在线时间466 小时
UID3547866
注册时间2022-4-24
NXP金币3397
TA的每日心情 | 开心 半小时前 |
签到天数: 1108 天 连续签到: 2 天 [LV.10]以坛为家III
- 5813
- 2025-8-4
发表于 2024-9-25 10:52:26
显示全部楼层
STM32驱动OV7670的代码:
#include "OV7670.h"
#include "delay.h"
#include "stm32f10x_lib.h"
// GND PIN1
// HREF PC8 PIN2
// VSYNC PIN3
// PWDN GND PIN4
// PCLK PC9 PIN5 没有用到
// AVDD 2.8V PIN6
// DVDD 2.8V PIN7
// SIOD PA6 PIN8
// XCLK1 PA8 PIN9
// SIOC PA7 PIN10
// D0 PC0 PIN11
// D1 PC1 PIN12
// D2 PC2 PIN13
// D3 PC3 PIN14
// GND PIN15
// D4 PC4 PIN16
// D5 PC5 PIN17
// D6 PC6 PIN18
// D7 PC7 PIN19
// RST GND PIN20
//extern const char change_reg[CHANGE_REG_NUM][2];
//功能:提供7670时钟
//返回:无
void CLK_init_ON(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
RCC_MCOConfig(RCC_MCO_HSE );//hsi
void CLK_init_OFF(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
void OV7670_GPIO_Init(void)
/* Enable GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = 0X0BFF;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;//GPIO_Mode_AF_OD GPIO_Mode_AF_PP GPIO_Mode_IPU GPIO_Mode_IN_FLOATING
//GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
void OV7670_GPIO_CONTRL_CONFIG(void)
GPIO_InitStructure.GPIO_Pin = LCD_HREF_BIT|LCD_VSYNC_BIT|LCD_PCLK_BIT;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//功能:写OV7670寄存器
//返回:1-成功 0-失败
unsigned char wrOV7670Reg(unsigned char regID, unsigned char regDat)
startSCCB();
if(0==SCCBwriteByte(0x42))
stopSCCB();
return(0);
delay_us(100);
if(0==SCCBwriteByte(regID))
stopSCCB();
return(0);
delay_us(100);
if(0==SCCBwriteByte(regDat))
stopSCCB();
return(0);
stopSCCB();
return(1);
//功能:读OV7670寄存器
//返回:1-成功 0-失败
unsigned char rdOV7670Reg(unsigned char regID, unsigned char *regDat)
//通过写操作设置寄存器地址
startSCCB();
stopSCCB();
return(0);
delay_us(100);
stopSCCB();
return(0);
stopSCCB();
delay_us(100);
//设置寄存器地址后,才是读
startSCCB();
if(0==SCCBwriteByte(0x43))
stopSCCB();
return(0);
delay_us(100);
*regDat=SCCBreadByte();
noAck();
stopSCCB();
return(1);
//(140,16,640,480) is good for VGA
//(272,16,320,240) is good for QVGA
/* config_OV7670_window */
void OV7670_config_window(unsigned int startx,unsigned int starty,unsigned int width, unsigned int height)
unsigned int endx;
unsigned int endy;// "v*2"必须
unsigned char temp_reg1, temp_reg2;
unsigned char temp=0;
endx=(startx+width);
endy=(starty+height+height);// "v*2"必须
rdOV7670Reg(0x03, &temp_reg1 );
temp_reg1 &= 0xf0;
rdOV7670Reg(0x32, &temp_reg2 );
temp_reg2 &= 0xc0;
// Horizontal
temp = temp_reg2|((endx&0x7)<<3)|(startx&0x7);
wrOV7670Reg(0x32, temp );
temp = (startx&0x7F8)>>3;
wrOV7670Reg(0x17, temp );
temp = (endx&0x7F8)>>3;
wrOV7670Reg(0x18, temp );
// Vertical
temp =temp_reg1|((endy&0x3)<<2)|(starty&0x3);
wrOV7670Reg(0x03, temp );
temp = starty>>2;
wrOV7670Reg(0x19, temp );
temp = endy>>2;
wrOV7670Reg(0x1A, temp );
set_OV7670reg(void)
wrOV7670Reg(0x8c, 0x00);
wrOV7670Reg(0x3a, 0x04);
wrOV7670Reg(0x40, 0xd0);
wrOV7670Reg(0x12, 0x14);
wrOV7670Reg(0x32, 0x80);
wrOV7670Reg(0x17, 0x16);
wrOV7670Reg(0x18, 0x04);
wrOV7670Reg(0x19, 0x02);
wrOV7670Reg(0x1a, 0x7b);
wrOV7670Reg(0x03, 0x06);
wrOV7670Reg(0x0c, 0x04);
wrOV7670Reg(0x3e, 0x00);
wrOV7670Reg(0x70, 0x3a);
wrOV7670Reg(0x71, 0x35);
wrOV7670Reg(0x72, 0x11);
wrOV7670Reg(0x73, 0x00);
wrOV7670Reg(0xa2, 0x00);
wrOV7670Reg(0x11, 0xff);
//wrOV7670Reg(0x15 , 0x31);
wrOV7670Reg(0x7a, 0x20);
wrOV7670Reg(0x7b, 0x1c);
wrOV7670Reg(0x7c, 0x28);
wrOV7670Reg(0x7d, 0x3c);
wrOV7670Reg(0x7e, 0x55);
wrOV7670Reg(0x7f, 0x68);
wrOV7670Reg(0x80, 0x76);
wrOV7670Reg(0x81, 0x80);
wrOV7670Reg(0x82, 0x88);
wrOV7670Reg(0x83, 0x8f);
wrOV7670Reg(0x84, 0x96);
wrOV7670Reg(0x85, 0xa3);
wrOV7670Reg(0x86, 0xaf);
wrOV7670Reg(0x87, 0xc4);
wrOV7670Reg(0x88, 0xd7);
wrOV7670Reg(0x89, 0xe8);
wrOV7670Reg(0x32,0xb6);
wrOV7670Reg(0x13, 0xff);
wrOV7670Reg(0x00, 0x00);
wrOV7670Reg(0x10, 0x00);
wrOV7670Reg(0x0d, 0x00);
wrOV7670Reg(0x14, 0x4e);
wrOV7670Reg(0xa5, 0x05);
wrOV7670Reg(0xab, 0x07);
wrOV7670Reg(0x24, 0x75);
wrOV7670Reg(0x25, 0x63);
wrOV7670Reg(0x26, 0xA5);
wrOV7670Reg(0x9f, 0x78);
wrOV7670Reg(0xa0, 0x68);
// wrOV7670Reg(0xa1, 0x03);//0x0b,
wrOV7670Reg(0xa6, 0xdf);
wrOV7670Reg(0xa7, 0xdf);
wrOV7670Reg(0xa8, 0xf0);
wrOV7670Reg(0xa9, 0x90);
wrOV7670Reg(0xaa, 0x94);
//wrOV7670Reg(0x13, 0xe5);
wrOV7670Reg(0x0e, 0x61);
wrOV7670Reg(0x0f, 0x43);
wrOV7670Reg(0x16, 0x02);
wrOV7670Reg(0x1e, 0x37);
wrOV7670Reg(0x21, 0x02);
wrOV7670Reg(0x22, 0x91);
wrOV7670Reg(0x29, 0x07);
wrOV7670Reg(0x33, 0x0b);
wrOV7670Reg(0x35, 0x0b);
wrOV7670Reg(0x37, 0x3f);
wrOV7670Reg(0x38, 0x01);
wrOV7670Reg(0x39, 0x00);
wrOV7670Reg(0x3c, 0x78);
wrOV7670Reg(0x4d, 0x40);
wrOV7670Reg(0x4e, 0x20);
wrOV7670Reg(0x69, 0x00);
wrOV7670Reg(0x6b, 0x4a);
wrOV7670Reg(0x74, 0x19);
wrOV7670Reg(0x8d, 0x4f);
wrOV7670Reg(0x8e, 0x00);
wrOV7670Reg(0x8f, 0x00);
wrOV7670Reg(0x90, 0x00);
wrOV7670Reg(0x91, 0x00);
wrOV7670Reg(0x92, 0x00);
wrOV7670Reg(0x96, 0x00);
wrOV7670Reg(0x9a, 0x80);
wrOV7670Reg(0xb0, 0x84);
wrOV7670Reg(0xb1, 0x0c);
wrOV7670Reg(0xb2, 0x0e);
wrOV7670Reg(0xb3, 0x82);
wrOV7670Reg(0xb8, 0x0a);
wrOV7670Reg(0x43, 0x14);
wrOV7670Reg(0x44, 0xf0);
wrOV7670Reg(0x45, 0x34);
wrOV7670Reg(0x46, 0x58);
wrOV7670Reg(0x47, 0x28);
wrOV7670Reg(0x48, 0x3a);
wrOV7670Reg(0x59, 0x88);
wrOV7670Reg(0x5a, 0x88);
wrOV7670Reg(0x5b, 0x44);
wrOV7670Reg(0x5c, 0x67);
wrOV7670Reg(0x5d, 0x49);
wrOV7670Reg(0x5e, 0x0e);
wrOV7670Reg(0x64, 0x04);
wrOV7670Reg(0x65, 0x20);
wrOV7670Reg(0x66, 0x05);
wrOV7670Reg(0x94, 0x04);
wrOV7670Reg(0x95, 0x08);
wrOV7670Reg(0x6c, 0x0a);
wrOV7670Reg(0x6d, 0x55);
wrOV7670Reg(0x6e, 0x11);
wrOV7670Reg(0x6f, 0x9f);
wrOV7670Reg(0x6a, 0x40);
wrOV7670Reg(0x01, 0x40);
wrOV7670Reg(0x02, 0x40);
//wrOV7670Reg(0x13, 0xe7);
wrOV7670Reg(0x15, 0x00);
wrOV7670Reg(0x4f, 0x80);
wrOV7670Reg(0x50, 0x80);
wrOV7670Reg(0x51, 0x00);
wrOV7670Reg(0x52, 0x22);
wrOV7670Reg(0x53, 0x5e);
wrOV7670Reg(0x54, 0x80);
wrOV7670Reg(0x58, 0x9e);
wrOV7670Reg(0x41, 0x08);
wrOV7670Reg(0x3f, 0x00);
wrOV7670Reg(0x75, 0x05);
wrOV7670Reg(0x76, 0xe1);
wrOV7670Reg(0x4c, 0x00);
wrOV7670Reg(0x77, 0x01);
wrOV7670Reg(0x3d, 0xc1);
wrOV7670Reg(0x4b, 0x09);
wrOV7670Reg(0xc9, 0x60);
//wrOV7670Reg(0x41, 0x38);
wrOV7670Reg(0x56, 0x40);
wrOV7670Reg(0x34, 0x11);
wrOV7670Reg(0x3b, 0x02);
wrOV7670Reg(0xa4, 0x89);
wrOV7670Reg(0x97, 0x30);
wrOV7670Reg(0x98, 0x20);
wrOV7670Reg(0x99, 0x30);
wrOV7670Reg(0x9a, 0x84);
wrOV7670Reg(0x9b, 0x29);
wrOV7670Reg(0x9c, 0x03);
wrOV7670Reg(0x9d, 0x4c);
wrOV7670Reg(0x9e, 0x3f);
wrOV7670Reg(0x09, 0x00);
wrOV7670Reg(0x3b, 0xc2);
/* OV7670_init() */
//返回1成功,返回0失败
unsigned char OV7670_init(void)
unsigned char temp;
unsigned int i=0;
OV7670_GPIO_Init();
OV7670_GPIO_CONTRL_CONFIG();
SCCB_GPIO_Config(); // io init..
CLK_init_ON();
temp=0x80;
if(0==wrOV7670Reg(0x12, temp)) //Reset SCCB
return 0 ;
delay_ms(100);
set_OV7670reg();
OV7670_config_window(272,12,320,240);// set 240*320
return 0x01; //ok
