查看: 2416|回复: 1
[分享] 【MCX-N947-BRK板卡试用】-3-启动RTThread
  • 签到天数: 1082 天
    发表于 2024-4-8 19:03:10 | 显示全部楼层 |阅读模式
    本文记录一下在Keil下使用Jlink烧录RTThread固件的过程。
    首先在Git下载最新的Rtthread固件库,把frdm-mcxn947文件夹复制并rename:mcxn947-brk.
    使用Jlink RTTview打印,添加相关C和H文件:
    1. #include <rtdevice.h>
    2. #include <rtthread.h>
    3. #include "drv_pin.h"
    4. #include "SEGGER_RTT.h"
    5. #include "SEGGER_RTT_Conf.h"
    6. #define LEDB_PIN        ((3*32)+4)
    7. #define BUTTON_PIN      ((0*32)+6)
    8. static void sw_pin_cb(void *args);
    9. int main(void)
    10. {
    11. #if defined(__CC_ARM)
    12.     rt_kprintf("using armcc, version: %d\n", __ARMCC_VERSION);
    13. #elif defined(__clang__)
    14.     rt_kprintf("using armclang, version: %d\n", __ARMCC_VERSION);
    15. #elif defined(__ICCARM__)
    16.     rt_kprintf("using iccarm, version: %d\n", __VER__);
    17. #elif defined(__GNUC__)
    18.     rt_kprintf("using gcc, version: %d.%d\n", __GNUC__, __GNUC_MINOR__);
    19. #endif
    20.     rt_pin_mode(LEDB_PIN, PIN_MODE_OUTPUT);  /* Set GPIO as Output */
    21.     rt_pin_mode(BUTTON_PIN, PIN_MODE_INPUT_PULLUP);
    22.     rt_pin_attach_irq(BUTTON_PIN, PIN_IRQ_MODE_FALLING, sw_pin_cb, RT_NULL);
    23.     rt_pin_irq_enable(BUTTON_PIN, 1);
    24.     rt_kprintf("MCXN947 HelloWorld\r\n");
    25.                 SEGGER_RTT_printf(0,"MCXN947 HelloWorld\r\n");
    26. #ifdef RT_USING_SDIO
    27.     rt_thread_mdelay(2000);
    28.     if (dfs_mount("sd", "/", "elm", 0, NULL) == 0)
    29.     {
    30.         rt_kprintf("sd mounted to /\n");
    31.     }
    32.     else
    33.     {
    34.         rt_kprintf("sd mount to / failed\n");
    35.     }
    36. #endif
    37.     while (1)
    38.     {
    39.         rt_pin_write(LEDB_PIN, PIN_HIGH);    /* Set GPIO output 1 */
    40.         rt_thread_mdelay(1000);               /* Delay 500mS */
    41.         rt_pin_write(LEDB_PIN, PIN_LOW);     /* Set GPIO output 0 */
    42.         rt_thread_mdelay(1000);               /* Delay 500mS */
    43.     }
    44. }
    45. static void sw_pin_cb(void *args)
    46. {
    47.     rt_kprintf("sw pressed\r\n");
    48.           SEGGER_RTT_printf(0,"sw pressed\r\n");
    49. }
    50. // end file
    其中,如下LED和BUTTON,需要根据MCXN-947 BRK板子的实际情况,修改后如下:
    1. #define LEDB_PIN        ((3*32)+4)
    2. #define BUTTON_PIN      ((0*32)+6)
    如下需要更改:
    下载选项Jlink
    下载之前,需要把如下两个文件放在项目同级文件夹:
    JLinkSettings.zip (1.56 KB, 下载次数: 1)
  • 签到天数: 204 天
    发表于 2024-4-9 08:18:43 | 显示全部楼层
    GMT+8, 2025-11-16 02:05 , Processed in 0.087420 second(s), 21 queries , MemCache On.
