter时错误
发表于 2024-2-2 11:58:21 来自手机 | 显示全部楼层 |阅读模式
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
deepview-validator 2.3.9.post4 requires requests==2.25.1, but you have requests 2.31.0 which is incompatible.
tensorflow 2.5.0 requires typing-extensions~=3.7.4, but you have typing-extensions 4.9.0 which is incompatible.
virtualenv 20.10.0 requires platformdirs<3,>=2, but you have platformdirs 4.1.0 which is incompatible.
我找到了venv  lib  site-package,删除了里面的高版本安装包,把python  lib  site-package里的低版本安装包放进去,但一运行jupyter,就会把高版本的重新装回去。
跳过这个错误去直接导入图片导不进去
发表于 2024-12-13 14:05:04 | 显示全部楼层
我也遇到了相同的问题
GMT+8, 2026-4-7 00:59 , Processed in 0.075608 second(s), 21 queries , Redis On.
