12
返回列表 发新帖
楼主: bccuje
[求助] MKE02Z32VLC4无法下载程序,
发表于 2015-10-28 13:00:50 | 显示全部楼层
bccuje 发表于 2015-10-28 11:33
https://www.nxpic.org.cn/module/forum/thread-602294-1-1.html提供的固件,JLINK没有问题了,日期是14 ...
你的意思,你的JLINK不是用的单独的JLINK啊?
你用FRDM KL02的opensda转的JLINk?
那你FRDM KL02的CLK有没有断开?
 楼主| 发表于 2015-10-28 13:47:01 | 显示全部楼层
那你FRDM KL02的CLK有没 ...
JLINK两个我都有:两个CLK肯定断开的,我只有一组线,
JLINK用FRDM KL02的opensda转的JLINk,连接上:
, - Connecting via USB to J-Link device 0
- J-Link firmware: V1.20 (J-Link OpenSDA compiled Apr 24 2014 14:43:37)
- Target interface speed: 5 kHz (Fixed)
- Initializing CPU core (Init sequence) ...
    - Initialized successfully
- Target interface speed: 1429 kHz (Auto)
- CPU clock frequency: 20961 kHz (Auto detected)
- Connected successfully
但下载时出现:
Auto programming target (6364 bytes, 1 range) ...
- Erasing affected sectors ...
    - ERROR: Timeout while checking target RAM, core does not stop
    - ERROR: Failed to erase sectors
- De-initializing CPU core (Exit sequence) ...
- ERROR: Failed to auto program target
用MDK5联调时,能识别到JLINK,但没有找到KE02,KE02没有连接成功
发表于 2019-8-7 16:35:18 | 显示全部楼层
各位大佬,问下keil怎样用KE02Z40M例程程序移植到MKE02Z32VLC4芯片中去啊,求助,急急急!!!
发表于 2019-9-4 13:45:46 | 显示全部楼层
发表于 2019-9-4 13:46:29 | 显示全部楼层
13#同志,keil怎样用KE02Z40M例程程序移植到MKE02Z32VLC4芯片中去,你有解决吗,谢谢
GMT+8, 2025-10-25 10:06 , Processed in 0.169840 second(s), 24 queries , MemCache On.
