楼主: 斯嘉丽
翻译接龙第二期:Using the Touch Screen Controller
 楼主| 发表于 2008-5-21 13:44:27 | 显示全部楼层
回复:翻译接龙第二期:Using the Touch Screen Controller
原帖由morebetter于2008-05-16 16:40发表:
7、The ASP module on the MCF5227x supports resistive type touch screens. Modes of operation are available for the commonly used interfaces — 4-wire, 5-wire, 7-wire, and 8-wire. The following sections discuss how the different types of resistive touch screens work, along with their advantages and disa
MCF5227x 就是freescale的产品
 楼主| 发表于 2008-5-21 13:45:09 | 显示全部楼层
原帖由山东大学南风队于2008-05-20 18:34发表:
1.1 How 4-Wire Resistive Touch Screens Work8、 A 4-wire touch screen is made from two layers, each with a resistive coating. There is a separation between the two layers. The bottom layer is rigid, but the top one is flexible. Both layers have bus bars placed perpendicular to each other. A voltage is
这段好像还没有翻译完啦!…………
发表于 2008-5-29 11:57:07 | 显示全部楼层
RE:翻译接龙第二期:Using the Touch Screen Controller
A 4-wire touch screen is made from two layers, each with a resistive coating. There is a separation between the two layers. The bottom layer is rigid, but the top one is flexible. Both layers have bus bars placed perpendicular to each other. A voltage is applied to the bus bars on both sides of a layer and the resistive coating creates a voltage gradient across the plane. The basic idea is to create a voltage divider. Detecting the voltage at the division point (the touch point) allows for calculating the relative position of the touch point with respect to the two rails.
4线触摸屏由2层构成,每层均有电阻涂层,将两层分割开来。其中底层为刚性,上层为柔性。每层的母线互相垂直。当两层母线开始加压,电阻涂层就会通过平面产生电压差。基本思路是建立一个分压器,检测分割点(接触点)电压 ,通过二维数据计算触摸屏上相应触摸点。
发表于 2008-5-29 12:09:19 | 显示全部楼层
9、To get the coordinates for a single point, two measurements are needed. First a voltage is applied across the x-axis plane, and the contacts for the y-axis plane are allowed to float. The resistive coating on the touch screen creates a voltage gradient across the plane. If the top layer is pressed, it flexes and makes contact with the bottom layer. The y-axis plane now has a voltage equal to the voltage on the x-axis plane at the point of contact. The voltage on the y-axis plane can be measured and used to obtain the x-coordinate. The process is repeated again to get the y-coordinate. This time the voltage is applied across they-axis plane and the x-axis plane is allowed to float. Then the x-axis voltage is measured and used to calculate the y-coordinate location.
要计算出坐标点需要两个测量前提。首先是电压应用于X轴平面,Y轴平面允许移动,触摸屏电阻涂层能够产生电压梯度差。如果上层接受到压力弯曲与底层产生接触,Y平面上就会产生与X平面接触点相同的电压。通过计算y平面上电压就可以计算出用户在X面上的坐标点。同样的过程在获得Y坐标。此时,电压应用与整个平面,X面允许自由浮动,同时通过测量X轴电压计算出Y坐标位置。
发表于 2008-5-29 12:10:28 | 显示全部楼层
lemon tree,lemon tree,I love lemon tree!
发表于 2008-5-29 15:23:01 | 显示全部楼层
发表于 2008-5-29 17:08:13 | 显示全部楼层
7、The ASP module on the MCF5227x supports resistive type touch screens. Modes of operation are available for the commonly used interfaces — 4-wire, 5-wire, 7-wire, and 8-wire. The following sections discuss how the different types of resistive touch screens work, along with their advantages and disadvantages
在ASP单元,介绍mcf5227x支持电阻式触摸屏。运作模式,常用接口-四线,五线,七线,八线。以下各节讨论如何依照他们的优缺点按不同类型的电阻触摸屏工作。
发表于 2008-5-29 17:17:27 | 显示全部楼层
11.The next step is to get the y-axis coordinate. This time Y+/YU is biased to 3.3 V, and Y–/YD is biased to 0 V. This creates the consistent voltage ramp across the y-axis plane. The pressure from the touch creates a contact point between the two planes so that the x-axis plane goes to 1.65 V. The input voltage is read from the X+/XL wire and used to determine that the y-axis coordinate of the touch point is at 50% of the screen’s height.
11:下一步是求Y轴坐标。这个时候y+/YU偏至3.3v,和y-/yd是偏至0V,这就产生了一个连续的斜坡电压穿过Y轴的平面。在两平面之间,压力从接触部分产生了一个联结点,使X轴的平面达到1.65V,输入电压从X+/xl线读取,并用来确定Y轴坐标触摸点是在50%的屏幕的高度。
发表于 2008-5-29 17:20:46 | 显示全部楼层
怎么看不见楼层了???
发表于 2008-5-30 17:56:11 | 显示全部楼层
GMT+8, 2026-4-16 08:57 , Processed in 0.111273 second(s), 28 queries , Redis On.
