查看: 1930|回复: 2
[求助] lpc824 硬件i2c的应用
发表于 2024-5-9 15:48:01 | 显示全部楼层 |阅读模式
检索了坛子里ssd1306的驱动,spi居多,i2c的应用比较少,有一个还是基于mbed的,因为系统会挂载多个i2c所以还是想用硬件的
哪位有作品分享一下,zlg的lm75做了2次封装,理解起来也比较。。,
多谢
我知道答案 目前已有2人回答
    发表于 2024-5-10 09:49:22 | 显示全部楼层
     楼主| 发表于 2024-5-11 08:41:06 | 显示全部楼层
    多谢guanguan,找到个845的硬件i2c驱动,
    static void OLED_Command (uint8_t Cmd)
            i2c_master_transfer_t xfer = {0};
            xfer.data = (uint8_t *)&Cmd;
            xfer.dataSize = sizeof(Cmd);
            xfer.flags = kI2C_TransferDefaultFlag;
            xfer.slaveAddress = SSD1306_ADDRESS_1;
            xfer.direction = kI2C_Write;
            xfer.subaddress = 0x0;
            xfer.subaddressSize = 1;
            I2C_MasterTransferBlocking(I2C1, &xfer);
    static void OLED_Data (uint8_t *Data)
            /*Start Transfer*/
            xfer.data = Data;
            xfer.dataSize = sizeof(OLED_Buffer);
            xfer.subaddress = 0x40;
    上面两个关键的函数,下面是824的demo
    * Function to setup and execute I2C transfer request */
    static void SetupXferRecAndExecute(uint8_t devAddr,
        uint8_t *txBuffPtr,
        uint16_t txSize,
        uint8_t *rxBuffPtr,
        uint16_t rxSize)
            /* Setup I2C transfer record */
            i2cmXferRec.slaveAddr = devAddr;
            i2cmXferRec.status = 0;
            i2cmXferRec.txSz = txSize;
            i2cmXferRec.rxSz = rxSize;
            i2cmXferRec.txBuff = txBuffPtr;
            i2cmXferRec.rxBuff = rxBuffPtr;
            Chip_I2CM_XferBlocking(LPC_I2C, &i2cmXferRec);
    GMT+8, 2025-10-23 10:08 , Processed in 0.079649 second(s), 22 queries , MemCache On.
