查看: 3376|回复: 1
[分享] Kinetis K60系列之FTM输出PWM
发表于 2016-9-21 09:09:59 | 显示全部楼层 |阅读模式
程序 LED渐亮渐灭
  1. #include "project.h"
  2. void delay(U32);
  3. void FTM_PWM_Init(void);
  4. ;
  5. void main(void)
  6. {
  7.     U16 FTM2_CH0_Duty,FTM2_CH1_Duty
  8.     DisableInterrupts;
  9.     UART4_Init(115200);
  10.     FTM_PWM_Init();
  11.     EnableInterrupts;
  12.     while(1)
  13.     {
  14.         for(FTM2_CH0_Duty = 0,FTM2_CH1_Duty = 0;FTM2_CH1_Duty  < 300;FTM2_CH1_Duty++,FTM2_CH0_Duty++)
  15.         {
  16.             FTM2_C0V = FTM2_CH0_Duty;
  17.             FTM2_C1V = FTM2_CH1_Duty;
  18.             delay(100000);
  19.         }
  20.         for(FTM2_CH0_Duty = 300,FTM2_CH1_Duty = 300;FTM2_CH1_Duty  > 0;FTM2_CH1_Duty--,FTM2_CH0_Duty--)
  21.         {
  22.             FTM2_C0V = FTM2_CH0_Duty;
  23.             FTM2_C1V = FTM2_CH1_Duty;
  24.             delay(100000);
  25.         }
  26.     }
  27. }
  28. void delay(U32 count)
  29. {
  30.     while(count--);
  31. }
  32. void FTM_PWM_Init(void)
  33. {
  34.     PORTA_PCR10 = PORT_PCR_MUX(0x03) | PORT_PCR_DSE_MASK;
  35.     PORTA_PCR11 = PORT_PCR_MUX(0x03) | PORT_PCR_DSE_MASK;
  36.
  37.     SIM_SCGC3 |= SIM_SCGC3_FTM2_MASK;
  38.     FTM2_SC |= (FTM_SC_CLKS(1)           // 系统时钟
  39.                |FTM_SC_PS(7));           // 128 分频
  40.
  41.     FTM2_C0SC |= (FTM_CnSC_MSB_MASK      // MSB 1
  42.                  |FTM_CnSC_ELSA_MASK);   // ELSA 1
  43.     FTM2_C1SC |= (FTM_CnSC_MSB_MASK      // MSB 1
  44.                  |FTM_CnSC_ELSA_MASK);   // ELSA 1
  45.
  46.     FTM2_OUTMASK = 0XFC;                 // 屏蔽CH2~CH7通道 打开CH0 CH1
  47.     FTM2_CNTIN = 0;                      //FTM 计数初始值
  48.     FTM2_MOD   = 299;                    // 计数的值 频率=分频/(MOD - CNTIN + 1)
  49.
  50.     FTM2_C0V   = 0;                      // 占空比 (CnV-CNTIN)/(MOD-CNTIN+1)
  51.     FTM2_C1V   = 0;                      // 占空比
  52. }
    发表于 2016-9-21 09:16:43 | 显示全部楼层
    多谢分享
    GMT+8, 2025-10-20 00:32 , Processed in 0.088256 second(s), 23 queries , MemCache On.
