在线时间491 小时
UID3547866
注册时间2022-4-24
NXP金币5203
TA的每日心情 | 开心 昨天 20:14 |
签到天数: 1209 天 连续签到: 31 天 [LV.10]以坛为家III
- 6225
- 2025-11-15
【MCX-N947分享】+驱动TFT屏
折腾了好长时间,终于调通SPI接口的TFT显示屏的显示处理了。发现实现MCX-N97的GPIO输入输出处理,和之前用过的ARM系列的开发板还真是不一样啊。除了要设置GPIO的标准设置外,
// 打开总线时钟
CLOCK_EnableClock(kCLOCK_Gpio3);
CLOCK_EnableClock(kCLOCK_Gpio0);
// 初始化端口
const port_pin_config_t port0_2_pin16_config = {/* Internal pull-up/down resistor is disabled */
kPORT_PullDisable,
/* Low internal pull resistor value is selected. */
kPORT_LowPullResistor,
/* Fast slew rate is configured */
kPORT_FastSlewRate,
/* Passive input filter is disabled */
kPORT_PassiveFilterDisable,
/* Open drain output is disabled */
kPORT_OpenDrainDisable,
/* Low drive strength is configured */
kPORT_LowDriveStrength,
/* Pin is configured as PIO3_4 */
kPORT_MuxAlt0,
/* Digital input enabled */
kPORT_InputBufferEnable,
/* Digital input is not inverted */
kPORT_InputNormal,
/* Pin Control Register fields [15:0] are not locked */
kPORT_UnlockRegister};
PORT_SetPinConfig(PORT0, 16U, &port0_2_pin16_config);
PORT_SetPinConfig(PORT0, 17U, &port0_2_pin16_config);
PORT_SetPinConfig(PORT0, 20U, &port0_2_pin16_config);
const port_pin_config_t port3_4_pinF14_config = {/* Internal pull-up/down resistor is disabled */
kPORT_PullDisable,
kPORT_FastSlewRate,
kPORT_MuxAlt0,
kPORT_InputNormal,
/* PORT3_4 (pin F14) is configured as PIO3_4 */
PORT_SetPinConfig(PORT3, 4U, &port3_4_pinF14_config);
PORT_SetPinConfig(PORT3, 1U, &port3_4_pinF14_config);
PORT_SetPinConfig(PORT3, 2U, &port3_4_pinF14_config);
PORT_SetPinConfig(PORT3, 3U, &port3_4_pinF14_config);
还要执行以下代码:
GPIO0->PDDR |= (1U << 16);
GPIO0->PDDR |= (1U << 17);
GPIO0->PDDR |= (1U << 20);
GPIO3->PDDR |= (1U << 1);
GPIO3->PDDR |= (1U << 2);
GPIO3->PDDR |= (1U << 3);
GPIO3->PDDR |= (1U << 4);
否则GPIO口不会被正常使用,输出高、低电平。
我的TFT屏是ST7735驱动的,在示例程序的基础上,进行必要的修改,以适应MCX-N947的开发环境。最终驱动效果如下:
