查看: 1629|回复: 0
[求助] NXP kea128配置GPIO出现问题了,五个按键只有三个按键能用,...
发表于 2024-7-8 19:28:33 | 显示全部楼层 |阅读模式
void  Kbi_Init()
        CONFIG_PIN_AS_GPIO(PTE,PTE0,INPUT); /* Configure SW1 (PTD0) as an input */
        CONFIG_PIN_AS_GPIO(PTE,PTE1,INPUT); /* Configure SW2 (PTD1) as an input */
        CONFIG_PIN_AS_GPIO(PTE,PTE2,INPUT); /* Configure SW1 (PTD0) as an input */
        CONFIG_PIN_AS_GPIO(PTE,PTE3,INPUT); /* Configure SW2 (PTD1) as an input */
  CONFIG_PIN_AS_GPIO(PTE,PTE4,INPUT); /* Configure SW2 (PTD1) as an input */
        ENABLE_INPUT(PTE,PTE0);                          /* Enable input SW1*/
        ENABLE_INPUT(PTE,PTE1);                          /* Enable input SW2*/
  ENABLE_INPUT(PTE,PTE2);                          /* Enable input SW1*/
        ENABLE_INPUT(PTE,PTE3);                          /* Enable input SW2*/
  ENABLE_INPUT(PTE,PTE4);                          /* Enable input SW2*/
  ENABLE_PULLUP(PTE,PTE0); /* 配置内部上拉电阻 */
  ENABLE_PULLUP(PTE,PTE1); /* 配置内部上拉电阻 */
  ENABLE_PULLUP(PTE,PTE2); /* 配置内部上拉电阻 */
  ENABLE_PULLUP(PTE,PTE3); /* 配置内部上拉电阻 */
  ENABLE_PULLUP(PTE,PTE4); /* 配置内部上拉电阻 */
        SIM_SCGC |=  SIM_SCGC_KBI1_MASK; /* Enable bus clock on KBI0 */
        KBI1_SC = 0;                                    /* Clearing mechanism */
        KBI1_ES |= KBI_ES_KBEDG(0x00);   /* Polarity setting, falling edge low level,PTE0 */
        KBI1_PE |= KBI_PE_KBIPE(0x00);   /* Enable KBI1 channel 0 , PTE0 */
        KBI1_PE |= KBI_PE_KBIPE(0x01);   /* Enable KBI1 channel 1 , PTE1 */
  KBI1_PE |= KBI_PE_KBIPE(0x02);   /* Enable KBI1 channel 0 , PTE0 */
        KBI1_PE |= KBI_PE_KBIPE(0x03);   /* Enable KBI1 channel 1 , PTE1 */
  KBI1_PE |= KBI_PE_KBIPE(0x04);   /* Enable KBI1 channel 0 , PTE0 */
        KBI1_SC = 0;                                                               /* Clearing flags*/
        KBI1_SC |=KBI_SC_RSTKBSP_MASK;                        /* Clearing RSTKBSP bit*/
        KBI1_SC |= KBI_SC_KBIE_MASK;           /* Enable  KBI1 Interrupts */
  KBI_SetCallback(KBI1,KBI1_IRQHandler);         /* Set the KBI callback function to be called on each button press */
        NVIC_EnableIRQ(KBI1_IRQn);                    /* Enable KBI1 Interrupt */
void KBI1_IRQHandler()
KBI_Interrupt();
void KBI_Interrupt()
                KBI1_SC |= KBI_SC_KBACK_MASK;        /*Clear flag*/
power_on;
    Uart_SendChar(KBI1_SP);//Uart_SendChar(KBI1_SP);
        if((KBI1_SP & KBI_SP_SP(0x00))>>0) /* If SW1 has been pressed */
{row=1;
power_on;}
        else if((KBI1_SP & KBI_SP_SP(0x01))>>1) /* If SW2 has been pressed */
{row=2;power_down;
        else if((KBI1_SP & KBI_SP_SP(0x02))>>2) /* If SW2 has been pressed */
{row=3;
power_on;}
        else if((KBI1_SP & KBI_SP_SP(0x03))>>3) /* If SW2 has been pressed */
{row=4;power_down;
        else if((KBI1_SP & KBI_SP_SP(0x04))>>4) /* If SW2 has been pressed */
row=5;
我知道答案 目前已有0人回答
GMT+8, 2025-12-1 16:33 , Processed in 0.073412 second(s), 21 queries , Redis On.
