查看: 758|回复: 0
[求助] sct 定时
发表于 2024-11-28 13:00:12 | 显示全部楼层 |阅读模式
示例程序如下,led是100ms闪烁一次,肉眼无法分辨
#define delay (SystemCoreClock/10)
1. Use SCT timer to generate a 100 msec toggle output @CTOUT_0
2. CTOUT_0 is linked to P0_12 (Red LED) and toggles every 100 msec)
主程序如下
int main(void)
  /* Enter an infinite loop, just incrementing a counter */
    volatile static int i = 0 ;
        /* Generic Initialization */
        SystemCoreClockUpdate();
        Board_Init();
        Chip_SWM_Init();        /* Configure the switch matrix    */
        Chip_SWM_MovablePinAssign(SWM_SCT_OUT0_O,15);        /* configure the SWM to output CTOUT_0 to PIO0_12 */
        sct_fsm_init();                                              /* Initialize the SCT using the code generated by Red State */
    while(1)
        i++ ;
        __WFI();
我想修改成1000ms也就是1s,
#define delay (SystemCoreClock/10)   感觉就是修改这句,但是放大缩小led一直长亮
哪里不对呢
我知道答案 目前已有0人回答
GMT+8, 2025-11-5 09:21 , Processed in 0.082195 second(s), 21 queries , MemCache On.
