12
返回列表 发新帖
楼主: comnet
[已解决] “窗口Freescale i.MX reference boards” 没出现,无法平台选择(已解决)
发表于 2014-3-21 15:38:11 | 显示全部楼层
回复:“窗口Freescale i.MX reference boards” 没出现,无法平台选择
回复第 10 楼 于2014-03-21 14:19:14发表:
======== host_config.log (最下面部分的内容) ===========
+ cp -dp /home/ocean/ltib/ltib/pkgs/zlib-1.2.3-arflags-1.patch.md5 /opt/freescale/pkgs/zlib-1.2.3-arflags-1.patch.md5
+ cp -dp /home/ocean/ltib/ltib/pkgs/zlib-1.2.3.tar.bz2 /opt/freescale/pkgs/zlib-1.2.3.tar.bz2
+ cp -dp /home/ocean/ltib/ltib/pkgs/zlib-1.2.3.tar.bz2.md5 /opt/freescale/pkgs/zlib-1.2.3.tar.bz2.md5
Processing platform: Host support packages
using /home/ocean/ltib/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Processing: flex
Processing: texinfo
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
main:554
Started: Thu Mar 20 23:10:26 2014
Ended:   Thu Mar 20 23:11:09 2014
Elapsed: 43 seconds
These packages failed to build:
texinfo
Build Failed
你好,你是否安装了所有LTIB需要的包,?
比如
sudo aptitude -y install asciidoc texlive-latex-base dblatex xutils-dev
sudo apt-get install texinfo
发表于 2014-3-21 15:38:52 | 显示全部楼层
RE:“窗口Freescale i.MX reference boards” 没出现,无法平台选择
如果没有安装的话请安装。
 楼主| 发表于 2014-3-21 16:05:19 | 显示全部楼层
ocean@ubuntu:~$ sudo aptitude -y install asciidoc texlive-latex-base dblatex xutils-dev
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
ocean@ubuntu:~$ sudo apt-get install texinfo
Reading package lists... Done
Building dependency tree
Reading state information... Done
texinfo is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
ocean@ubuntu:~$
============都已安装了=========
发表于 2014-3-21 17:50:50 | 显示全部楼层
那你把opt/freescale/ltib/usr/src/rpm/BUILD/下的texinfo-4.8删除了,重新编译。
 楼主| 发表于 2014-3-21 22:21:27 | 显示全部楼层
删除后重新编译,又发现新的问题,没有平台选择的内容:这是怎么回事??
 楼主| 发表于 2014-3-22 10:23:55 | 显示全部楼层
EXIT后,再进入就没问题了,谢谢。
发表于 2014-3-24 10:24:28 | 显示全部楼层
楼主,以后问题解决了,帮我在你的标题上加上(已解决)
方便我们查看未结题。
发表于 2014-3-24 11:12:13 | 显示全部楼层
回复:“窗口Freescale i.MX reference boards” 没出现,无法平台选择(已解决)
回复第 15 楼 于2014-03-21 22:21:27发表:
楼主你好,这个界面是没有问题的,要选择freesacle imx reference boards.
GMT+8, 2025-10-23 07:18 , Processed in 0.136431 second(s), 28 queries , MemCache On.
