查看: 7689|回复: 1
[其他] BDI3000 与8313E RDB开发板问题
发表于 2010-4-16 17:20:33 | 显示全部楼层 |阅读模式
说明 BDI3000 GDB for PPC版本开发板 8313E RDB REVA4 版本 8M NorFlash的系统资源  Start        End           Definition    0x0000_0000   0x07ff_ffff    DDR2 SDRAM    0x8000_0000   0x8fff_ffff    PCI memory    0x9000_0000   0x9fff_ffff    PCI_MMIO    0xe000_0000   0xe00f_ffff    IMMR    0xe200_0000   0xe20f_ffff    PCIIO    0xe280_0000   0xe280_7fff    NAND flash    0xfe00_0000   0xfe7f_ffff    NOR flash    The flash starts at address 0xfe000000.    Start        End           Definition    0xfe00_0000   0xfe0f_ffff    U-Boot    0xfe10_0000   0xfe2f_ffff    Linux kernel    0xfe30_0000   0xfe6f_ffff    Ramdisk/JFFS2 file system    0xfe70_0000   0xfe70_ffff    OF tree    0xfe71_0000   0xfe72_ffff    Vitesse 7385 image_loader program    0xfe73_0000   0xfe7f_dfff    Reserved    0xfe7f_e000   0xfe7f_ffff    Vitesse 7385 firmware image BDI配置文件 参照CodeWarrier的修改 如下:[INIT];setMMRBaseAddr 0xFF400000;WREG        MBAR        0xFF400000; change internal MMR base from 0xff400000 (reset value) to 0xe0000000WM32 0xff400000                 0xe0000000 ;setMMRBaseAddr 0xe0000000;WREG        MBAR        0xe0000000;#############################################; System Configuration - Local Access Windows ;#############################################; Local Bus Local Access Windows;################################; WINDOW 0 - NOR FLASHWM32 0xe0000020 0xfe000000 ; LBLAWBAR0  - begining at 0xfe000000 WM32 0xe0000024 0x80000018 ; LBLAWAR0   - enable, size = 32MB ; WINDOW 1 - NAND FlashWM32 0xe0000028 0xf8000000 ; LBLAWBAR1  - begining at 0xf8000000WM32 0xe000002c 0x80000018 ; LBLAWAR1   - enable, size = 32MB ; WINDOW 2 - VSC7385WM32 0xe0000030 0xf0000000 ; LBLAWBAR2  - begining at 0xfc100000WM32 0xe0000034 0x80000010 ; LBLAWAR2   - enable, size = 128kB; WINDOW 3 - Read Write BufferWM32 0xe0000038 0xfa000000 ; LBLAWBAR3  - begining at 0xfa000000WM32 0xe000003c 0x8000000e ; LBLAWAR3   - enable, size = 32kB; PCI Local Access Windows;#################################; WINDOW 0WM32 0xe0000060 0x80000000 ; PCILAWBAR0 - begining at 0x80000000WM32 0xe0000064 0x8000001c ; PCILAWAR0  - enable, size = 512MB; WINDOW 1WM32 0xe0000068 0xa0000000 ; PCILAWBAR1 - begining at 0xa0000000WM32 0xe000006c 0x8000001c ; PCILAWAR1  - enable, size = 512MB; DDR Local Access Windows;#################################; WINDOW 0 - 1st DDR SODIMMWM32 0xe00000a0 0x00000000 ; DDRLAWBAR0 - begining at 0x00000000WM32 0xe00000a4 0x8000001a ; DDRLAWAR0  - enable, size = 128MB;        #*********************************        ; DDR2 Controller Registers;        #*********************************        ;DDRCDR        WM32 0xE0000128 0x73000002        ; DDR_SDRAM_CLK_CNTL        ; CLK_ADJST = b'010' ; 2 Clocks        WM32 0xE0002130 0x02000000        ; CS0_BNDS        ; SA0 = b'000000000000'        ; EA0 = b'000000000111'        WM32 0xE0002000 0x00000007 ;# 128MB                ; CS0_CONFIG        ; CS_0_EN = b'1'        ; AP_0_EN = b'1'        ; ODT_RD_CFG = b'0'        ; ODT_WR_CFG = b'1'        ; BA_BITS_CS_0 = b'00'        ; ROW_BITS_CS_0 = b'001' ; 13 row bits        ; COL_BITS_CS_0 = b'010' ; 10 columns bits        WM32 0xE0002080 0x80840102        ; TIMING_CFG_3        ; EXT_REFREC = b'000' ; 0 Clocks        WM32 0xE0002100 0x00000000                ; TIMING_CONFIG_1        ; bit 1-3 = 2 - PRETOACT precharge activate interval 2 clock cycles        ; bit 4-7 = 6 - ACTTOPRE activate to precharge interval 6 clock cycles        ; bit 9-11 = 2 = ACTTORW activate to r/w interval 2 clock cycles         ; bit 13 - 15 = 5 - CASLAT CAS latency 3 clock cycles        ; bit 16 - 19 = 6 - REFREC refresh recovery time 14 clock cycles         ; bit 21 - 23 = 2 - WRREC data to precharge interval 2 clock cycles         ; bit 25 - 27 = 2 - ACTTOACT activate to activate interval 2 clock cycles        ; bit 29 - 31 = 2 - WRTORD write data to read command interval 2 clock cycles        WM32 0xe0002108 0x26256222        ; TIMING_CONFIG_2        ; bit 19-21  = b010  - WR_DATA_DELAY - 1/2 DRAM clock delay        WM32 0xe000210C 0x0f9028c7                ; TIMING_CFG_0        ; RWT = b'00' ; 0 Clocks        ; WRT = b'00' ; 0 Clocks        ; RRT = b'00' ; 0 Clocks        ; WWT = b'00' ; 0 Clocks        ; ACT_PD_EXIT = b'010' ; 2 Clocks        ; PRE_PD_EXIT = b'010' ; 2 Clocks        ; ODT_PD_EXIT = b'1000' ; 8 Clocks        ; MRS_CYC = b'0010' ; 2 Clocks        WM32 0xE0002104 0x00220802        ; DDR_SDRAM_CFG        ; MEM_EN = b'0'        ; SREN = b'1'        ; RD_EN = b'0'        ; SDRAM_TYPE = b'011'        ; DYN_PWR = b'0'        ; 32_BE = b'1'        ; 8_BE = b'0'        ; NCAP = b'0'        ; 2T_EN = b'0'        ; x32_EN = b'0'        ; PCHB8 = b'0'        ; HSE = b'0'        ; MEM_HALT = b'0'        ; BI = b'0'        WM32 0xE0002110 0x43080000                ; DDR_SDRAM_CFG_2        ; FRC_SR = b'0'        ; DQS_CFG = b'00'        ; ODT_CFG = b'10'        ; NUM_PR = b'0001'        ; D_INIT = b'0'        WM32 0xE0002114 0x00401000        ; DDR_SDRAM_MODE        ; Extended Mode Register: Outputs=0 or 1?        ; Mode Register        WM32 0xE0002118 0x44400232                ; DDR_SDRAM_MODE_2        ; Extended Mode Register 2        ; Extended Mode Register 3        WM32 0xE000211C 0x8000c000                        ; DDR_SDRAM_INTERVAL        ; REFINT = 800 Clocks        ; BSTOPRE = 100 Clocks        WM32 0xE0002124 0x03200064                ;delay before enable        DELAY 300        ;Enable: DDR_SDRAM_CFG        WM32 0xE0002110 0xc3080000;##############################################; Local Bus Interface (LBIU) Configuration;##############################################; CS0 - 8MB NOR FLASH WM32 0xe0005000 0xfe001001 ; BR0 base address at 0xFE000000, port size 16 bit, GPCM, validWM32 0xe0005004 0xfe006ff7 ; OR0 8MB flash size, 15 w.s., timing relaxed; CS1 - NAND FLASH      WM32        0xE0005008        0xF8000C21 ; BR1 base address at 0xF8000000, port size 8 bit, FCM, validWM32        0xE000500c        0xFFFF83CC ; OR1 32KB flash size, small page;for a Rev A board, please comment the line above and use the below initialization for OR1:;WM32        0xE000500c        0xFFFF93CC ; OR1 32KB flash size, small page; CS2 - VSC7385WM32 0xe0005010 0xf0000801 ; BR2 base address at 0xF0000000, port size 8 bit, GPCM, validWM32 0xe0005014 0xFFFE09FF ; OR2 128KB; CS3 - Read Write BufferWM32 0xe0005018 0xfa000801 ; BR3 base address at 0xfa000000, port size 8 bit, GPCM, validWM32 0xe000501c 0xFFFF8FF7 ; OR3 32KB; LBCR - local bus enableWM32 0xe00050d0 0x00000000; LCRR; bit 14 - 15 = 0b11 - EADC - 3 external address delay cycles ; bit 28 - 31 = 0x0010  - CLKDIV - system clock:memory bus clock = 2WM32 0xe00050d4 0x00030002WREG  MSR  0x2000 ;;writereg MSR 0x2000 ; FP available, machine check disable, exception vectors at 0x0000_0000WM32 0xE0000800 0x00000000 ; ACR - Enable CoreWM32 0xfa000000 0x00000000 ; write board LEDs;; NAND Flash settings;WM32        0xE00050E0        0x0000E000 ; FMR; MRTPR - refresh timer prescalerWM32 0xe0005084 0x20000000 ;WREG SP 0xf[TARGET]CPUTYPE     8313                        ;the CPU typeJTAGCLOCK   0                           ;use 16 MHz JTAG clockPOWERUP      1000W***EUP       100BOOTADDR     0x000100;RCW         0xa4700000 0x04230000       ;override reset configuration wordsSTARTUP     RESET                       ;halt immediately at the boot vectorBRE***MODE   HARD                              ;SOFT or HARD, HARD uses PPC hardware breakpoint***MODE    HWBP                       ;TRACE or HWBP, HWBP uses a hardware breakpointMMU            XLAT 0xC0000000        ;enable virtual address modePTBASE      0x000000f0          ;here is the pointer to the page table pointers;[HOST]IP          192.168.6.33;FILE        FORMAT      SRECLOAD        MANUAL      ;load code MANUAL or AUTO after resetPROMPT      8313_RDB>;[FLASH]CHIPTYPE    AM29BX16   ; MIRRORX16 Flash type: Micron Q-Flash MT28F640J3CHIPSIZE    0x800000   ;The size of one flash chip in bytesBUSWIDTH    16          ;The width of the flash memory bus in bits (8 | 16 | 32 | 64);WORKSPACE   0x1000      ;workspace in DDR RAMFILE        $u-boot.binFORMAT      BIN 0xfe000000;ERASE       0xfff00000  ;erase sector 8;ERASE       0xFFF20000;ERASE       0xFFF40000;ERASE       0xFFF60000;ERASE       0xFFF80000;ERASE       0xFFFa0000;ERASE       0xFFFc0000;ERASE       0xFFFe0000;ERASE       0xfe100000  ;erase sector 8;ERASE       0xfe120000  ;erase sector 9;ERASE       0xfe140000  ;erase sector 10;ERASE       0xfe160000  ;erase sector 11;ERASE       0xfe100000 0x20000 3 ; erase 3 sectors[REGS]FILE         $reg8313e.def现在问题是无法编程Nor Flash,也无法擦除Flash,解锁命令也老是不对,都说不是命令错误就是参数错误。313_RDB>info    Target CPU        : MPC83xx (e300c3)    Target state      : debug mode    Debug entry cause : COP halt    Current PC        : 0xfff00100    Current CR        : 0x00000000    Current MSR       : 0x00002000    Current LR        : 0x00000000    Current MBAR      : 0xe00000008313_RDB>reset- TARGET: processing user reset request- BDI asserts HRESET- Reset JTAG controller passed- Bypass check: 0x00000001 => 0x00000001- JTAG exists check passed- IDCODE is 0x0687001D- BDI removes HRESET- PVR is 0x80850010- SVR is 0x80B00010- BDI sets breakpoint at 0x00000100- BDI resumes program execution- COP status is 0x01- Waiting for target stop failed- TARGET: Break at boot vector failed, freeze forced- TARGET: Target PVR is 0x80850010- TARGET: resetting target passed- TARGET: processing target startup ....- TARGET: processing target startup passed8313_RDB>UNLOCK  0xfe000000 0x10000 8Unlocking flash at 0xfe000000# Invalid parameter for flash programming8313_RDB>erase 0xfe000000 0x10000 8 UNLOCK# syntax error in command反正就是出现无法编程NOR flash的情况??谁帮忙解惑 一下,第一次接触PPC开发BDI也不是很熟悉,
我知道答案 目前已有0人回答
    发表于 2010-4-17 09:19:34 | 显示全部楼层
    RE:BDI3000 与8313E RDB开发板问题
    能不能把你的程序方的整齐点呢?这样看的头晕,我帮你看看。
    GMT+8, 2026-4-20 00:57 , Processed in 0.086654 second(s), 23 queries , Redis On.
