查看: 141|回复: 0
[在线活动] 2025 AI训练营——IIC接口
    昨天 16:11
  • 签到天数: 1373 天
    连续签到: 12 天
    2万
    发表于 2026-1-2 22:50:25 | 显示全部楼层 |阅读模式
    # NXP LPC800 I2C接口使用例程
    # I2C从机地址定义
    I2C_SLAVE_ADDR = 0x55
    # I2C状态标志
    I2C_STAT_BUSY = 1 << 0
    I2C_STAT_TXF = 1 << 2
    I2C_STAT_RXF = 1 << 3
    I2C_STAT_NAK = 1 << 4
    I2C_STAT_ARB = 1 << 5
    # 模拟硬件寄存器
    class LPC_I2C0:
        def __init__(self):
            self.CTRL = 0
            self.STAT = 0
            self.DATA = 0
            self.FREQ = 0
            self.ADR = 0
    class LPC_SYSCON:
        SYSAHBCLKCTRL = 0
    class LPC_IOCON:
        PIO0_10 = 0
        PIO0_11 = 0
    # 全局硬件实例
    LPC_I2C0 = LPC_I2C0()
    LPC_SYSCON = LPC_SYSCON()
    LPC_IOCON = LPC_IOCON()
    SystemCoreClock = 12000000  # 12MHz系统时钟
    def i2c_init():
        """I2C初始化配置"""
        # 使能I2C时钟
        LPC_SYSCON.SYSAHBCLKCTRL |= (1 << 10)
        # 配置PIO0_10(SDA)和PIO0_11(SCL)为I2C功能
        LPC_IOCON.PIO0_10 = 0x01
        LPC_IOCON.PIO0_11 = 0x01
        # 设置I2C时钟频率(100KHz)
        LPC_I2C0.FREQ = (SystemCoreClock // 100000) - 1
        # 配置从机地址
        LPC_I2C0.ADR = (I2C_SLAVE_ADDR << 1)
        # 使能I2C模块
        LPC_I2C0.CTRL = 0x40
    def i2c_start():
        """I2C发送起始条件"""
        # 发送起始条件
        LPC_I2C0.CTRL |= (1 << 5)
        # 等待起始条件完成
        while not (LPC_I2C0.STAT & (1 << 3)):
            pass
        # 清除中断标志
        LPC_I2C0.STAT = (1 << 3)
    def i2c_stop():
        """I2C发送停止条件"""
        # 发送停止条件
        LPC_I2C0.CTRL |= (1 << 6)
        # 等待停止条件完成
        while not (LPC_I2C0.STAT & (1 << 4)):
            pass
        # 清除中断标志
        LPC_I2C0.STAT = (1 << 4)
    def i2c_send_byte(data):
        """I2C发送一个字节"""
        # 等待TX FIFO空
        while not (LPC_I2C0.STAT & I2C_STAT_TXF):
            pass
        # 写入数据
        LPC_I2C0.DATA = data
        # 等待ACK
        while not (LPC_I2C0.STAT & (1 << 0)):
            pass
        # 检查ACK状态
        if LPC_I2C0.STAT & (1 << 1):
            return 1  # NACK错误
        return 0
    def i2c_read_byte(ack):
        """I2C读取一个字节"""
        # 等待RX FIFO非空
        while not (LPC_I2C0.STAT & I2C_STAT_RXF):
            pass
        # 读取数据
        data = LPC_I2C0.DATA
        # 设置ACK状态
        if ack:
            LPC_I2C0.DATA = 0x00  # ACK
        else:
            LPC_I2C0.DATA = 0x01  # NACK
        return data
    def i2c_master_transmit(slave_addr, data, length):
        """主模式发送数据"""
        # 发送起始条件
        i2c_start()
        # 发送从机地址+写命令
        if i2c_send_byte((slave_addr << 1) | 0x00):
            i2c_stop()
            return 1  # 地址应答失败
        # 发送数据
        for i in range(length):
            if i2c_send_byte(data):
                i2c_stop()
                return 2  # 数据发送失败
        # 发送停止条件
        i2c_stop()
        return 0
    def i2c_master_receive(slave_addr, data, length):
        """主模式接收数据"""
        # 发送起始条件
        i2c_start()
        # 发送从机地址+读命令
        if i2c_send_byte((slave_addr << 1) | 0x01):
            i2c_stop()
            return 1  # 地址应答失败
        # 接收数据
            # 最后一个字节前发送ACK
            ack = 1 if i < length-1 else 0
            data = i2c_read_byte(ack)
        # 发送停止条件
        i2c_stop()
        return 0
    # 主函数示例
    def main():
        tx_data = [0x01, 0x02, 0x03]
        rx_data = [0] * 3
        # 初始化I2C
        i2c_init()
        # 发送数据示例
        print("发送数据中...")
        result = i2c_master_transmit(I2C_SLAVE_ADDR, tx_data, 3)
        if result == 0:
            print("发送成功")
        else:
            print(f"发送失败,错误码: {result}")
        # 接收数据示例
        print("接收数据中...")
        result = i2c_master_receive(I2C_SLAVE_ADDR, rx_data, 3)
        if result == 0:
            print(f"接收成功: {rx_data}")
        else:
            print(f"接收失败,错误码: {result}")
    # 执行主函数
    if __name__ == "__main__":
        main()```
    GMT+8, 2026-4-7 01:05 , Processed in 0.071184 second(s), 22 queries , Redis On.
