查看: 4604|回复: 18
[求助] KL16串口的问题
发表于 2015-6-3 21:48:12 | 显示全部楼层 |阅读模式
各位大侠:
       我用KL16的UART0串口每隔1ms给电脑发送一帧数据,格式是61 XX XX XX XX 共五个字节这样的,115200波特率,但是在串口猎人上接收到的数据会有丢数据或者数据不对的,看了一下寄存器,实际波特率算下来是117647,我用的是网上的例程,串口初始化函数是uart0_init(UART0_BASE_PTR,2000,115200);
void uart0_init (UART0_MemMapPtr uartch, int sysclk, int baud)
    uint8 i;
    uint32 calculated_baud = 0;
    uint32 baud_diff = 0;
    uint32 osr_val = 0;
    uint32 sbr_val, uart0clk;
    uint32 baud_rate;
    uint32 reg_temp = 0;
    uint32 temp = 0;
    SIM_SCGC4 |= SIM_SCGC4_UART0_MASK;
    // Disable UART0 before changing registers
    UART0_C2 &= ~(UART0_C2_TE_MASK | UART0_C2_RE_MASK);
    // Verify that a valid clock value has been passed to the function
    if ((sysclk > 50000) || (sysclk < 32))
        sysclk = 0;
        reg_temp = SIM_SOPT2;
        reg_temp &= ~SIM_SOPT2_UART0SRC_MASK;
        reg_temp |= SIM_SOPT2_UART0SRC(0);
        SIM_SOPT2 = reg_temp;
    // Verify that a valid value has been passed to TERM_PORT_NUM and update
    // uart0_clk_hz accordingly.  Write 0 to TERM_PORT_NUM if an invalid
    // value has been passed.
    if (TERM_PORT_NUM != 0)
     // Enter inifinite loop because the
     // the desired terminal port number
     // invalid!!
     while(1)
    // Initialize baud rate
    baud_rate = baud;
    // Change units to Hz
    uart0clk = sysclk * 1000;
    // Calculate the first baud rate using the lowest OSR value possible.
    i = 4;
    sbr_val = (uint32)(uart0clk/(baud_rate * i));
    calculated_baud = (uart0clk / (i * sbr_val));
    if (calculated_baud > baud_rate)
        baud_diff = calculated_baud - baud_rate;
    else
        baud_diff = baud_rate - calculated_baud;
    osr_val = i;
    // Select the best OSR value
    for (i = 5; i <= 32; i++)
            temp = calculated_baud - baud_rate;
        else
            temp = baud_rate - calculated_baud;
        if (temp <= baud_diff)
            baud_diff = temp;
            osr_val = i;
    if (baud_diff < ((baud_rate / 100) * 3))
        // If the OSR is between 4x and 8x then both
        // edge sampling MUST be turned on.
        if ((osr_val >3) && (osr_val < 9))
            UART0_C5|= UART0_C5_BOTHEDGE_MASK;
        // Setup OSR value
        reg_temp = UART0_C4;
        reg_temp &= ~UART0_C4_OSR_MASK;
        reg_temp |= UART0_C4_OSR(osr_val-1);
        // Write reg_temp to C4 register
        UART0_C4 = reg_temp;
        reg_temp = (reg_temp & UART0_C4_OSR_MASK) + 1;
        sbr_val = (uint32)((uart0clk)/(baud_rate * (reg_temp)));
         /* Save off the current value of the uartx_BDH except for the SBR field */
        reg_temp = UART0_BDH & ~(UART0_BDH_SBR(0x1F));
        UART0_BDH = reg_temp |  UART0_BDH_SBR(((sbr_val & 0x1F00) >> 8));
        UART0_BDL = (uint8)(sbr_val & UART0_BDL_SBR_MASK);
        /* Enable receiver and transmitter */
        UART0_C2 |= (UART0_C2_TE_MASK
                    | UART0_C2_RE_MASK );
    else
请各位大侠指正,谢谢!
我知道答案 目前已有18人回答
发表于 2015-6-4 09:32:10 | 显示全部楼层
楼主的波特率误差以及超出1.5%了,所以会出问题。
你可以参考KL26的UART代码:
uart.rar (2.65 KB, 下载次数: 20)
发表于 2015-6-4 10:31:27 | 显示全部楼层
顺便来偷师一下
 楼主| 发表于 2015-6-4 11:16:07 | 显示全部楼层
你可以参考KL26的UART代码:
你好,我又设置UART时钟为48000000,FLL做时钟源,算下来波特率为115384,低于千分之二了,可是还是会出现数据传错问题。。
MCG_C1 |= MCG_C1_IRCLKEN_MASK;
MCG_C4 |= 0xa0;
uart0_init(UART0_BASE_PTR,48000,115200);
还有上面这样配置有问题吗,FLL这样配置有误差吗?
    发表于 2015-6-4 12:43:09 | 显示全部楼层
    学习了!
    发表于 2015-6-4 13:37:32 | 显示全部楼层
    gaow11 发表于 2015-6-4 11:16
    你好,我又设置UART时钟为48000000,FLL做时钟源,算下来波特率为115384,低于千分之二了,可是还是会出 ...
    你FLLCLK是48Mhz吗?
    你用的是内部时钟还是外部晶振多大?
    另外,如果用的是外部晶振,那么FRDIV是多大?
    首先你要保证你给uart初始化的时钟源频率是对的。
    另外,你的串口线是否有干扰?
     楼主| 发表于 2015-6-5 10:46:18 | 显示全部楼层
    FSL_TICS_ZJJ 发表于 2015-6-4 13:37
    你FLLCLK是48Mhz吗?
    你用的是内部时钟还是外部晶振多大?
    用的内部晶振,慢速时钟32.768K的,MCG_C4 |= 0xa0;
    设置FLL48MHz
    发表于 2015-6-5 10:49:21 | 显示全部楼层
    设置FLL48MHz
    你把代码工程给我,我这边测试看看是否正常。
    发表于 2015-6-5 10:57:52 | 显示全部楼层
    另外,楼主把你UART发出来的数据,给我贴一部分出来。
     楼主| 发表于 2015-6-7 11:15:35 | 显示全部楼层
    我用的是GPIOD中断,每1ms中断一次,接收六个SPI数据以后再通过串口发送其中四个,以0x61作为间隔符,测试串口的时候没有用SPI数据,只是发固定的测试数据,附上代码和接收到的串口数据
    klxx-sc-baremetal.zip
    4.96 MB, 下载次数: 23, 下载积分: 威望 1
    串口数据.zip
    2.49 KB, 下载次数: 5, 下载积分: 威望 1
    GMT+8, 2025-11-7 05:46 , Processed in 0.103535 second(s), 31 queries , MemCache On.
