查看: 13373|回复: 10
[原创] 【YL-KL26Z开发】+ IIC读写24C02
发表于 2015-7-26 21:04:30 | 显示全部楼层 |阅读模式
接上次RTC中断翻转LED实验:https://www.nxpic.org.cn/module/forum/thread-600274-1-1.html
本次所做实验为IIC读写EEPROM,即24C02。由于之前在51上模拟过IIC,对时序方面还有印象,所以本次实验难度不大。
下面是源程序:
主程序:
for (i = 0; i < 8; i++) {                                            /* 数组初始化                   */
        ucData = i;
       printf("Data = %d \r\n" , ucData);               /*将要写入EEPROM的数据在串口上显示*/
    printf("Now Start Write ...\r\n");
    I2C0WriteMultiRegister(EEPROM_I2C_ADDRESS, 0x00, ucData,8);                /*将数据写入EEPROM*/
        ucData = 0;
        printf("Now Start Read...\r\n");
       j = I2C0ReadMultiRegisters(EEPROM_I2C_ADDRESS, 0x00, 8,ucData);    /*读取EEPROM中的数据*/
       printf("DummyRead = %d\r\n",j);
        if (ucData != i) {
            GPIO_TOGGLE(MKL_PORTB,19);                                  /* 验证失败,D6亮           */
            printf("ERR!");
                while (1);
    GPIO_TOGGLE(MKL_PORTD,1);                                            /* 验证正确,D7亮             */
     printf("OK!");
   while(1);
IIC初始化:
void init_I2C(void)
  SIM_SCGC5 = SIM_SCGC5_PORTA_MASK | SIM_SCGC5_PORTB_MASK | SIM_SCGC5_PORTC_MASK | SIM_SCGC5_PORTD_MASK |           SIM_SCGC5_PORTE_MASK;
  SIM_SCGC4 |= SIM_SCGC4_I2C1_MASK; //开启IIC时钟
  /* 配置I/O口为IIC功能*/
  PORTC_PCR10 = PORT_PCR_MUX(2);
  PORTC_PCR11 = PORT_PCR_MUX(2);
  I2C1_F  = 0x16;       // 配置IIC时钟频率
I2C1_C1 = I2C_C1_IICEN_MASK;       /* 使能 IIC */
IIC读写选择:
void IIC0_StartTransmission (unsigned char SlaveID, unsigned char Mode)
  if(Mode == MWSR)
    /* 设置为读*/
    MasterTransmission = MWSR;
  else
    /* 设置为写 */
    MasterTransmission = MRSW;
  /* 配置从机为相应读写 */
  SlaveID = SlaveID << 1;
  SlaveID |= (unsigned char)MasterTransmission;
  /* 启动操作 */
  i2c0_Start();
  /* 写器件地址*/
  i2c0_write_byte(SlaveID);
IIC写操作:
void I2C0WriteMultiRegister(unsigned char SlaveAddr, unsigned char u8RegisterAddress, unsigned char *u8Data, unsigned int length)
    uint16 i;
  /* 写从机地址&写操作 */
IIC0_StartTransmission(SlaveAddr,MWSR);
  i2c0_Wait();       //等待写入完成
  I2C0_D = u8RegisterAddress;        //写地址
  i2c0_Wait();
  for(i=0; i<length; i++)
      I2C0_D = u8Data;                 //发送数据
      i2c0_Wait();
i2c0_Stop();                                //停止命令
  Pause(7);                                    //等待
IIC读操作:
unsigned char I2C0ReadMultiRegisters(unsigned char SlaveAddr, unsigned char u8RegisterAddress, unsigned char bytes, char buf[])
  unsigned char n=bytes;
  int i;
  /* Send Slave Address */
  i2c0_Wait();
  /* Write Register Address */
  i2c0_Wait();
  /* Do a repeated start */
  I2C0_C1 |= I2C_C1_RSTA_MASK;
  I2C0_D = (EEPROM_I2C_ADDRESS << 1) | 0x01; //read address
  i2c0_Wait();
  /* Put in Rx Mode */
I2C0_C1 &= (~I2C_C1_TX_MASK);
        //设置为读操作
  /* Ensure TX*** bit is 0 */
I2C0_C1 &= ~I2C_C1_TX***_MASK;
  /* 虚拟读 */
  result[0] = I2C0_D ;                                        //这里的操作有什么意义?
  i2c0_Wait();
  for(i=0;i<n-2;i++)
    /* Read first byte */
    buf = I2C0_D;
    i2c0_Wait();
  /* 非应答*/
I2C0_C1 |= I2C_C1_TX***_MASK;
  /* Read second byte */
  buf[i++] = I2C0_D;                                   //为什么要非应答后再读次低位数据?
  i2c0_Wait();
  /* Send stop */
i2c0_Stop();
  /* Read third byte */
  buf[i++] = I2C0_D;                                  // 为什么停止操作后再读最低位数据?
        for(i = 0; i < 8; i++)
          printf("ReadData = %d\r\n", buf);        //将读取的数据通过串口发送
  return result[0];              //这里返回值为虚拟读的值,但是我不知道如何把读到的数组buf返回,求大神指点!!!!!
依照惯例,其他的程序就不贴了。和上次一样,程序关注点放在红色的部分即可。
上面那个蓝色的东西,希望有大神可以不吝赐教,非常感谢。
附手册IIC读写时序:
这次实验由于读写速度很快就没有视频了,附一张图:
附源工程: I2C_Master.zip (1.13 MB, 下载次数: 104)
参与人数 1NXP金币 +30 收起 理由
小七 + 30 打赏!
    发表于 2015-7-26 21:56:29 | 显示全部楼层
    楼主很专业啊:
    2022-3-3 09:56
  • 签到天数: 4 天
    发表于 2015-7-26 22:50:58 | 显示全部楼层
    感谢分享,很详细。
  • 签到天数: 9 天
    发表于 2015-7-29 10:29:39 | 显示全部楼层
    感谢分享,很详细。
  • 签到天数: 158 天
    发表于 2015-10-8 23:55:34 | 显示全部楼层
    谢谢分享!
    发表于 2015-10-12 12:43:43 | 显示全部楼层
    谢谢分享
    发表于 2015-10-22 11:34:31 | 显示全部楼层
    感谢分享,学习中,谢谢
    发表于 2015-10-22 13:49:35 | 显示全部楼层
    感谢分享
    发表于 2015-10-23 09:04:00 | 显示全部楼层
    楼主的是一个系列啊
    发表于 2015-10-26 08:47:26 | 显示全部楼层
    感谢楼主分享
    GMT+8, 2026-2-22 03:12 , Processed in 0.114727 second(s), 30 queries , Redis On.
