查看: 1073|回复: 1
[求助] UART DMA中断发送
发表于 2024-12-30 16:30:30 | 显示全部楼层 |阅读模式
最近使用MKV30F64实现UART DMA的收发功能,发现进入接收中断后,会出现没有数据回复。
如果我在中断中添加多个case时,当接收数据变化时会出现回复数据与接受数据错位。求大佬们帮忙解答!!!
/* Definition of peripheral ID */
#define UART0_PERIPHERAL            UART0
/* Definition of the clock source frequency */
#define UART0_CLOCK_SOURCE          CLOCK_GetFreq(UART0_CLK_SRC)
/* UART0 eDMA source request. */
#define UART0_RX_DMA_REQUEST        kDmaRequestMux0UART0Rx
/* Selected eDMA channel number. */
#define UART0_RX_DMA_CHANNEL        2
#define UART0_TX_DMA_REQUEST        kDmaRequestMux0UART0Tx
#define UART0_TX_DMA_CHANNEL        3
#define UART_IRQn                   UART0_RX_TX_IRQn
#define UART_IRQ_PRIORITY           0
#define UART_IRQHandler             UART0_RX_TX_IRQHandler
* UART0 initialization code
/* clang-format off */
const uart_config_t UART0_config = {
  .baudRate_Bps = 2500000UL,
  .parityMode = kUART_ParityDisabled,
  .txFifoWatermark = 0U,
  .rxFifoWatermark = 1U,
  .idleType = kUART_IdleTypeStartBit,
   .enableTx = true,
  .enableRx = true
edma_handle_t UART0_RX_Handle;
edma_handle_t UART0_TX_Handle;
uart_edma_handle_t UART0_UART_eDMA_Handle;
static void UART0_init(void)
    /* Configure DMAMUX */
    DMAMUX_Init(DMA_DMAMUX_BASEADDR);
    EDMA_Init(DMA_DMA_BASEADDR, &DMA_config);
    UART_Init(UART0_PERIPHERAL, &UART0_config, UART0_CLOCK_SOURCE);
    /* Set the source kDmaRequestMux0UART0Rx request in the DMAMUX */
    DMAMUX_SetSource(DMA_DMAMUX_BASEADDR, UART0_RX_DMA_CHANNEL, UART0_RX_DMA_REQUEST);
    /* Enable the channel 2 in the DMAMUX */
    DMAMUX_EnableChannel(DMA_DMAMUX_BASEADDR, UART0_RX_DMA_CHANNEL);
   /* Set the source kDmaRequestMux0UART0Tx request in the DMAMUX */
    DMAMUX_SetSource(DMA_DMAMUX_BASEADDR, UART0_TX_DMA_CHANNEL, UART0_TX_DMA_REQUEST);
    /* Enable the channel 3 in the DMAMUX */
    DMAMUX_EnableChannel(DMA_DMAMUX_BASEADDR, UART0_TX_DMA_CHANNEL);
    /* Create the eDMA UART0_RX_Handle handle */
    EDMA_CreateHandle(&UART0_RX_Handle, DMA_DMA_BASEADDR, UART0_RX_DMA_CHANNEL);
    /* Create the eDMA UART0_TX_Handle handle */
    EDMA_CreateHandle(&UART0_TX_Handle, DMA_DMA_BASEADDR, UART0_TX_DMA_CHANNEL);
    /* Create the UART eDMA handle */
    UART_TransferCreateHandleEDMA(UART0_PERIPHERAL, &UART0_UART_eDMA_Handle, UART_UserCallback, NULL, &UART0_TX_Handle,         &UART0_RX_Handle);
    /* Interrupt vector DMA0_IRQn priority sets in the NVIC.*/
    NVIC_SetPriority(DMA_DMA_CH_INT_DONE_0_IRQN, DMA_DMA_CH_INT_DONE_0_IRQ_PRIORITY);
    NVIC_SetPriority(UART_IRQn, 0);
    UART_EnableInterrupts(UART0_PERIPHERAL, kUART_RxDataRegFullInterruptEnable |kUART_RxOverrunInterruptEnable);
    EnableIRQ(UART_IRQn);
void UART_IRQHandler(void)
   uint8_t  data   = 0;
   edma_transfer_config_t sendXferConfig;
   if(0 != ((UART0_PERIPHERAL->S1) & UART_S1_RDRF_MASK))
        //UART_ClearStatusFlags(UART0_PERIPHERAL,(uint32_t)kUART_RxDataRegFullFlag);
        data = UART0_PERIPHERAL->D;
        switch(data)
            case 0x92:
                data_Buffer[0] = 0x92;
                data_Buffer[1] = 0x20;
                data_Buffer[2] = 0x11;
                data_Buffer[3] = 0xA6;
                /* 发送长度 */
                    UART0_UART_eDMA_Handle.txDataSizeAll = 4U;
                /* 开启485口 */
                NXP485_GPIO->PSOR = GPIO_FIT_REG(1U << NXP485_GPIO_PIN);
                /*Uart_DMA Config*/
                EDMA_PrepareTransferConfig(&sendXferConfig, data_Buffer, sizeof(uint8_t),sizeof(uint8_t), (uint32_t *)(uint32_t) &(UART0_PERIPHERAL-  >D),  sizeof(uint8_t), 0 ,sizeof(uint8_t), 4U);
                /*Submit transfer.*/
                EDMA_SetTransferConfig(UART0_UART_eDMA_Handle.txEdmaHandle->base, UART0_TX_DMA_CHANNEL, &sendXferConfig, NULL);
                /* Enable auto disable request feature */
                UART0_UART_eDMA_Handle.txEdmaHandle->base->TCD[UART0_TX_DMA_CHANNEL].CSR |= DMA_CSR_DREQ_MASK;
                /* Enable major interrupt */
                UART0_UART_eDMA_Handle.txEdmaHandle->base->TCD[UART0_TX_DMA_CHANNEL].CSR |= DMA_CSR_INTMAJOR_MASK;
                UART0_UART_eDMA_Handle.txEdmaHandle->base->SERQ = DMA_SERQ_SERQ(UART0_TX_DMA_CHANNEL);
                /* Enable UART TX EDMA. */
                UART0_PERIPHERAL->C5 |= (uint8_t)UART_C5_TDMAS_MASK;
                 UART0_PERIPHERAL->C2 |= (uint8_t)UART_C2_TIE_MASK;
              break;
            default:
                //UART0_PERIPHERAL->C5 &= ~(uint8_t)UART_C5_TDMAS_MASK;
                //UART0_PERIPHERAL->C2 &= ~(uint8_t)UART_C2_TIE_MASK;
              break;
    else if((kUART_TransmissionCompleteFlag & UART_GetStatusFlags(UART0_PERIPHERAL)) != 0U)
           UART_ClearStatusFlags(UART0_PERIPHERAL,(uint32_t)kUART_TransmissionCompleteFlag);
          /* 关闭485口*/
          NXP485_GPIO->PCOR = GPIO_FIT_REG(1UL << NXP485_GPIO_PIN);
    SDK_ISR_EXIT_BARRIER;
我知道答案 目前已有1人回答
 楼主| 发表于 2024-12-30 17:18:28 | 显示全部楼层
配置应该没问题,刚才看了下硬件,因为我发送信号需要设备断电重启,原JLINK中给芯片供电的线没接,现在接上发现没啥问题了。
GMT+8, 2025-10-27 13:36 , Processed in 0.084370 second(s), 22 queries , MemCache On.
