楼主: rivita
[已解决] I.MX6,linux启动问题,谢谢!(已解决)
 楼主| 发表于 2014-10-8 20:01:01 | 显示全部楼层
1.我没找到到官网下载的文件,使用自己编译的文件;
2.我使用SD卡启动的。
 楼主| 发表于 2014-10-8 20:02:00 | 显示全部楼层
今天我计划使用LTIB编译一下的,结果连编译都没编过,描述如下:
IT   include/autoconf.h -> include/config/*
  HOSTCC  applets/usage
  HOSTCC  applets/applet_tables
applets/usage.c: In function 'main':
applets/usage.c:52:8: warning: ignoring return value of 'write', declared with attribute warn_unused_result [-Wunused-result]
applets/applet_tables.c: In function 'main':
applets/applet_tables.c:144:9: warning: ignoring return value of 'fgets', declared with attribute warn_unused_result [-Wunused-result]
  GEN     include/usage_compressed.h
  GEN     include/bbconfigopts.h
  GEN     include/applet_tables.h
  HOSTCC  applets/usage_pod
  CC      applets/applets.o
applets/usage_pod.c: In function 'main':
applets/usage_pod.c:74:3: warning: format not a string literal and no format arguments [-Wformat-security]
  LD      applets/built-in.o
  DOC     busybox.pod
  DOC     BusyBox.txt
  DOC     busybox.1
  DOC     BusyBox.html
  CC      libbb/appletlib.o
  AR      libbb/lib.a
  LINK    busybox_unstripped
Trying libraries: m
Failed: -Wl,--start-group -lm -Wl,--end-group
Output of:
gcc -Wall -Wshadow -Wwrite-strings -Wundef -Wstrict-prototypes -Wunused -Wunused-parameter -Wunused-function -Wunused-value -Wmissing-prototypes -Wmissing-declarations -Wdeclaration-after-statement -Wold-style-definition -fno-builtin-strlen -finline-limit=0 -fomit-frame-pointer -ffunction-sections -fdata-sections -fno-guess-branch-probability -funsigned-char -static-libgcc -falign-functions=1 -falign-jumps=1 -falign-labels=1 -falign-loops=1 -Os -o busybox_unstripped -Wl,--start-group applets/built-in.o archival/lib.a archival/libarchive/lib.a console-tools/lib.a coreutils/lib.a coreutils/libcoreutils/lib.a debianutils/lib.a e2fsprogs/lib.a editors/lib.a findutils/lib.a init/lib.a libbb/lib.a libpwdgrp/lib.a loginutils/lib.a mailutils/lib.a miscutils/lib.a modutils/lib.a networking/lib.a networking/libiproute/lib.a networking/udhcp/lib.a printutils/lib.a procps/lib.a runit/lib.a selinux/lib.a shell/lib.a sysklogd/lib.a util-linux/lib.a util-linux/volume_id/lib.a archival/built-in.o archival/libarchive/built-in.o console-tools/built-in.o coreutils/built-in.o coreutils/libcoreutils/built-in.o debianutils/built-in.o e2fsprogs/built-in.o editors/built-in.o findutils/built-in.o init/built-in.o libbb/built-in.o libpwdgrp/built-in.o loginutils/built-in.o mailutils/built-in.o miscutils/built-in.o modutils/built-in.o networking/built-in.o networking/libiproute/built-in.o networking/udhcp/built-in.o printutils/built-in.o procps/built-in.o runit/built-in.o selinux/built-in.o shell/built-in.o sysklogd/built-in.o util-linux/built-in.o util-linux/volume_id/built-in.o -Wl,--end-group -Wl,--start-group -lm -Wl,--end-group
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find /lib/libc.so.6
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find /usr/lib/libc_nonshared.a
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find /lib/ld-linux.so.3
collect2: ld returned 1 exit status
make: *** [busybox_unstripped] Error 1
error: Bad exit status from /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source/ltib/tmp/rpm-tmp.37464 (%build)
RPM build errors:
Build time for busybox: 5 seconds
Failed building busybox
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Wed Oct  8 14:20:05 2014
Ended:   Wed Oct  8 14:20:12 2014
Elapsed: 7 seconds
These packages failed to build:
busybox
Build Failed
Exiting on error or interrupt
vmuser@vmuser-virtual-machine:~/imx6/L3.0.35_4.1.0_130816_source/source/ltib$
 楼主| 发表于 2014-10-8 20:03:17 | 显示全部楼层
由于自己制作的板子已经回来了,现在在开发板上还没跑通,挺着急的,有没有相关文档或者什么的,官网上的资料真的太少了,而且描述看的不是很懂,谢谢啦!
 楼主| 发表于 2014-10-8 20:19:20 | 显示全部楼层
gogogogo 发表于 2014-10-8 11:56
至少我觉得mmcblk0p2是有问题的,还是环境设置不对的原因,建议重新设置环境。 ...
正确的应该怎么配置呢?
发表于 2014-10-9 16:57:37 | 显示全部楼层
2.我使用SD卡启动的。 ...
楼主你好,在官网上Demo images是在L3.10.17_1.0.0_IMX6QDLS_BUNDLE里一起的。下载链接为:https://www.freescale.co
m/weba ... ab=Design_Tools_Tab
。往SD卡里写,并启动是OK的。我在我这边已经试过。根据文档中的说明就是可以的。
这里建议你先跑一下官网的Demo。
发表于 2014-10-9 16:58:08 | 显示全部楼层
rivita 发表于 2014-10-8 20:03
由于自己制作的板子已经回来了,现在在开发板上还没跑通,挺着急的,有没有相关文档或者什么的,官网上的资 ...
请问你是想要使用哪个版本的BSP ?
发表于 2014-10-9 16:58:46 | 显示全部楼层
IT   include/autoconf.h -> include/conf ...
楼主你好,请问你这里使用LTIB编译的是哪个版本的BSP呢?
发表于 2014-10-9 16:59:30 | 显示全部楼层
不要着急,现在你告诉我你是要使用哪个版本的BSP,我告诉你如果操作启动板子。
 楼主| 发表于 2014-10-9 21:20:37 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-10-9 16:59
不要着急,现在你告诉我你是要使用哪个版本的BSP,我告诉你如果操作启动板子。 ...
yocto用的是fsl-yocto-3.10.17_1.0.0.gz
LTIB用的是L3.0.35_4.1.0_130816_source.tar.gz
我想知道您们官方推荐用哪个?您能不能教我一下启动的配置或者资料,最好能有编译资料,官方文档写的好简单呀,真的谢谢啦!
 楼主| 发表于 2014-10-9 21:21:47 | 显示全部楼层
或者会不会是我写SD卡的方法有问题?
GMT+8, 2025-10-22 17:29 , Processed in 0.100954 second(s), 29 queries , MemCache On.
