在线时间312 小时
UID3914144
注册时间2023-4-15
NXP金币4788
TA的每日心情 | 开心 前天 12:40 |
签到天数: 852 天 连续签到: 1 天 [LV.10]以坛为家III
- 4054
- 2026-10-24
发表于 2026-3-28 06:35:43
显示全部楼层
前段时间在做FRDM_MCXW71时,发现I2C的总线不能正确配置,始终跑在5.6KHz频率下,不过我提了issue后,很快就有回复: Albort12138 left a comment (zephyrproject-rtos/zephyr#105708)
Hi @AllenZhang-NXP, the PR has already passed the batch tests and no additional issues were found. It is still under review, but since the clock-related changes are extensive and may introduce unexpected side effects, the PR might not be merged into the 4.4 release.
However, for the MCXW7x series, I believe we should transition to the new clock control implementation. We can also use the current PR to verify whether the issue still exists.
nxp团队在zephyr上面有很好技术团队,相信如果有问题,会能及时的得到解决!
