查看: 1353|回复: 2
[分享] 【庆典三:项目速成设计】MCXN947-温度传感器动态显示
  • 签到天数: 471 天
    发表于 2024-12-9 11:57:27 | 显示全部楼层 |阅读模式
    本次设计一个传感器数据动态展示界面,并且添加时间信息。
    生成针对KEIL工具链的代码,然后再打开工程。在setup_scr_screen.c源文件里面可以看到UI相关组件的代码。
    1. void setup_scr_screen(lv_ui *ui)
    2. {
    3.         //Write codes screen
    4.         ui->screen = lv_obj_create(NULL);
    5.         lv_obj_set_size(ui->screen, 480, 320);
    6.         lv_obj_set_scrollbar_mode(ui->screen, LV_SCROLLBAR_MODE_OFF);
    7.         //Write style for screen, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
    8.         lv_obj_set_style_bg_opa(ui->screen, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    9.         //Write codes screen_nxpChart
    10.         ui->screen_nxpChart = lv_chart_create(ui->screen);
    11.         lv_chart_set_type(ui->screen_nxpChart, LV_CHART_TYPE_LINE);
    12.         lv_chart_set_div_line_count(ui->screen_nxpChart, 3, 5);
    13.         lv_chart_set_point_count(ui->screen_nxpChart, 5);
    14.         lv_chart_set_range(ui->screen_nxpChart, LV_CHART_AXIS_PRIMARY_Y, 0, 100);
    15.         lv_chart_set_axis_tick(ui->screen_nxpChart, LV_CHART_AXIS_PRIMARY_Y, 10, 5, 5, 4, true, 40);
    16.         lv_chart_set_range(ui->screen_nxpChart, LV_CHART_AXIS_SECONDARY_Y, 0, 100);
    17.         lv_chart_set_axis_tick(ui->screen_nxpChart, LV_CHART_AXIS_PRIMARY_X, 10, 5, 5, 4, true, 40);
    18.         lv_chart_set_zoom_x(ui->screen_nxpChart, 256);
    19.         lv_chart_set_zoom_y(ui->screen_nxpChart, 256);
    20.         ui->screen_nxpChart_0 = lv_chart_add_series(ui->screen_nxpChart, lv_color_hex(0x000000), LV_CHART_AXIS_PRIMARY_Y);
    21. #if LV_USE_FREEMASTER == 0
    22.         lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 1);
    23.         lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 20);
    24.         lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 30);
    25.         lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 40);
    26.         lv_chart_set_next_value(ui->screen_nxpChart, ui->screen_nxpChart_0, 5);
    27. #endif
    28.         lv_obj_set_pos(ui->screen_nxpChart, 34, 24);
    29.         lv_obj_set_size(ui->screen_nxpChart, 411, 273);
    30.         lv_obj_set_scrollbar_mode(ui->screen_nxpChart, LV_SCROLLBAR_MODE_OFF);
    31.         //Write style for screen_nxpChart, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
    32.         lv_obj_set_style_bg_opa(ui->screen_nxpChart, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    33.         lv_obj_set_style_bg_color(ui->screen_nxpChart, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
    34.         lv_obj_set_style_bg_grad_dir(ui->screen_nxpChart, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
    35.         lv_obj_set_style_border_width(ui->screen_nxpChart, 1, LV_PART_MAIN|LV_STATE_DEFAULT);
    36.         lv_obj_set_style_border_opa(ui->screen_nxpChart, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    37.         lv_obj_set_style_border_color(ui->screen_nxpChart, lv_color_hex(0xe8e8e8), LV_PART_MAIN|LV_STATE_DEFAULT);
    38.         lv_obj_set_style_border_side(ui->screen_nxpChart, LV_BORDER_SIDE_FULL, LV_PART_MAIN|LV_STATE_DEFAULT);
    39.         lv_obj_set_style_radius(ui->screen_nxpChart, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    40.         lv_obj_set_style_line_width(ui->screen_nxpChart, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
    41.         lv_obj_set_style_line_color(ui->screen_nxpChart, lv_color_hex(0xe8e8e8), LV_PART_MAIN|LV_STATE_DEFAULT);
    42.         lv_obj_set_style_line_opa(ui->screen_nxpChart, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    43.         lv_obj_set_style_shadow_width(ui->screen_nxpChart, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    44.         //Write style for screen_nxpChart, Part: LV_PART_TICKS, State: LV_STATE_DEFAULT.
    45.         lv_obj_set_style_text_color(ui->screen_nxpChart, lv_color_hex(0x151212), LV_PART_TICKS|LV_STATE_DEFAULT);
    46.         lv_obj_set_style_text_font(ui->screen_nxpChart, &lv_font_montserratMedium_12, LV_PART_TICKS|LV_STATE_DEFAULT);
    47.         lv_obj_set_style_text_opa(ui->screen_nxpChart, 255, LV_PART_TICKS|LV_STATE_DEFAULT);
    48.         lv_obj_set_style_line_width(ui->screen_nxpChart, 2, LV_PART_TICKS|LV_STATE_DEFAULT);
    49.         lv_obj_set_style_line_color(ui->screen_nxpChart, lv_color_hex(0xe8e8e8), LV_PART_TICKS|LV_STATE_DEFAULT);
    50.         lv_obj_set_style_line_opa(ui->screen_nxpChart, 255, LV_PART_TICKS|LV_STATE_DEFAULT);
    51.         //Write codes screen_label_1
    52.         ui->screen_label_1 = lv_label_create(ui->screen);
    53.         lv_label_set_text(ui->screen_label_1, "NXP MCXN947 Cool");
    54.         lv_label_set_long_mode(ui->screen_label_1, LV_LABEL_LONG_WRAP);
    55.         lv_obj_set_pos(ui->screen_label_1, 112, 6);
    56.         lv_obj_set_size(ui->screen_label_1, 245, 23);
    57.         //Write style for screen_label_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
    58.         lv_obj_set_style_border_width(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    59.         lv_obj_set_style_radius(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    60.         lv_obj_set_style_text_color(ui->screen_label_1, lv_color_hex(0x000000), LV_PART_MAIN|LV_STATE_DEFAULT);
    61.         lv_obj_set_style_text_font(ui->screen_label_1, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
    62.         lv_obj_set_style_text_opa(ui->screen_label_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    63.         lv_obj_set_style_text_letter_space(ui->screen_label_1, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
    64.         lv_obj_set_style_text_line_space(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    65.         lv_obj_set_style_text_align(ui->screen_label_1, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN|LV_STATE_DEFAULT);
    66.         lv_obj_set_style_bg_opa(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    67.         lv_obj_set_style_pad_top(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    68.         lv_obj_set_style_pad_right(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    69.         lv_obj_set_style_pad_bottom(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    70.         lv_obj_set_style_pad_left(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    71.         lv_obj_set_style_shadow_width(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    72.         //Write codes screen_digital_clock_1
    73.         static bool screen_digital_clock_1_timer_enabled = false;
    74.         ui->screen_digital_clock_1 = lv_dclock_create(ui->screen, "11:25:50 AM");
    75.         if (!screen_digital_clock_1_timer_enabled) {
    76.                 lv_timer_create(screen_digital_clock_1_timer, 1000, NULL);
    77.                 screen_digital_clock_1_timer_enabled = true;
    78.         }
    79.         lv_obj_set_pos(ui->screen_digital_clock_1, 289, 56);
    80.         lv_obj_set_size(ui->screen_digital_clock_1, 130, 36);
    81.         //Write style for screen_digital_clock_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
    82.         lv_obj_set_style_radius(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    83.         lv_obj_set_style_text_color(ui->screen_digital_clock_1, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
    84.         lv_obj_set_style_text_font(ui->screen_digital_clock_1, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
    85.         lv_obj_set_style_text_opa(ui->screen_digital_clock_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    86.         lv_obj_set_style_text_letter_space(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    87.         lv_obj_set_style_text_align(ui->screen_digital_clock_1, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN|LV_STATE_DEFAULT);
    88.         lv_obj_set_style_bg_opa(ui->screen_digital_clock_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    89.         lv_obj_set_style_bg_color(ui->screen_digital_clock_1, lv_color_hex(0x2195f6), LV_PART_MAIN|LV_STATE_DEFAULT);
    90.         lv_obj_set_style_bg_grad_dir(ui->screen_digital_clock_1, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
    91.         lv_obj_set_style_pad_top(ui->screen_digital_clock_1, 7, LV_PART_MAIN|LV_STATE_DEFAULT);
    92.         lv_obj_set_style_pad_right(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    93.         lv_obj_set_style_pad_bottom(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    94.         lv_obj_set_style_pad_left(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    95.         lv_obj_set_style_shadow_width(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    96.         //The custom code of screen.
    97.         //Update current screen layout.
    98.         lv_obj_update_layout(ui->screen);
    99. }
    在上段代码的倒数第二行,增加如下代码,来动态更新图表数据。
    1.         chart = ui->screen_nxpChart;
    2.         chart_ser1 = ui->screen_nxpChart_0;
    3.         lv_chart_set_update_mode(ui->screen_nxpChart,LV_CHART_UPDATE_MODE_SHIFT);     //设置循环刷新
    4.         lv_timer_create(add_data, 1, NULL);
    本段代码创建了一个LVGL的内部定时间,单位是毫秒。该回调函数的实现如下:
    1. static void add_data(lv_timer_t * timer)
    2. {
    3.     LV_UNUSED(timer);
    4.     static uint32_t cnt = 0;
    5.     lv_chart_set_next_value(chart, chart_ser1, lv_rand(20, 90));
    6.     cnt++;
    7. }
    这样就可以使用随机数来验证图表是否能正常刷新显示。
    数字时钟的UI代码如下:
    1.         //Write codes screen_digital_clock_1
    2.         static bool screen_digital_clock_1_timer_enabled = false;
    3.         ui->screen_digital_clock_1 = lv_dclock_create(ui->screen, "11:25:50 AM");
    4.         if (!screen_digital_clock_1_timer_enabled) {
    5.                 lv_timer_create(screen_digital_clock_1_timer, 1000, NULL);
    6.                 screen_digital_clock_1_timer_enabled = true;
    7.         }
    8.         lv_obj_set_pos(ui->screen_digital_clock_1, 289, 56);
    9.         lv_obj_set_size(ui->screen_digital_clock_1, 130, 36);
    10.         //Write style for screen_digital_clock_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
    11.         lv_obj_set_style_radius(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    12.         lv_obj_set_style_text_color(ui->screen_digital_clock_1, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
    13.         lv_obj_set_style_text_font(ui->screen_digital_clock_1, &lv_font_montserratMedium_16, LV_PART_MAIN|LV_STATE_DEFAULT);
    14.         lv_obj_set_style_text_opa(ui->screen_digital_clock_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    15.         lv_obj_set_style_text_letter_space(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    16.         lv_obj_set_style_text_align(ui->screen_digital_clock_1, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN|LV_STATE_DEFAULT);
    17.         lv_obj_set_style_bg_opa(ui->screen_digital_clock_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
    18.         lv_obj_set_style_bg_color(ui->screen_digital_clock_1, lv_color_hex(0x2195f6), LV_PART_MAIN|LV_STATE_DEFAULT);
    19.         lv_obj_set_style_bg_grad_dir(ui->screen_digital_clock_1, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
    20.         lv_obj_set_style_pad_top(ui->screen_digital_clock_1, 7, LV_PART_MAIN|LV_STATE_DEFAULT);
    21.         lv_obj_set_style_pad_right(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    22.         lv_obj_set_style_pad_bottom(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    23.         lv_obj_set_style_pad_left(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    24.         lv_obj_set_style_shadow_width(ui->screen_digital_clock_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
    实物效果:
    可以看到数字时钟正常运行,动态图表可以显示随机数,刷新时候无闪烁,非常不错!
    接下来把开发板的I3C传感器数据采集过来,动态展示。
    初始化相关的PIN脚:
    1.     const port_pin_config_t port1_11_pinD3_config = {/* Internal pull-up/down resistor is disabled */
    2.                                                      kPORT_PullDisable,
    3.                                                      /* Low internal pull resistor value is selected. */
    4.                                                      kPORT_LowPullResistor,
    5.                                                      /* Fast slew rate is configured */
    6.                                                      kPORT_FastSlewRate,
    7.                                                      /* Passive input filter is disabled */
    8.                                                      kPORT_PassiveFilterDisable,
    9.                                                      /* Open drain output is disabled */
    10.                                                      kPORT_OpenDrainDisable,
    11.                                                      /* Low drive strength is configured */
    12.                                                      kPORT_LowDriveStrength,
    13.                                                      /* Pin is configured as I3C1_PUR */
    14.                                                      kPORT_MuxAlt10,
    15.                                                      /* Digital input enabled */
    16.                                                      kPORT_InputBufferEnable,
    17.                                                      /* Digital input is not inverted */
    18.                                                      kPORT_InputNormal,
    19.                                                      /* Pin Control Register fields [15:0] are not locked */
    20.                                                      kPORT_UnlockRegister};
    21.     /* PORT1_11 (pin D3) is configured as I3C1_PUR */
    22.     PORT_SetPinConfig(PORT1, 11U, &port1_11_pinD3_config);
    23.     const port_pin_config_t port1_16_pinF6_config = {/* Internal pull-up resistor is enabled */
    24.                                                      kPORT_PullUp,
    25.                                                      /* Low internal pull resistor value is selected. */
    26.                                                      kPORT_LowPullResistor,
    27.                                                      /* Fast slew rate is configured */
    28.                                                      kPORT_FastSlewRate,
    29.                                                      /* Passive input filter is disabled */
    30.                                                      kPORT_PassiveFilterDisable,
    31.                                                      /* Open drain output is disabled */
    32.                                                      kPORT_OpenDrainDisable,
    33.                                                      /* Low drive strength is configured */
    34.                                                      kPORT_LowDriveStrength,
    35.                                                      /* Pin is configured as I3C1_SDA */
    36.                                                      kPORT_MuxAlt10,
    37.                                                      /* Digital input enabled */
    38.                                                      kPORT_InputBufferEnable,
    39.                                                      /* Digital input is not inverted */
    40.                                                      kPORT_InputNormal,
    41.                                                      /* Pin Control Register fields [15:0] are not locked */
    42.                                                      kPORT_UnlockRegister};
    43.     /* PORT1_16 (pin F6) is configured as I3C1_SDA */
    44.     PORT_SetPinConfig(PORT1, 16U, &port1_16_pinF6_config);
    45.     const port_pin_config_t port1_17_pinF4_config = {/* Internal pull-up resistor is enabled */
    46.                                                      kPORT_PullUp,
    47.                                                      /* Low internal pull resistor value is selected. */
    48.                                                      kPORT_LowPullResistor,
    49.                                                      /* Fast slew rate is configured */
    50.                                                      kPORT_FastSlewRate,
    51.                                                      /* Passive input filter is disabled */
    52.                                                      kPORT_PassiveFilterDisable,
    53.                                                      /* Open drain output is disabled */
    54.                                                      kPORT_OpenDrainDisable,
    55.                                                      /* Low drive strength is configured */
    56.                                                      kPORT_LowDriveStrength,
    57.                                                      /* Pin is configured as I3C1_SCL */
    58.                                                      kPORT_MuxAlt10,
    59.                                                      /* Digital input enabled */
    60.                                                      kPORT_InputBufferEnable,
    61.                                                      /* Digital input is not inverted */
    62.                                                      kPORT_InputNormal,
    63.                                                      /* Pin Control Register fields [15:0] are not locked */
    64.                                                      kPORT_UnlockRegister};
    65.     /* PORT1_17 (pin F4) is configured as I3C1_SCL */
    66.     PORT_SetPinConfig(PORT1, 17U, &port1_17_pinF4_config);
    2. {
    3.      static double temperature;
    4.       LV_UNUSED(timer);
    5.       P3T1755_ReadTemperature(&p3t1755Handle, &temperature);
    6.       lv_chart_set_next_value(chart, chart_ser1, temperature);
    7. }
    用手触摸温度传感器,数据动态变化。
    至此完成了第一个基于GUI Guider设计的温度传感器采集展示小项目。
    happy!
    发表于 2024-12-10 16:12:24 | 显示全部楼层
    先完成一个小目标
  • 签到天数: 471 天
     楼主| 发表于 2024-12-10 22:26:37 | 显示全部楼层
    NXP管管 发表于 2024-12-10 16:12
    先完成一个小目标
    happy!
    GMT+8, 2026-4-5 00:09 , Processed in 0.092631 second(s), 22 queries , Redis On.
