查看: 5061|回复: 0
[其他] 关于中断向量表与prm文件的设置
发表于 2009-11-30 23:37:37 | 显示全部楼层 |阅读模式
各位高手:
       我最近在做ucosii在xep100上的移植,不使用xgate,使用以下这个中断向量表:
#pragma CONST_SEG __NEAR_SEG OS_VECTOR_TABLE
void (* near const _vectab[])() =
  /* ff3c*/
   Unhandled,
   /* ff3e*/
   Unhandled,
/* fff0: RealTimeInterrupt */
   rti_handled,
   /* fff2: IRQ */
   Unhandled,
   /* fff4: XIRQ */
   Unhandled,
   /* fff6: SWI */
   OSCtxSw,
   /* fff8: UnimplementedInstruction */
   Unhandled,
   /* fffa: COP_FailureReset */
   Unhandled,
   /* fffc: ClockMonitorFailReset */
   Unhandled,
   /* fffe: Reset */
   _startup,
同时修改。prm文件如下:
/* non-banked FLASH */
      ROM_4000      = READ_ONLY     0x4000 TO   0x7FFF;
      ROM_C000      = READ_ONLY     0xC000 TO   0xFEFF;
/*    VECTORS       = READ_ONLY     0xFF00 TO   0xFFFF; intentionally not defined: used for VECTOR commands below */
     OSVECTORS     = READ_ONLY     0xFF10 TO   0xFFFF;  /* OSEK interrupt vectors (use your vector.o) */
/* paged EEPROM                     0x0800 TO   0x0BFF; addressed through EPAGE */
      EEPROM_FC     = READ_ONLY   0xFC0800 TO 0xFC0BFF;
      EEPROM_FD     = READ_ONLY   0xFD0800 TO 0xFD0BFF;
      EEPROM_FE     = READ_ONLY   0xFE0800 TO 0xFE0BFF;
/*    EEPROM_FF     = READ_ONLY   0xFF0800 TO 0xFF0BFF; intentionally not defined: equivalent to EEPROM */
 PAGED_RAM         INTO  /* when using banked addressing for variable data, make sure to specify
                                 the option -D__FAR_DATA on the compiler command line */
                              RAM_F0, RAM_F1, RAM_F2, RAM_F3, RAM_F4, RAM_F5, RAM_F6, RAM_F7,
                              RAM_F8, RAM_F9, RAM_FA, RAM_FB, RAM_FC, RAM_FD;
      OS_VECTOR_TABLE      INTO  OSVECTORS; /* OSEK vector table */
END
ENTRIES /* keep the following unreferenced variables */
    /* OSEK: always allocate the vector table and all dependent objects */
  //_vectab OsBuildNumber _OsOrtiStackStart _OsOrtiStart
END
STACKSIZE 0x100   /* size of the stack (will be allocated in DEFAULT_RAM) */
/* use these definitions in plane of the vector table ('vectors') above */
//VECTOR 0 _Startup /* reset vector: this is the default entry point for a C/C++ application. */
现象是:在全仿真模式下,在执行swi命令后没有进入中断,reset复位以后没有进入 _startup 而是跑飞了!
我的问题是,我只想用这种中断向量表的方式实现中断,那么我的。prm文件设置是否正确?我应该如何设置和修改?在程序的其他地方我还需要做什么吗?
谢谢!!!
我知道答案 目前已有0人回答
GMT+8, 2025-10-27 09:33 , Processed in 0.085813 second(s), 22 queries , MemCache On.
