123
返回列表 发新帖
楼主: 雨影使者
[CodeWarrior] codewarrior 浮动安装license怎么安装不起(已解决)
发表于 2013-7-9 13:11:48 | 显示全部楼层
回复:codewarrior 浮动安装license怎么安装不起
不客气
     楼主| 发表于 2013-7-16 21:33:21 | 显示全部楼层
    回复第 19 楼 于2013-07-09 09:30:16发表:
    回复第 18 楼 于2013-07-09 09:23:40发表:
    可以的, 不过你需要rehost license. 也就是说, 把license重新绑定在你的台式机上.
    Freescale已经将rehost的方法写在FAQ中. ([url=https://www.freescale.co
    m/webapp/sps/site/overview.jsp?nodeId=015210272624448523]https://www.freescale.co
    m/webapp/sps/site/overview.jsp?nodeId=015210272624448523[/url]).
    这个工作是Freescale注册用户自己完成的
    我把他摘出如下:
    Q: How do I rehost my CodeWarrior Development Suite to another computer?
    *NOTE: By rehosting, you are transferring all of the privileges of your CodeWarrior Development Suite to the new computer. To rehost your CodeWarrior Development Suite:
    1.    Go to [url=https://www.freescale.co
    m/]www.freescale.com[/url] using your new computer
    2.    Log in to My Freescale using your registered member ID and password
    3.    Click on CodeWarrior Licensing — "My Products" page appears showing your currently licensed products
    4.    Click on License Options — The CodeWarrior Development Suite Details page appears
    5.    Click on Rehost
    6.    If necessary, determine if your CodeWarrior Development Suite is node locked or floating by going to "How do I determine if my CodeWarrior Development Suite is Node Locked or Floating?" FAQ
    7.    Select the Host ID type
    8.    Enter the new Host ID
    9.    Click Submit — The online license profile updates and the Registration and Licensing System page appears, confirming your new licensing information
    10.   For products you are entitled to license, select Get License to lock the license to the new license profile information
    11.   For products you have already licensed, select Repair License to obtain an updated license file locked to the new license profile information
    补充一下, 想要用其它台式机做服务器, 这个rehost是必须做的. rehost完成后 新生成的license 绑定其它台式机的Host ID(比如 MAC地址). 这样的license才可以用于其它台式机
    不去rehost,自己把MAC改了行不行?我发现好像可以安装
    发表于 2013-7-17 09:34:22 | 显示全部楼层
    回复第 22 楼 于2013-07-16 21:33:21发表:
    我把他摘出如下:
    5.    Click on Rehost
    我没这么试过。理论上这样不行的。
    发表于 2013-7-17 10:34:45 | 显示全部楼层
    我把他摘出如下:
    5.    Click on Rehost
    不可以,自己改MAC地址是不行的,这样的License 用不了
    GMT+8, 2025-10-23 19:59 , Processed in 0.082706 second(s), 22 queries , MemCache On.
