查看: 8144|回复: 17
[分享] KL02Z 内部温度传感器读出来的温度感觉不对
  • 签到天数: 64 天
    发表于 2014-6-6 10:23:54 | 显示全部楼层 |阅读模式
     如题,读出来的ADC值为245或246,进计算为24°。相关代码如下:
    #define TEMP_CHANNEL    0x1A     //Temp Sensor is selected as input
    #define BG_CHANNEL    0x1B        //Bandgap  is selected as input
    #define AD_DISABLE      0x1F        //Module Disable
    #define ADCR_TEMP25     239     // 25℃时ADC值
    #define TempSlope_Cold      56      //低温时的斜率,ADC值大于ADCR_TEMP25
    #define TempSlope_Hot       60      //高温时的斜率,ADC值小于ADCR_TEMP25
    void InitADC( void )
            SIM_SCGC6 |= SIM_SCGC6_ADC0_MASK;  // enable ADC0 clock
              /*ADC0_CFG1 = ADC_CFG1_ADIV(1)|
                                      ADC_CFG1_MODE(2)|
                                      ADC_CFG1_ADICLK(3);*/
        ADC0_CFG1 = ADC_CFG1_ADIV(0)|       //The divide ratio is 1 and the clock rate is (input clock)/1.
                                    ADC_CFG1_MODE(2)|       //It is single-ended 10-bit conversion.
                                    ADC_CFG1_ADICLK(0)|     //Bus clock
                                    ADC_CFG1_ADLPC_MASK|
                                    ADC_CFG1_ADLSMP_MASK;
        ADC0_SC2 = 0;
        ADC0_SC1A = ADC_SC1_AIEN_MASK | ADC_SC1_ADCH(0X1A);
    unsigned char TriggerADC(unsigned char Channel)
      if(Channel == 0x1B)                                          // Bandgap is selected as input
          PMC_REGSC |= PMC_REGSC_BGBE_MASK;                        // Bandgap buffer enabled
       ADC0_SC1A = Channel;                   // update the channel value
       return 1;
    unsigned int ReadADCPoll(void)
        while((ADC0_SC1A & ADC_SC1_COCO_MASK) == 0);
        //ADC0_SC1A &= ~ ADC0_SC1A_COCO_MASK;
        return ADC0_RA;
    unsigned int ReadADC_TempChannel(void)
        unsigned int i = 0, adc_value = 0;
        for(i=0; i> 4;
        TriggerADC(AD_DISABLE);
        return adc_value;
    int Get_Temperature(void)
        unsigned int adc_temp;
        int value, temp_value;
        adc_temp = ReadADC_TempChannel();
        DEBUG_TRACE(MOD_ADC,"adc_temp = %d", adc_temp);
        if (adc_temp >= ADCR_TEMP25)
            value = (adc_temp - ADCR_TEMP25) * 10 / TempSlope_Cold;
            temp_value = (int)(25 - value);
        else
            value = (ADCR_TEMP25 - adc_temp) * 10 / TempSlope_Hot;
            temp_value = (int)(25 + value);
        return temp_value;
    发表于 2014-6-6 11:08:02 | 显示全部楼层
    RE:KL02Z 内部温度传感器读出来的温度感觉不对
    楼主你bandgap使能没有?
    很多网友读出来不对,都是bandgap没有使能。
    发表于 2014-6-6 11:18:32 | 显示全部楼层
    楼主请查看PMC_REGSC[BGBE]这个位是否使能。
  • 签到天数: 64 天
     楼主| 发表于 2014-6-6 13:29:05 | 显示全部楼层
    回复2、3楼:
       return 1;
    在选择通道时,如果是Bandgap,则使能PMC_REGSC[BGBE]。
    刚才有试了下载ADC初始化时加上PMC_REGSC |= PMC_REGSC_BGBE_MASK;也还是和原来的一样
    发表于 2014-6-6 13:58:35 | 显示全部楼层
    回复:KL02Z 内部温度传感器读出来的温度感觉不对
    回复第 4 楼 于2014-06-06 13:29:05发表:
    回复2、3楼:
    return 1;
    看你这个#define TEMP_CHANNEL    0x1A     //Temp Sensor is selected as input
    你设为1A,但你程序里面是1B才使能。
    你直接初始化还不行吗?
    发表于 2014-6-6 13:59:59 | 显示全部楼层
    你参考下这篇文章的代码结构,
    https://www.nxpic.org.cn/bbs/article_1280_578313.html
    发表于 2014-6-6 14:02:57 | 显示全部楼层
    突然想起来,我之前做过这个代码,是在FRDM_KL02上做的,而且测试时通过的,
    我用的是CW的PE做的,给你参考下:
    KL02_ADC_temp.rar (530.91 KB, 下载次数: 16)
    发表于 2014-6-6 16:00:13 | 显示全部楼层
    楼主请用我的程序试下,如果还有问题,欢迎继续交流。
  • 签到天数: 64 天
     楼主| 发表于 2014-6-6 17:34:44 | 显示全部楼层
    OK,还没来得及试呢,谢谢
    发表于 2014-6-9 09:51:59 | 显示全部楼层
    楼主你是感觉测试的温度和实际温度偏差太大还是怎么样呢?
    如果是精度方面,那么就没必要去纠结,因为本身bandgap就是有一定的范围。
    所以如果在一两度的差别下,还是能够接受的。
    另外,你需要查看你的VDD是否是3.3V,如果不是偏差比较大的话,你就不能直接用公式Temp=25-((Vtemp-Vtemp25)/m) 去代了,你需要先计算当前VDD下的一些参数,然后再去计算实际的temp就比较准确的。
    具体:
    如果改变VDD值,那么就不能用以上公式直接计算,需要找到对应当前VDD值的Vtemp25以及m的ADC值去替换掉原来的Vtemp25以及m。下面直接给出计算公式:
    (1)   计算当前VDD
    VDD=(ADCRvdd*Vbg)/ADCRgb
    大家知道,内部的bandgap是固定的,通过datasheet可以知道,这个值的范围为0.97到1.03,典型值为1V。
    所以我们利用内部的bandgap值,读取在当前VDD下的ADC值,结合ADC满量程(比如12位为4095),计算出当前VDD的电压值。
    公式中,
    ADCRvdd:VDD对应的ADC满量程值,由你所选定的ADC位数决定,比如12位,就是2的12次方-1。
    Vbg:bandgap值,1V
    ADCRgb:ADC读取bandgap的值,实测。
    实际计算,会将VDD放大10倍计算,即公式变为:
    VDD*10=(ADCRvdd*Vbg)*10/ADCRgb
    VDD*10=VDDconv
    (2)   计算temp25对应的ADC值ADCtemp25
    ADCtemp25=(ADCRvdd*Vtemp25*10)/VDDconv
    公式中,
           Vtemp25:25度,VDD=3v时对应的电压,此值由datasheet提供
    (3)   计算温度电压变化率m对应的ADC值ADCR100m
    ADCR100m=(ADCRvdd*m*1000)/ VDDconv
          其中,
           m:温度相对电压的变化率,这个也是由datasheet提供。
    (4)   最终温度公式
    Temp=25-((ADCRt- ADCtemp25)/ ADCR100m)*100
          其中,ADCRt:为实际测试的ADC值。
    其实,楼上板子写了一个关于KL02的内部温度测试的经验分享,具体过程以及代码都很齐全,你可以看看:https://www.nxpic.org.cn/bbs/article_1280_583073.html
    GMT+8, 2026-4-4 02:47 , Processed in 0.111429 second(s), 30 queries , Redis On.
