查看: 886|回复: 2
S32k314 485(串口)无法进入中断
发表于 2025-9-28 17:57:41 | 显示全部楼层 |阅读模式
我的这个485初始化,不能正常进入中断,是配置的问题,还是我代码的原因,大佬们,求解决
 楼主| 发表于 2025-9-28 17:58:19 | 显示全部楼层
void RS485_DriverInit(void)
        // Siul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS0, g_pin_mux_InitConfigArr0);
        /* ENRS485 Enable GPIO */
        Siul2_Dio_Ip_WritePin(EN_485_PORT,EN_485_PIN,1);
        /* ENRS485 rx,tx */
        /* RS485 Install Interrupt Handler */
        IntCtrl_Ip_InstallHandler(LPUART0_IRQn, &LPUART_UART_IP_0_IRQHandler, NULL_PTR);
        /* RS485 Enable Interrupt */
        IntCtrl_Ip_EnableIrq(LPUART0_IRQn);
        Lpuart_Uart_Ip_Init(LPUART_UART_IP_INSTANCE_USING_0,&Lpuart_Uart_Ip_xHwConfigPB_0);
        Lpuart_Uart_Ip_StartReceiveDataUsingInt(LPUART_UART_IP_INSTANCE_USING_0, Modbus_RX_BUFF,sizeof(Modbus_RX_BUFF));
        // IntCtrl_Ip_Init(&IntCtrlConfig_0);
        // IntCtrl_Ip_ConfigIrqRouting(&intRouteConfig);
 楼主| 发表于 2025-9-28 17:58:31 | 显示全部楼层
这个是初始化
GMT+8, 2026-11-11 02:44 , Processed in 0.080369 second(s), 22 queries , Redis On.
