查看: 1711|回复: 0
[求助] S32K312 WPC 产品样机 PE(Multilink)Debug 烧录 fail 求助帖
发表于 2024-12-4 20:54:06 | 显示全部楼层 |阅读模式
S32DS 提示信息及报错图片如下:
  1. Connection from "127.0.0.1" via 127.0.0.1. Connection from port "2801" to 6224
  2. Connection from "127.0.0.1" via 127.0.0.1. Connection from port "2802" to 7224
  3. Telnet server running on 127.0.0.1:51794
  4. Searching for Kernel Symbols...
  5. rsp_qC - qSymbol: 5F74785F7468726561645F63757272656E745F707472
  6.   _tx_thread_current_ptr not found. ThreadX analysis not enabled.
  7. rsp_qC - qSymbol: 707843757272656E74544342
  8.   pxCurrentTCB not found. FreeRTOS analysis not enabled.
  9. Unable to load libusb0.dll
  10. Copyright 2024 P&E Microcomputer Systems,Inc.
  11. Command Line :D:\work\NXP\S32DS.3.5\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_5.9.3.202411271449\win32\pegdbserver_console -device=NXP_S32K3xx_S32K312 -startserver -singlesession -serverport=7224 -gdbmiport=6224 -interface=USBMULTILINK -speed=5000 -p
  12. PEmicro Interface detected - Flash Version 11.37
  13. CMD>RE
  14. Initializing.
  15. INFO: DAP IDCODE = 0x6BA02477
  16. INFO: DAP successfully powered up. DP CTRL/STAT = 0xF0000040
  17. Target has been RESET and is active.
  18. CMD>CM D:\work\NXP\S32DS.3.5\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_5.9.3.202411271449\support***_ARM\NXP\S32K3xx\nxp_s32k312_1x32x456k_hse_enabled.arp
  19. Initializing.
  20. INFO: DAP IDCODE = 0x6BA02477
  21. INFO: DAP successfully powered up. DP CTRL/STAT = 0xF0000040
  22. Initialized.
  23. ;version 1.04, 11/05/2024, Copyright 2024 P&E Microcomputer Systems, www.pemicro.com [S32K3x2_hse_enabled]
  24. ;device nxp, s32k312, 1x32x456k,desc=hse_enabled
  25. ;begin_cs device=$00400000, length=$001D4000, ram=$20400000
  26. Loading programming algorithm ...
  27. Error enabling module, part timed out during buffer initialization.
  28. Error loading programming algorithm - load aborted.
  29. Error occured during Flash programming.
  30. INFO: DAP IDCODE = 0x6BA02477
  31. INFO: DAP successfully powered up. DP CTRL/STAT = 0xF0000040
  32. BusFault: An imprecise (asynchronous) data access error has occurred.
  33. BusFault: A precise (synchronous) data access error has occurred.
  34. Possible BusFault location: 0xDB52060C.
  35. HardFault: A fault has been escalated to a hard fault.
  36. Warning - device did not halt out of reset. Stopping core.
  37. Starting reset script (D:\work\NXP\S32DS.3.5\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_5.9.3.202411271449\support***_ARM\NXP\S32K3xx\S32K312.mac) ...
  38. REM Enable clocks for selected cores in MC_ME module
  39. Delaying for 200mS ...
  40. Done.
  41. REM Initialize RAM and DMA:
  42. REM Initialize DMA TCD:
  43. REM Copy valid executable code to RAM for each core to be used.
  44. REM Enable required cores in MC_ME:
  45. Delaying for 20mS ...
  46. Done.
  47. Reset script (D:\work\NXP\S32DS.3.5\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_5.9.3.202411271449\support***_ARM\NXP\S32K3xx\S32K312.mac) completed.
  48. PEmicro GDB Launch Failure : Error during flash programming. Terminating debug session.
  49. PE-ERROR: Error downloading to the device. Terminating debug session.
  50. Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "2801" from 6224
  51. Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "2802" from 7224
  52. INFO: DAP IDCODE = 0x6BA02477
  53. Target Disconnected.
GMT+8, 2026-5-1 02:45 , Processed in 0.077441 second(s), 19 queries , Redis On.
