查看: 2116|回复: 2
[原创] 【MCX-A153分享】基于RT-Thread的硬件IIC驱动适配
  • 签到天数: 204 天
    发表于 2024-7-21 16:46:12 | 显示全部楼层 |阅读模式
    目前RT-Thread Studio尚未支持恩智浦FRDM-MCXA153开发板BSP,需要从gitee下载最新的主线,通过scons命令创建工程。下载好主线源码后,在rt-thread\bsp\nxp\mcx\mcxa\frdm-mcxa153 目录下打开scons环境,配置IIC驱动和SSD1306 OLED。
    一、IIC配置
    恩智浦FRDM-MCXA153开发板板载的mikroBUS socket预留一个IIC接口,具体可以从针脚图看到,下图红框处的针脚。
    NXP引入了一个Flexcomm概念,每个Flexcomm接口可通过软件选择作为USART、SPI或I2C接口。此处只需要在menuconfig中选择I2C0即可。
    因为FRDM-MCXA153的BSP目前只有pin和Uart的驱动,需要增加drv_i2c.c文件,直接从已有的BSP(如N947)拷贝过来,同时修改baud、clock_attach_id、clock_div_name初始化值。
    再修改pin mux的配置,首先在BOARD_InitPins函数中增加I2C0 reset实现:
    1. RESET_ReleasePeripheralReset(kLPI2C0_RST_SHIFT_RSTn);
    同时加上I2C0的SDA/SCL针脚初始化代码:
    1. const port_pin_config_t port3_27_pin34_config = {/* Internal pull-up resistor is enabled */
    2.           kPORT_PullUp,
    3.            /* Low internal pull resistor value is selected. */
    4.            kPORT_LowPullResistor,
    5.            /* Fast slew rate is configured */
    6.            kPORT_FastSlewRate,
    7.            /* Passive input filter is disabled */
    8.            kPORT_PassiveFilterDisable,
    9.            /* Open drain output is enabled */
    10.            kPORT_OpenDrainEnable,
    11.            /* Low drive strength is configured */
    12.            kPORT_LowDriveStrength,
    13.            /* Normal drive strength is configured */
    14.            kPORT_NormalDriveStrength,
    15.            /* Pin is configured as LPI2C0_SCL */
    16.            kPORT_MuxAlt2,
    17.            /* Digital input enabled */
    18.            kPORT_InputBufferEnable,
    19.            /* Digital input is not inverted */
    20.            kPORT_InputNormal,
    21.            /* Pin Control Register fields [15:0] are not locked */
    22.            kPORT_UnlockRegister};
    23.     /* PORT3_27 (pin 34) is configured as LPI2C0_SCL */
    24.     PORT_SetPinConfig(PORT3, 27U, &port3_27_pin34_config);
    25.     const port_pin_config_t port3_28_pin33_config = {/* Internal pull-up resistor is enabled */
    26.            kPORT_PullUp,
    27.            /* Low internal pull resistor value is selected. */
    28.            kPORT_LowPullResistor,
    29.            /* Fast slew rate is configured */
    30.            kPORT_FastSlewRate,
    31.            /* Passive input filter is disabled */
    32.            kPORT_PassiveFilterDisable,
    33.            /* Open drain output is enabled */
    34.            kPORT_OpenDrainEnable,
    35.            /* Low drive strength is configured */
    36.            kPORT_LowDriveStrength,
    37.            /* Normal drive strength is configured */
    38.            kPORT_NormalDriveStrength,
    39.            /* Pin is configured as LPI2C0_SDA */
    40.            kPORT_MuxAlt2,
    41.            /* Digital input enabled */
    42.            kPORT_InputBufferEnable,
    43.            /* Digital input is not inverted */
    44.            kPORT_InputNormal,
    45.            /* Pin Control Register fields [15:0] are not locked */
    46.            kPORT_UnlockRegister};
    47.     /* PORT3_28 (pin 33) is configured as LPI2C0_SDA */
    48.     PORT_SetPinConfig(PORT3, 28U, &port3_28_pin33_config);
    二、SSD1306 OLED配置
    在menuconfig中选择enable SSD1306,并且设置好I2C bus name,I2C的地址默认是0x3c无需修改。
    上述内容设置好之后,选择保存。分别执行下述2个命令:
    pkgs —update
    scons —target=mdk5
    待Keil工程生成后,打开工程编译程序。
    1. Program Size: Code=79916 RO-data=24408 RW-data=768 ZI-data=7700
    2. Finished: 0 information, 2 warning and 0 error messages.
    3. ".\build\rtthread.axf" - 0 Error(s), 2 Warning(s).
    4. Build Time Elapsed:  00:00:12
    然后下载到恩智浦FRDM-MCXA153开发板上。
    三、硬件IIC测试
    固件下载完成后,reset系统,还是熟悉的味道。
    1. \ | /
    2. - RT -     Thread Operating System
    3. / | \     5.2.0 build Jul 17 2024 23:16:53
    4. 2006 - 2024 Copyright by RT-Thread team
    5. I/I2C: I2C bus [i2c0] registered
    6. using armclang, version: 6180002
    7. MCXA153 HelloWorld
    8. msh >
    list device后,可以看到IIC已经起来:
    1. msh >list device
    2. device           type         ref count
    3. -------- -------------------- ----------
    4. i2c0     I2C Bus              0
    5. pin      Pin Device           0
    6. uart0    Character Device     2
    7. msh >
    因为之前在menuconfig选择ssd1306的时候同时选择了demo,跑起来。
    至此,基于RT-Thread的硬件IIC驱动适配完成。
    2025-2-21 12:40
  • 签到天数: 16 天
    发表于 2024-7-21 17:28:24 | 显示全部楼层
    rt-thread/bsp/nxp/mcx/mcxa/frdm-mcxa153/   RTT有支持吧,不过支持到啥程度就得自己拿板子玩了
  • 签到天数: 204 天
     楼主| 发表于 2024-7-21 17:53:19 | 显示全部楼层
    oxlm 发表于 2024-7-21 17:28
    rt-thread/bsp/nxp/mcx/mcxa/frdm-mcxa153/   RTT有支持吧,不过支持到啥程度就得自己拿板子玩了 ...
    只有 pin和UART
    没有IIC
    GMT+8, 2025-11-16 02:22 , Processed in 0.083719 second(s), 22 queries , MemCache On.
