查看: 10351|回复: 17
[已解决] “窗口Freescale i.MX reference boards” 没出现,无法平台选择(已解决)
发表于 2014-3-21 09:08:29 | 显示全部楼层 |阅读模式
安装ltib 后,
前面一切照文说明
/home/ocean/ltib  ------------------我安装的 LTIB 位置,然后回车
ocean@ubuntu:~/ltib/ltib$ ./ltib
Installing host support packages.
This only needs to be done once per host, but may take up to
an hour to complete ...
If an error occurs, a log file with the full output may be found in:
/home/ocean/ltib/ltib/host_config.log
Exiting on error or interrupt
Please see >> /home/ocean/ltib/ltib/host_config.log for details
没有错误的话,会出现如下窗口,Freescale i.MX reference boards 退出并保存。
==========无法进行I.MX平台选择,请问是哪里出现问题了,谢谢。===========
我知道答案 目前已有16人回答
 楼主| 发表于 2014-3-21 09:09:57 | 显示全部楼层
回复:“窗口Freescale i.MX reference boards” 没出现,无法平台选择
 楼主| 发表于 2014-3-21 09:17:36 | 显示全部楼层
Processing platform: Host support packages
using /home/ocean/ltib/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
Processing: texinfo
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
main:554
Started: Thu Mar 20 18:09:39 2014
Ended:   Thu Mar 20 18:09:41 2014
Elapsed: 2 seconds
These packages failed to build:
texinfo
Build Failed
=========host_config.log 显示内容===============
发表于 2014-3-21 10:45:07 | 显示全部楼层
RE:“窗口Freescale i.MX reference boards” 没出现,无法平台选择
楼主你好,请问你使用的是那块开发板?还有你使用的飞思卡尔linux BSP是哪个版本的?
 楼主| 发表于 2014-3-21 11:11:36 | 显示全部楼层
开发板的名称:MCIMX6Q-SDP 带9.7寸屏
BSP版本:L3.0.35_4.1.0_130816_source.tar.gz
执行的步骤,完全按“ i.MX6 Ubuntu12.04上编译LTIB.pdf”
到“没有错误的话,会出现如下窗口,Freescale i.MX reference boards 退出并保存。”
到这步就出问题了,因为,没有出现选择窗口。
发表于 2014-3-21 12:57:24 | 显示全部楼层
你的问题已经转交I.MX工程师,他会回答你。
请耐心等待。
发表于 2014-3-21 13:01:50 | 显示全部楼层
回复第 5 楼 于2014-03-21 11:11:36发表:
请问你的环境是ubuntu12.04吗?另外,如果你是第一次安装ltib的话,时间会比较久才会出现选择窗口。请问你到这一步出现什么问题,有错误信息显示么?有的话,把错误信息发给我看一下~~
发表于 2014-3-21 13:03:00 | 显示全部楼层
或者是你把编译过程中停在的位置,截图发给我也可以。
 楼主| 发表于 2014-3-21 13:47:25 | 显示全部楼层
我用的虚拟机是 ubuntu 12.04
===========虚拟机终端最后显示的界面内容(终端最下面部分)===========
ltib/dist/lfs-5.1/gpu-viv-bin/
ltib/dist/lfs-5.1/gpu-viv-bin/gpu-viv-bin-mx6q.spec
ltib/dist/lfs-5.1/gpu-viv-bin/gpu-viv-wl-bin-mx6s.spec
ltib/dist/lfs-5.1/gpu-viv-bin/gpu-viv-wl-bin-mx6q.spec
ltib/dist/lfs-5.1/gpu-viv-bin/gpu-viv-bin-mx6s.spec
ltib/dist/lfs-5.1/libid3tag/
ltib/dist/lfs-5.1/libid3tag/libid3tag.spec
ltib/dist/lfs-5.1/videoproto/
ltib/dist/lfs-5.1/videoproto/videoproto.spec
ltib/README
ltib/.ltibrc
Copying packages to /home/ocean/ltib/ltib/pkgs
Installation complete, your ltib installation has been placed in
/home/ocean/ltib/ltib, to complete the installation:
cd /home/ocean/ltib/ltib
./ltib
ocean@ubuntu:~/ltib/L3.0.35_4.1.0_130816_source$ cd /home/ocean/ltib/ltib/
 楼主| 发表于 2014-3-21 14:19:14 | 显示全部楼层
======== host_config.log (最下面部分的内容) ===========
+ cp -dp /home/ocean/ltib/ltib/pkgs/zlib-1.2.3-arflags-1.patch.md5 /opt/freescale/pkgs/zlib-1.2.3-arflags-1.patch.md5
+ cp -dp /home/ocean/ltib/ltib/pkgs/zlib-1.2.3.tar.bz2 /opt/freescale/pkgs/zlib-1.2.3.tar.bz2
+ cp -dp /home/ocean/ltib/ltib/pkgs/zlib-1.2.3.tar.bz2.md5 /opt/freescale/pkgs/zlib-1.2.3.tar.bz2.md5
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
Processing: texinfo
traceback:
main:554
Started: Thu Mar 20 23:10:26 2014
Ended:   Thu Mar 20 23:11:09 2014
Elapsed: 43 seconds
texinfo
Build Failed
GMT+8, 2025-10-23 07:16 , Processed in 0.118440 second(s), 30 queries , MemCache On.
