查看: 1508|回复: 1
[分享] 【MCXC444分享】 运行FreeRTOS
    前天 19:59
  • 签到天数: 1610 天
    连续签到: 10 天
    发表于 2024-12-6 22:34:07 | 显示全部楼层 |阅读模式
    一、下载源码
    FreeRTOS源码
    下载地址:https://github.com/FreeRTOS/Free ... eRTOSv202212.01.zip
    二、添加源码到工程
    2.1、添加FreeRTOS源码到工程
    三、程序代码
    3.1、task.c
    1. #include "main.h"
    2. #define START_TASK_PRO                1
    3. #define START_STK_SIZE                128
    4. TaskHandle_t StartTask_Handler;
    5. #define TASK1_PRIO      2
    6. #define TASK1_STK_SIZE  128
    7. static TaskHandle_t            Task1Task_Handler = NULL;
    8.
    9. #define TASK2_PRIO      3
    10. #define TASK2_STK_SIZE  128
    11. static TaskHandle_t            Task2Task_Handler = NULL;
    12. #define TASK3_PRIO      4
    13. #define TASK3_STK_SIZE  128
    14. static TaskHandle_t            Task3Task_Handler = NULL;
    15. void start_task(void *pvParameters);
    16. void task1(void *pvParameters);
    17. void task2(void *pvParameters);
    18. void task3(void *pvParameters);
    19. void task_create(void)
    20. {
    21.
    22.         //start_task
    23.         xTaskCreate((TaskFunction_t )start_task,
    24.                                                         (const char*    )"start_task",
    25.                                                         (uint16_t       )START_STK_SIZE,
    26.                                                         (void*          )NULL,
    27.                                                         (UBaseType_t    )START_TASK_PRO,
    28.                                                         (TaskHandle_t*  )&StartTask_Handler);
    29.         vTaskStartScheduler();
    30. }
    31. void start_task(void *pvParameters)
    32. {
    33.         taskENTER_CRITICAL();
    34.         //task1
    35.         xTaskCreate((TaskFunction_t )task1,
    36.                                                         (const char*    )"task1",
    37.                                                         (uint16_t       )TASK1_STK_SIZE,
    38.                                                         (void*          )NULL,
    39.                                                         (UBaseType_t    )TASK1_PRIO,
    40.                                                         (TaskHandle_t*  )&Task1Task_Handler);
    41.         //task2
    42.         xTaskCreate((TaskFunction_t )task2,
    43.                                                         (const char*    )"task2",
    44.                                                         (uint16_t       )TASK2_STK_SIZE,
    45.                                                         (void*          )NULL,
    46.                                                         (UBaseType_t    )TASK2_PRIO,
    47.                                                         (TaskHandle_t*  )&Task2Task_Handler);
    48.
    49.         //task3
    50.         xTaskCreate((TaskFunction_t )task3,
    51.                                                         (const char*    )"task3",
    52.                                                         (uint16_t       )TASK3_STK_SIZE,
    53.                                                         (void*          )NULL,
    54.                                                         (UBaseType_t    )TASK3_PRIO,
    55.                                                         (TaskHandle_t*  )&Task3Task_Handler);
    56.         taskEXIT_CRITICAL();
    57.         vTaskDelete(StartTask_Handler);
    58. }
    59. //task1
    60. void task1(void *pvParameters)
    61. {
    62.     while (1)
    63.     {
    64.                                 rgbled_red_tog();
    65.         PRINTF("任务1运行 ...\r\n");
    66.         vTaskDelay(100);
    67.     }
    68. }
    69. //task2
    70. void task2(void *pvParameters)
    71. {
    72.     while (1)
    73.     {
    74.                                 rgbled_green_tog();
    75.         PRINTF("任务2运行 ...\r\n");
    76.         vTaskDelay(200);
    77.     }
    78. }
    79. //task3
    80. void task3(void *pvParameters)
    81. {
    82.     while (1)
    83.     {
    84.                                 rgbled_blue_tog();
    85.         PRINTF("任务3运行 ...\r\n");
    86.         vTaskDelay(300);
    87.     }
    88. }
    3.2、main.c
    2. void init_board(void)
    3. {
    4.         BOARD_InitPins();
    5.         BOARD_BootClockRUN();
    6.         BOARD_InitDebugConsole();
    7.         init_led();
    8. }
    9. int main(void)
    10. {
    11.         uint32_t m_adv=0;
    12.         float vl= 0.0f;
    13.
    14.         init_board();
    15.
    16.         task_create();
    17.         while (1)
    18.         {
    19.         }
    20. }
    四、程序运行
    串口输出运行结果
    昨天 14:38
  • 签到天数: 1546 天
    连续签到: 10 天
    发表于 2024-12-7 20:39:08 | 显示全部楼层
    嘿嘿,就喜欢FreeRTOS
    GMT+8, 2026-3-15 00:37 , Processed in 0.079955 second(s), 20 queries , Redis On.
